1,277 -
71
Everything posted by Phatline
From the album: Trigger-Matrix-Footboard-CC
http://wiki.midibox.org/doku.php?id=16th_fixed_polysequencer
ok
i need rackmount . with desktop case or simular would be fine. not too deep
na 300mm dont fit in my flight cases. thought more in the size of your desktop cases. they dont fit?
is there a case for the rackmount panel?
multitrack record, recorded with zoom livetrack12, made with one JP8080 for all tracks (also drums) overdubed with the Midi-Clock to Audio, Audio to Midi-Clock technology in order to drive a midibox seq light multiple once after a nother... info about midi-clock to audio: and wiki: http://wiki.midibox.org/doku.php?id=clock2audio2clock
cool idea... i also want such device.
i want to connect one Encoder directly to J5a i know that in my Code i have to initalize this pins: // initialize pin 2 of J5A, as Digital input with internal Pull-UP //connect to ground MIOS32_BOARD_J5_PinInit(0, MIOS32_BOARD_PIN_MODE_INPUT_PU); MIOS32_BOARD_J5_PinInit(1, MIOS32_BOARD_PIN_MODE_INPUT_PU); and i also can observe the state of the J5a pin by putting following code into APP_Background: MIOS32_BOARD_J5_PinGet(0) MIOS32_BOARD_J5_PinGet(1) all clear so far, and working good with buttons (with hardware debouncing ): debouce-circuit how does a Encoder-Code look like (without any Acceleration), and how does Hardware debouncing look like (the same like for buttons?), i want to use as less code then possible... thx 4 any tips
na directly recording midi wasnt the way, but first convert it to audio pulses on a DOUT-Pin, and then record it, when playback it go thru a Schmitt Trigger into a DIN-Pin, the strip down mios-functions and code, it is running thight, HURRAAY i solved it this way: clock2audio2clock - wiki
- 11 replies
- phatline
- audio to clock
- (and 9 more)
is it possible to convert a Midiclock-Stream to audio? and convert this audio-recording back to midiclock? so i could use one of the RECorder-channels for the midi (clock start stop notes and so on) are there already devices out there? i can remember that 30 years ago such things as midi tape exist... or is it maybe a cheap trick that can be solved with an optocopler an opamp and a few lines of code? its done VIDEO-Overdubbing a JP8080:
- 11 replies
- phatline
- audio to clock
- (and 9 more)
