15,248 -
It still works at my side, but I noticed a problem with the "store" function - it doesn't store the network setup. Could this be the problem at your side? (check the current configuration with the "network" command) The fix will be available with the next release. Meanwhile you could enter the configuration directly into the MBSEQ_GC.V4 file: BLM_SCALAR_Port 66 and OSC_RemoteIp 2 192.168.11.102 OSC_RemotePort 2 8000 OSC_LocalPort 2 8000 OSC_TransferMode 2 1 (note that in this file the connection numbers are counted from 0) After the changes, enter "reset" to reload the configuration. Best Regards, Thorsten.
The required configuration is explained in the MBSEQ manual: http://www.ucapps.de/midibox_seq_manual_blm.html search for "osc_remote" Did you try the same? Best Regards, Thorsten.
To 1) in src/cs_menu_tables.inc you will find following table: ========================================================================== ; The wavetable menu ; ========================================================================== CS_MENU_TABLE_WT db (CS_MENU_TABLE_WT_End-CS_MENU_TABLE_WT)/CS_MENU_ENTRY_LEN, 0x00 ;; Register (00=dummy) |<-->| max print ix, exec ix parameter transfer CS_MENU_ENTRY CS_MENU_WT_STEP, "Step", 0x1f+1,PRINT_VAR_WTSTEP, EXEC_SELPAR, R2PP2R_VAR_WTSTEP CS_MENU_ENTRY 0x00, "Mode", 0x03, PRINT_VAR_WTMODE, EXEC_TOGPAR, R2PP2R_VAR_WTPAR CS_MENU_ENTRY 0x01, " #1 ", 0xff, PRINT_VAR_WTPAR, EXEC_SELPAR, R2PP2R_VAR_WTPAR CS_MENU_ENTRY 0x02, " #2 ", 0xff, PRINT_VAR_WTPAR, EXEC_SELPAR, R2PP2R_VAR_WTPAR CS_MENU_ENTRY 0x03, " #3 ", 0xff, PRINT_VAR_WTPAR, EXEC_SELPAR, R2PP2R_VAR_WTPAR CS_MENU_ENTRY MBFM_Px_WT_RATE, "Rate", 0x7f, PRINT_Px_DEC, EXEC_SELPAR, R2PP2R_Px CS_MENU_ENTRY MBFM_Px_CTRL2_U, "Sync", 0x02, PRINT_Px_WTSYNC, EXEC_TOGPAR, R2PP2R_Px CS_MENU_ENTRY MBFM_Px_WT_PAR1, "CC#1", 0x7f, PRINT_Px_CCASG, EXEC_SELPAR_ASG, R2PP2R_Px CS_MENU_ENTRY MBFM_Px_WT_PAR2, "CC#2", 0x7f, PRINT_Px_CCASG, EXEC_SELPAR_ASG, R2PP2R_Px CS_MENU_ENTRY MBFM_Px_WT_PAR3, "CC#3", 0x7f, PRINT_Px_CCASG, EXEC_SELPAR_ASG, R2PP2R_Px CS_MENU_TABLE_WT_End Here you could re-order the menu items to test if you are satisfied with the result. Once you are happy, and for the case that more people would like to get this change, I would change this in the official firmware To 2) I understand your wish (I had the same, and implemented in MBSID V2) But for MBFM it isn't possible due to memory limitations and design decisions which make it difficult today to add such changes, as simple they might sound for you as a user... Please note also, that the MBFM project is only in "maintenance mode" anymore, which means: only bugfixes and minor changes which don't need much attention from my side will be provided. Best Regards, Thorsten.
The usage of source drivers (the transistors) is for pro users who want to get perfect results. I'm unsure if this really makes a big difference. It's more important that you try to keep the number of selection lines per matrix as low as possible (8 is acceptable, 4 is perfect) Best Regards, Thorsten.
I added the expert option in the Utility->OPT page (item #12) -> http://www.ucapps.de/mios32/midibox_seq_v4_084_pre1.zip Could you please test this at your side? Best Regards, Thorsten.
In this version the quantized value should be displayed at the lower line. The unquantized value is still visible at the upper right line. http://www.ucapps.de/mios32/midibox_seq_v4_084_pre1.zip This approach isn't an option, but always applied. Could you please test this at your side? Best Regards, Thorsten.
Live input from Different Channels for Different Tracks
TK. replied to phillwilson's topic in MIDIbox SEQ
The Live feature shouldn't apply FTS to drum tracks anymore in this version: http://www.ucapps.de/mios32/midibox_seq_v4_084_pre1.zip Could you please test this at your side? Best Regards, Thorsten. -
Ok, I see... please try this version: http://www.ucapps.de/mios32/midibox_ng_v1_031_pre2.zip In addition, you've to set "key=any" for EVENT_SENDER as well: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fconev_6.ngc Best Regards, Thorsten.
That's too much code for a quick check (and I'm also no DMX expert...) However, you wanted to setup Push Pull mode, but actually you activate Open Drain Mode: MIOS32_SYS_LPC_PINMODE_OD(2, 0, 1); Write (2, 0, 0) instead to ensure that Push-Pull is configured. (Sidenote: due to a LPC1769 silicon bug, it will be push pull anyhow, but just to ensure...) For the baudrate and pin behaviour, I'm sure that the scope will help to debug this! :) Best Regards, Thorsten.
Yes, it should have a positive effect on a MB64E as well. For large value ranges it's only subtile, for smaller ranges (e.g. 0..255 - mostly used) it's noticeable. This doesn't happen at my side. Ok, it depends on how we define "very slowly..." - but when I rotate the encoder slowly I can see that the values are incremented continuously and precisely +/- 1 With MIOS V1.9g sometimes the value was sporadically incremented much faster on slow movements, but with MIOS V1.9h this doesn't happen anymore. It could be related to your encoder. How does it work when you are changing CutOff with the main encoder instead? And compare also parameters with lower value ranges, acceleration control should be super-precise for them now :smile: Slave cores don't need the MIOS V1.9h update. Best Regards, Thorsten.
:pirate: :thumbsup:
Hi Phill, no, it "quantise" to the measure instead, and the measure length can be configured in the Utility->Opt page (it's 16 steps by default) Whenever these number of steps have been played, the step progression (clock divider values and step position) of the tracks which activated this synchronisation option will be reset. All tracks which have enabled the sync option should be aligned again once the measure has been played. I just tested this again at my side: it still works. :smile: This would be a slightly different approach, and I'm not sure if this is better than the current one. Currently the tracks just continue to play until the 1st step of the measure is reached, then all tracks which have this synch option enabled will be restarted and are then aligned again. The quantization works depending on the clock divider, and this might confuse you. Means: with a clock divider of 16 (16th notes) one step takes 96 "clock ticks". With a quantisation of 50% the incoming MIDI event will be put into the next step if it's delayed by more than 48 ticks. With a clock divider of 64 (4th notes) one step takes 384 ticks, therefore the incoming MIDI event will be put into the next step after a delay of 192 ticks. So: the time window over which the quantisation takes place is much larger. However, I think that 50% is a bad choice anyhow. Most people prefer 10% We had 20% by default some time ago, but users complained that this is too much. Therefore I would propose to try smaller values. Best Regards, Thorsten.
Ok, starting with MIOS32 was a good idea, because especially the possibility to send "printf" like debug messages helped me to find an easy solution, which also fits nicely into MIOS8. Could you please install this new MIOS version: /edit: removed expired link, please download the official version under http://www.ucapps.de/mios_download.html Thereafter install MBSID V2 again: /edit: removed expired link, please download the official version under http://www.ucapps.de/mios_download.html (still enctest2, the same that I provided some days ago) Encoders should behave better now! Best Regards, Thorsten.
Yes, this will work. Now tested here: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fconev_6.ngc Best Regards, Thorsten.
I understand your requests, but from my point of view they don't fit with the concepts behind MIDIbox CV. It would be a separate application with a dedicated UI. If you don't mind, I will split your post to a separate topic - maybe somebody else with programming skills is interested to help you... Best Regards, Thorsten.
yes Best Regards, Thorsten.
I won't delete this topic, because it's a useful confirmation that two chained MBHP_AOUT_NG modules are working :) Best Regards, Thorsten.
I'm using the feedback option in almost all bassline demos, e.g. in this one: http://www.ucapps.de/mp3/midibox_sid/mbsid_v2_tk2_soundbank_demo.mp3 However, the signal/noise ratio is very poor, which means that the option will only work for loud music... ;-) Best Regards, Thorsten.
I know what you mean, because I had the same impression and see the need for improvements. But it won't be trivial, especially since a (more than 10 years old) routine in MIOS8 has to be overworked, and this will be *very* time consuming. However, meanwhile I got the idea that I could try to improve this in MIOS32 first, which has the same algorithm. And once I'm happy, I could translate it into the (assembly based) MIOS8. Hopefully it will be possible without consuming additional RAM, because there is no free RAM available in MIOS8... Best Regards, Thorsten.
A SID player can switch between multiple patches quickly (almost zero-time) because it has direct access to the "patch memory". MIDIbox SID has to load patches from an external EEPROM instead, this consumes time and the amount of time depends on the patch size. During the development phase of the firmware (ca. 7 years ago) the first beta users preferred to get as many sound features as possible. This was leading to an increased patch size, and this was in contradiction to the patch load speed, but it has been accepted. So, somebody could implement an alternative firmware with much less sound features, but faster patch load time. Or somebody could use a more modern microcontroller with enough embedded RAM (or fast access to external memory) to overcome such limitations. It wouldn't be in my own scope, because I'm happy with the implementation. Best Regards, Thorsten.
Ok, I added to the wishlist that an "expert option" should be added which allows to disable this default behaviour (means: FTS only if enabled in the MODE page) Best Regards, Thorsten.
Alright, one issue solved :) Could you please try this version? It should work without compatibility issues: -> http://www.ucapps.de/mios32/midibox_ng_v1_031_pre1.zip To the query issue: it would be interesting if Query works again if you disconnect/re-connect the core and restart MIOS Studio. If this doesn't help: does it work after a Windows reboot? Best Regards, Thorsten.
The changed behaviour in V1.030 is related to the new Switch function, which ensures that a NoteOn/Off event is only sent once as requested here: So, you have a different use case which I haven't considered: you want to send continuous Note On events from an analog input like somebody is normally doing with CCs, right? Here a modified version which disables the change for "AIN Switches", so that you can proceed with the analysis: http://www.ucapps.de/mios32/midibox_ng_v1_031_modified_ain_notes.zip Unfortunately this won't satisfy the needs of dOperator anymore... :-( In future it will be required to enhance the EVENT_AIN configuration in order to select one of the contradicting use cases. I did another change in this version: "MIDI Clock Inputs" are disabled by default now. Could you please check if the "MidiFileClkOutPorts" workaround is still required at your side? Best Regards, Thorsten.
GMAprogrammer's update issues with v1.030 are now discussed in a separate thread:
Please show me the AIN configuration of your .NGC file And which MBNG version did you use before the update? Best Regards, Thorsten.
