15,248 -
I can generate similar peaks with the PIC when I take a long cable (> 5 m) ;) How long are your cables to the CLK and Ground pins? Best Regards, Thorsten.
Interesting! Where did you probe the signal, at the PWM output of the microcontroller, or at the CLK input of the SID? However, since the resistor doesn't help, using a cap against ground seems to be the right way to solve the issue. Best Regards, Thorsten.
Do you mean song steps (A1, A2, .. A8, B1, B2, ... B8) or track steps? If song steps: it's normal that MBSEQ starts a song from the currently displayed position to simplify editing. Just change to another page (e.g. EDIT) and push the start button from there - then the song should be started from A1 If you (and/or some other) people don't like this behaviour, I could make it optional. This is strange! I need your session directory, and the MBSEQ_GC.V4 file in the root directory to analyze this. Best Regards, Thorsten.
I'm a bit confused from your reply and guess, that you missed the message: you can modulate all six OSCs with a single modulation path by enabling the L/R switches of the direct modulation targets for OSC pitch. This will copy the modulation result to all (selected) targets. Did you every try this - where is the difference? Best Regards, Thorsten.
NEW Backpanel design for the SEQ4 aluminum case (LPC17 & STM32F4)
TK. replied to kristal='s topic in MIDIbox SEQ
The breakout board is not an external board, it just brings all interfaces together and allows to mount the MBHP_CORE_STM32F4 (or MBHP_CORE_LPC17) under the frontpanel at the bottom of the case without tricks and with much more free space. Here a picture from orange_hand which shows what I mean: Original article (in german): Re: Midibox Sequenzer MBSEQ V4 / The Project I'm trying to highlight that there is a solution which makes LPC17 and future STM32F4 users happy. Such a breakout board would even open the possibility to upgrade the MIDIbox SEQ with future core modules w/o high costs, because most interface components are already part of the breakout board. We wouldn't have a dependency between the core module layout and the backpanel anymore. Best Regards, Thorsten. -
Yes, I'm planning to provide timed events sooner or later. I've already some ideas for an efficient implementation (it could be similar to the MIDI event scheduler), but due to the memory consumption it might only be provided for the MBHP_CORE_STM32F4 module. Best Regards, Thorsten.
Hi, the DEFAULT_BPM_DIGITS_* configuration looks correct for your hardware. Could it be that the common lines are connected to the wrong Dx output pins? I'm a bit unsure if it was (D7, D6, D5) or (D2, D1, D0) Best Regards, Thorsten.
Building a MIDIbox SEQ V4 (Wilba Control Surface) - Photo Tutorial
TK. replied to Hawkeye's topic in Tips & Tricks
Very nice report! I'm also looking forward for the upcoming case design :) Best Regards, Thorsten.- 35 replies
It's started, but not finished, see: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fprocessing%2Fmidibox_cv_v2%2Fsrc%2Fcomponents%2FMbCvVoice.cpp 1st place: search for "transfer note -> linear frequency" 2nd place: search for "linear frequency -> CV frequency conversion" It won't be so easy to finalize this, if you would like to work on the implementation, step forward. :) Best Regards, Thorsten.
No, you need potentiometers (in the schematic called R_p) for the calibration to compensate the usual device tolerances. Best Regards, Thorsten.
As mentioned in another thread, I highly recommend to use a MBHP_CORE_STM32F4 module, since this will be the only one which will be able to run the upcoming "V4 Plus" firmware (due to higher amount of RAM and Flash resources, and higher speed). Accordingly the backpanel will look different. E.g. MBHP_CORE_STM32F4 natively supports 4 MIDI INs and 4 MIDI OUTs - is there still a need for 4 additional IIC based MIDI OUTs? For SD Card and USB Socket we need a breakout board, because the MBHP_CORE_STM32F4 module is too large so that it can't directly mounted at the backpanel (/edit: to be more precisely - instead it has to be mounted at the bottom of the case) For ethernet the MBHP_ETH module would be required. This opens the option that somebody designs a special breakout board with: - 4 MIDI IN/OUT based on two MBHP_MIDI_IO boards - USB, and here the question: do you prefer a B Socket like before, or would Micro USB be more interesting - advantage of Micro USB: an USB Host option would be possible! - SD Card Socket - Ethernet Circuit (MBHP_ETH module) + Socket. For LPC17 a direct socket connection would be required (MBHP_ETH not used) - 25 pin AOUT/SRIO Breakout Socket Optionally with line drivers to support cable lengths of up to 5m -> http://www.ucapps.de/mbhp/line_drivers.pdf - BLM Socket - Power Switch and Ext. Power Socket Such a breakout board would have another advantage: it would be compatible to the MBHP_CORE_LPC17 module as well! And we could create a common backpanel design for it. Best Regards, Thorsten. -
For the records: Zenlogic had the same issue with an Atmel Microcontroller and solved it:
Yes, you need two MBHP_DIO_MATRIX modules, yes, these are 1N4148 diodes, and yes the LEDs are driven similar to the LED Ring schematic. Note that the 10x10 dimension isn't the best choice, because LEDs won't be so bright like on a 8x8 configuration. Best Regards, Thorsten.
Well done! :thumbsup: It seems that the Atmel microcontroller has much "stronger" pad drivers compared to the PIC which can lead to such EMC issues. This might also explain why the 6581 was working: it's produced in a different technology which consumes more power. Probably the input resistance of the clock input is lower, and this causes the same effect like the cap that you've added. The proper solution would be (if my assumption is correct) to add a resistor in serial, e.g. 100 Ohm should be fine. It will limit the current drawn during signal transitions so that the nominal voltage isn't exceeded. Using a cap is also possible, but not the best choice, because it will cause higher current drawn during transitions (no dramatic drawn, not really noticeable, but if you ask for the preferred solution, take the resistor) Best Regards, Thorsten.
Hi, it should work the following way: configure the encoder, so that it doesn't send a value. The integrated button has to execute a .NGR script section. From there you could send the current encoder value - e.g. here for encoder 1 (ENC:1) # type port chn value send ProgramChange USB1 1 ENC:1 Unfortunately timed events are not supported. Best Regards, Thorsten.
It's interesting, that the other guy was using an Atmel chip as well, and had (or still has?) the same issue. I would propose to check the shift register transfers. Write a routine which allows you to set different data values at the shift register output, e.g. controlled via incoming CCs or MIDI Note events (so that you don't need to change your program while testing different values). Check that you can control each individual bit of the address and data lines, and that there are no interdependencies. E.g. if it turns out, that the gate flag (D0) doesn't work reliable, then you know that something might be wrong with the SPI transfer routine. It wouldn't explain why this doesn't affect transfers to a 6581, but on such mysterious effects it's always a good idea to ensure the basic infrastructure first. Best Regards, Thorsten.
If you want to modulate all three pitches from a single modulation path, just enable the L/R switches of the direct modulation targets: These are the same switches which are displayed by the Matrix LEDs of the CS The "soft-targets" (Tr1 and Tr2) are only optional for the case that you want to control something else than Pitch, Pulsewidth, Filter or Volume. Best Regards, Thorsten.
Not really - but remote diagnosis is difficult without knowing your hardware setup + software. The effect happened sporadically when a free-running (not synchronized) oscillator was used; conclusion: a) the SID clock shall be generated by the microcontroller b) each write access to a SID register shall be synchronized to the SID clock as described above to avoid timing violations. If the effect always happens, it could also be related to your hardware setup. E.g. defective SIDs, wrong voltage, wrong filter caps. Best Regards, Thorsten.
Yes, this has been resolved in November 2005 (so, almost 9 years ago) with exactly the solution that I described above. Best Regards, Thorsten.
I've updated the MIDIbox SID Panel, so that it works with the latest Ctrlr version. Download links can be found in the first post of this thread: Best Regards, Thorsten.
I've updated the MIDIbox FM Panel, so that it works with the latest Ctrlr version. Download links can be found in the first post of this thread: Best Regards, Thorsten.
The shift registers (to which the encoders are connected) are scanned each mS. Higher scan rates don't make a difference for encoders with up to 100 pulses per rotation. Here is btw. a tutorial for the encoder usage in MIOS32: http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F014_enc_relative%2F And here is an older PIC ASM based solution, which might help you to understand the migration from ASM to C ;-) -> http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fmios%2Fmios_enc.inc Best Regards, Thorsten.
Yes, the numbers are documented here: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Finclude%2Fmios32%2Fmios32_midi.h search for mios32_midi_port_t In the MBSEQ_GC.V4 file you can either enter them in decimal or hexadecimal format. Best Regards, Thorsten.
Hi, the source code can be found under: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fmios32%2Fcommon%2Fmios32_enc.c It works with polling, interrupts are no option when encoders are scanned via serial registers. Best Regards, Thorsten.
Hi Lars, it would be very difficult (and the wrong way) to implement additional encoder functions for GPIOs. They consume more CPU time than scanning the SRIOs (might sound strange, but the standard scan via SPI in background results into a better overall-performance) Only possibility that I see is to explain you how to modify the firmware for your particular use case. But I don't really want to provide a generic (user-configurable) solution. Alternatively buy a 74HC165 @Reichelt for 0.30 EUR... Best Regards, Thorsten.
