doc
Frequent Writer
    1,079
Everything posted by doc
  1. Nice Boxes, respect to both !
  2. ... hope so...
  3. >>MCLR - 4.3V steady, with or without MCLR Checked in ICProg If I'm right, the voltage should much higher there (about 13.7V). Looks like your JDM is faulty. Doc
  4. without Bikini :-[
  5. Are you sure about the "1047"? On my C64 on the rectifier is +BA20B0C- printed. You can use this rectifier, too. You also can use 4 Diodes 1N4002 or 1N4007. Doc
  6. Hallo Michael, die MB+ Box ist wirklich etwas "out-of-fashion", wenn du dir die ganzen schönen MIOS Projekte ansiehst ... Natürlich funktioniert sie. Der F77-20P funktioniert auch. Zur Steuerung ohne Display kann ich Dir leider nicht viel berichten, da ich es nie versucht habe. Sicherlich wissen andere mehr .... ;) Vereinfacht ausgedrückt: Du kannst den Potis und Knöpfen Deiner Box bestimmte MIDI-Befehle zuordnen, die die Box dann ausführt. Es ist also eher anders herum. Nicht der Computer steuert die Box, sondern die Box steuert den Computer. (Vermutlich Ansichtssache...) Gruß Doc
  7. Sure you'll need another core. 128 DIN is the maximum, I think. Perhaps TK can give you advice on the layer problem. Doc
  8. Hi, a good mixer is not always hard & expensive to build. It depends strongly on what you want (or expect). There are a lot of DIY resources with audio projects. Just take a look at www.ePanorama.net, especially on the following links (mixer): http://www.epanorama.net/links/audiocircuits.html#mixer There you can find a lot of projects. I built a big analog modular mixer several years ago. It was a project called "ESP Audio pages". I don't find the link now. Just surf a little in ePanorama.net . Hope this helps Doc
  9. Hi, I think 2.5mm is not enough. I would say a 3mm minimum if its done in aluminium. doc
  10. Hello MrMucicman, thank you for your comment. yes I know (now) that only one controller is supported. But in a future release of cubase it will be supported. (Don't want to drill again in the near future... ;D) Doc
  11. Not very much information .... Please try the MIDI-Troubleshoot-Guide first, Do it step by step (even if some issues make no sense to you). Hope this helps Doc
  12. James Blond ;D :P
  13. Thank you very much Pearl, this explanation was very helpful. In fact I already have the hardware, I build the whole box with 16 Faders. Hoping that someday Cubase is supporting the 8 extension Faders. Until that greatful day I have 2 Boxes in One !?. - don't mind me much. ;D
  14. If I get you right, you want to switch a audio Input signal to two outs via MIDI ? This can be done via a MIDI Box Concept near the MIDIO128 concept on the ucapps pages. You have to use a relais to switch between the audio outs. The relais is then controlled via the Core (via DOUT) and the MIOS Software (or simply with a button). Surely a lot of stuff just to switch ONE Audio port on 2 outs. But you asked ... DOC
  15. Thank you very much, always ready to learn something new! 8) DOC
  16. Hey D2k, what is a "uberl33t" LC ??? Yes I know, that the ledrings can be use. But I thought it is a good idea building both into the case. Who knows what tomorrow comes ... ::) doc
  17. Thank you for the tip. The screw holes must go away there I know. For this I have to change the PCB Layouts again . ;D Doc
  18. Hi everybody, by using some sparetime, I want you to have a look at my "working" layout of my MidiboxLc. The Box will be used with Cubase and I "borrowed" a lot of things from the Mackie Controller and from Axels Midibox of the year. It's not the final version but something near to it. I just put the link here because of the filesize (about 500k). The image is quite noisy because of the high compression (the original file has 30 MB). The original size is 1000 x 440 mm. Any comments are welcome ;D http://www.systemhaus-schneider.de/doc/frontplatte3.jpg Doc
  19. Nochn Versuch .... ;) Stimmt die Device ID des PIC mit der ge-"perlt"-en Device ID überein ? (Sorry, kann auch nur raten ...) Gruß Doc
  20. Hi, hast Du daran gedacht, dass Du den SysEx Upload innerhalb von 2 Sekunden nach dem Einschalten des Core starten musst ? (Nur für MIOS) Gruß Doc
  21. Hi, the spacing is (just like mentioned before) 2,54 mm or 0,1 inch. But be careful. For example: A switch is mounted on the pcb. Look where the shaft is. Dependining on how you mount it the space can be 1,27 mm or 0,05 inch ! My tip: Plug the components on your vectorboard without soldering them an then count the "whole" and the "half" holes on your design. Then you can measure the exact inch value for mounting. If you layout your design with the pc, print it out and test it before making the panel ! Hope this helps you Doc
  22. Hello Steven_c, i have looked at Axels Box. But he is using it for logic, I think. My problem is, I don't know exactly wich functions I can leave out (without missing them later ...) on the second one. 8) On the cubase layout you have 8 Buttons for Fader groups (which are controlling 8 Faders each, if I understood the manual right). What is happening now, if I build 2x8 Fader Groups. Am I able to control 16 groups with each 16 Faders or not ??? -or shall I leave it to 8 Fader groups. But can these fader groups then control 16 fader ? You see - a lot of questions by now. Thats why I thougt, I first build a release with a lot of more knobs & leds I'll need. Then I can make a new layout after finding out what is possible or not. Don't know if I'm right. Doc I bought Cubase SL but I haven't installed it yet. I want to get my box ready first. I know this isn't a quite good way. But somewhere I have to start...
  23. Thank you, I mean Cubase SL (for the moment...SX perhaps later). I think, if noone knew it better, I build both units in one case. Then I can test it and if it's working I can change the frontpanel again (hard work ... but if theres no other way). Doc
  24. Hello everybody, I'm planing/building a midibox lc like a mackie Universal control with cubase. The pcbs are all ready and now I'm on the "layout" (2xCore, 8xDINx4, 8xDOUTx4, 2xMF, etc...) But 8 Faders are not enough, so I planned it with 16 Faders. Now I have several questions: - Shall I build 2 identical 8 Fader Boxes or can I "combine" both boxes (like the"Midibox of the Year"). If so, shall I use (for example) 16 Buttons for the Fader control section instead of 8 and can the software manage this ? On the other hand: Is it possible to drive 2 MCU clones (on different midi ports of course) on Cubase ? Any suggestions are very welcome ??? ::) Thank you Doc
  25. New York ?????? ...... where is "New York" ....... ? (Go back to your soldering irons ! - Much more effective than a discussion about a logo, isn't it ?) ;) DOC
