1,081 -
Everything posted by Twin-X
Oeps ik was in de war met Tantaal condensatoren. Monolithic zijn gewoon keramische condensatoren. Deze zijn alleen niet van die ronde schijfjes maar van die plastic druppel achtige condensatoren. Sorry!!
Programming Platforn / Old PIC info / Can of Worms
Twin-X replied to Durisian's topic in MIDIbox Documentation Project
Stop!!! Please do not do anything before i update the wiki software. I tell my self every day that i will update it but i constantly have excusses for not doing it. Currently we are lucky it still works with this version of smf. However the wiki is outdated and really needs a new version (also better for the plugins) Keep on dicussing on how it will look etc but do not take actions like this (it's a huge transformation) yet until i am done. I will have a look into it in the upcomming week for the upgrade. And i am pretty sure i end up by putting back a backup. :( -
Amazing you have some real talent. Those sogs are great. The vids makes it even better
Dan moet je ze juist hebben! Ik zal ze in het reichelt pakket knallen voor je ok.
enth you are from the netherlands right? You could be in luck. 200 you say? I will ask nils if he can add 200 extra on my order. See the dutch forum part. We have a little groupbuy going on there.
Wie kan me helpen aan twee onderdelen voor m'm MB-6582?
Twin-X replied to renepela's topic in Nederlands
reichelt elektronik GmbH & Co. KG Elektronikring 1 26452 Sande Tel.: 04422 / 955-333 Fax: 04422 / 955-111 www.reichelt.de Datum: 07.Oct.2008 Warenkorb Artikel-Nr. Bezeichnung WG Menge Einzelpreis Gesamtpreis -------------------------------------------------------------------------------- SPL 32 IC-Fassung, 32-polig, einreihig, RM 2,54, gerade 1 4 0,48 € 1,92 € PFL 16 Pfostenbuchse, 16-polig, mit Zugentlastung 1 8 0,13 € 1,04 € MABP 5S DIN-Buchse, 5-polig, halbrund, Printausführung 1 8 0,36 € 2,88 € D-SUB BU 25US D-SUB-Buchse, 25-polig, gewinkelt, RM 7,2 1 4 0,32 € 1,28 € RK09L12B-LOG100K ALPS Drehpoti. logarithm., 6mm, stereo, 100K 1 4 2,10 € 8,40 € P6S-LOG 470K Drehpoti. logarithm. 6mm, stereo 470 K-Ohm 1 8 1,40 € 11,20 € PFL 6 Pfostenbuchse, 6-polig, mit Zugentlastung 1 2 0,25 € 0,50 € P6S-LOG 100K Drehpoti. logarithm. 6mm, stereo 100 K-Ohm 1 20 1,40 € 28,00 € TASTER 3301D Kurzhubtaster 6x6mm, Höhe: 12,5mm, 12V, vert. 1 300 0,12 € 35,70 € 6N 138 OPTOKOPPLER 1 4 0,50 € 2,01 € -------------------------------------------------------------------------------- Warenwert 92,93 € ============ Zuzüglich Versandkosten für ca. 0,6 kg bei Zahlung per Nachnahme 8,06 € Zuzüglich Versandkosten für ca. 0,6 kg bei Zahlung per Bankeinzug/Re/Vorkasse 5,60 € Bei Versand ins Ausland bitten wir um Kontaktaufnahme. Alle Preise in Euro inklusive gesetzl. Mehrwertsteuer. Mit freundlichen Grüßen Ihr Reichelt Elektronik Team -------------------------------------------------------------------------------- Volksbank Jever e. G. BLZ 282 622 54 Kto. 50 44 55 00 00 IBAN: DE10 2826 2254 5044 5500 00 SWIFT: BIC: GENODEF1JEV Sparkasse Wilhelmshaven BLZ 282 501 10 Kto. 00 03 81 61 62 IBAN: DE36 2825 0110 0003 8161 62 SWIFT: BIC: BRLADE21WHV Handelsregister: HRA 200654 Oldenburg USt-IdNr.: DE 259817039 WEEE-Nr.: DE 58715331 Persönlich haftende Gesellschafterin: reichelt elektronik Verwaltungs-GmbH Sitz Sande - Amtsgericht Oldenburg, HRB 130281 - Geschäftsführerin: Angelika Reichelt Ok een beetje lelijke copy paste maar ik had niks beters. Deze lijst heb ik aan nils doorgegeven. Als we 50 euro meer hadden dan had ik het direct kunnen bestellen. -
Deze hebben een plus en een min toch? Dus die kun je niet gebruiken. Voor het filter gedeelte heb ik nog van die 1% 22nf dingen liggen hoeveel moet je er ook alweer hebben voor je sid?
Regeling met betaling komt wel. De verzend kosten worden gedeeld en de verzending binnen nederland zijn voor jullie eigen rekening. -
Ok zondag plaats ik de bestelling dus je kunt nog blijven toevoegen. Maar tot zondag dan gaat ie er namelijk echt uit. Die potmeters 100k 470k of 500k dual gang maakt niks uit. Om een beetje in lijn te blijven zijn de 470k het beste. nILS doet de bestelling voor me (na eerst heel irritant gedaan te hebben hahahaha) -
Hello Pierre you must do this;
Komt voor mekaar Alex. Ik heb ze zelf ook nodig namelijk ;) -
Geen probleem rvooh. Staat erbij. -
Dreamer dank je voor de toevoeging. Woensdag avond laat ik jullie weten hoe of wat. (ga er maar van uit dat het goed zit) -
Not fair Thorsten ;)
Genoteerd. Ik zal nog even onderzoek doen naar die dual gang want nu begin ik te twijvelen zal Wilba hier even op aan spreken. Er is in principe zat ruimte achterin. Maar naar beneden (war de pootjes zitten kan het wat krap worden maar dat moet wel gaan lukken denk ik.) Ik wil nog even wachten op de bestelling van dreamer als hij wil meedoen. Waarschijnlijk doet MTE nILS of TK de bestelling voor jullie. Maar dat laat ik weten zodra de lijst compleet is. -
Als jullie iets van reichelt willen dan kan ik dat ergelen. Helft van de mebers hier is duits. Ik heb mijn tact switches ook van reichelt. Heel goedkoop. Helaas is er voor nederlanders een minumum van 150 euro ingesteld. Dus daarom als je zou willen moet ik dit door een duitse member laten verzorgen (wat geen enkel punt is om te doen voor deze keer) Die dualgangs heb ik niet in mijn sid? Ik heb gewone pots van 50k? Werkt uitstekend. Maar reighelt zal die dualgans vast wel hebben. Beetje zoeken en je moet ze wel kunnen vinden. Die tact's part number heb ik wel eens gepost hier op het forum dus die vinden we zo terug. 500k dual gang : P6S-LIN 47K 13mm tact (heb ik zelf ook) : TASTER 3301D -
try http://www.hidemyass.com
I installed mibbit since it is not firewall blocked? Works perfectly from work it uses port 80?
And i bet 98% is not build yet!
People who are allergic to beans - can they be trusted?
Twin-X replied to DavidBanner's topic in Miscellaneous
Is he called Jack ? -
I really really like mibbit but i am trying to find out how secure i can get it.
Buy it! I sold it for a RS7000 Sold my RS7000 for a MPC4000 MPC4000 collecting dust. Should have sticked to my rmx1 ;) Great sequencer! Internal sounds are ok.
I have no idea???? Grrr i hate SMF this software sucks!. I preffer vbulletin.
Sound on Sound dit not mention 1 word that the controllers guts are from midibox :( How LAME
Hhaha don't pay attention to them. Please continue i like the way it is going.
