nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. Yes - absolutely. Actually, stryd, you already know as we're working on it right now :D
  2. As far as I know, there's no Tap-Button yet. But what I can tell you for sure is, that if it's really not there, it's definitely possible to implement that feature :D
  3. Well the chance that they don't work at all is pretty low. The chance that the filters are busted is fairly high - but that's an easy thing to find out once you have your mbSID to test the SIDs in ;-)
  4. nILS
    *whack*
    [Wilba] 3:35 pm: Ok I'm buying some big caps on ebay [Wilba] 3:36 pm: 3300uF 100V [Wilba] 3:36 pm: how can I test if they're not counterfeits? [Wilba] 3:36 pm: like that picture on the forum with a smaller cap inside a big shell [ultra] 3:36 pm: charge them up and hit them with a screwdriver [Wilba] 3:36 pm: hit as in whack?
  5. How about posting your source code so we might be able to see what's wrong instead of guessing?
  6. I'm a very visual person. And I just can picture that. :D
  7. Pascal, ich bin jetzt wieder reichlich im Chat - schau einfach mal vorbei, dann richten wir die LEDs auch noch :D
  8. english: red = right german: rot = rechts So, all the important languages are covered. Let's look at the unimportant one ;-) dutch: rood = recht french: rouge = dRoite italian: rossa = destRa portuguese: veRmelha = diReita spanish: roja = deRecha russian: ?P????? ?P??? japanese: ?? = ?? works in almost any language ;-)
  9. You're gonna copy-paste that in every thread now? ;-)
  10. Exactly - thanks for pointing it out stryd ;-)
  11. Time for a new "Fastest Newb" Award ;-) Sehr schick geworden und das in so kurzer Zeit - Gratulation!
  12. Now that's a nice first post! Welcome aboard and thanks for sharing! :D
  13. Mmmm - blue stain GOOOD! Looks nice! I really like the DIY case :D
  14. If you really wanna go switching PSU - you could at least do so really cheap: http://www.pollin.de/shop/detail.php?pg=NQ==&a=NTc2OTQ2OTk= ;) edit: evil typo
  15. Hehe, I call it being insipred by the work of others. Which goes for virtually anyone around here, including you, sineSurfer ;-) Looks good - build it!
  16. Um... -> http://www.midibox.org/forum/index.php/topic,10438.0.html Please check if what you are about to post has already been posted ;-)
  17. ...which is a horrible idea ;-)
  18. This might help you out: http://www.midibox.org/forum/index.php/topic,5086.0.html http://www.midibox.org/forum/index.php/topic,9698.0.html
  19. Yes, it is possible, it just involves a lot more programming. You could even build a tiny button or LED matrix. With the 8 pins of J5 you could have a 4x4 Matrix for instance, or a 3x3 matrix and 2 LEDs or a 3x2 matrix and 3 LEDs [...] You can do what you want with most of the input/output pins, it's just a matter of programming.
  20. To be honest: That's enough info for me ;-) If I were TK (which is kinda hard to imagine), I'm not sure if would want to go through the hassle of writing a fun to read little story when I could go spend my free time working on creating more history :D What I'm trying to say is: Do some research, check the google cache for old versions of ucapps and write up some history - if there's a pretty good base with a lot of info there already I think a lot more people will be tempted to contribute.
  21. Which you do or don't? I only noticed you sell 6582s so far ;-)
  22. Welcome aboard! Nice to hear you got this far without having to ask any question ;-) #define DEFAULT_EXT_CLK_PULSEWIDTH 19 should give you a 10ms pulsewidth, yes. Did you do the calibration and setup as described on ucapps.de? Sorry that I can't give you an in-depth technical answer, but I believe measuring a 10ms pulse signal with a multimeter will not lead to any usable results as the signal is not constant enough. Did you measure the output from you s&h the same way?
  23. Whatever you need to do needs to be <= 8. 2 (two pots) + 2 (two buttons) + 2 (one encoder) + 2 (two leds) = 8 so you're good.
  24. Voltage drops as current rises - hook up some LEDs or something else to the adapter and voltage will most likely drop to the desired range.
  25. Looks really nice - but why is that one knob a different color? ;-)
