nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. Welcome aboard Turnthetables! 1) Leave blank, yes 2) If you buy a kit you get all the parts 3) Yes
  2. Ahahaha ;D Good work man!
  3. My favorite in every respect: http://www.thomann.de/de/sony_mdr7506_kopfhoerer.htm
  4. You have 6581s with working filters? *drool*
  5. 10k (A) ---[===]-----+--------------->> OUTPUT | 10k | (B) ---[===]-----+ | 10k | 1k-5k (C) ---[===]-----+-----[===]---. | --- - [/code] Like this, yeah :-)
  6. Let me add to that: If you don't then stfu.
  7. Glad you got it working! Thanks for sharing the answer!
  8. I've already got an expensive wav player (called "Pee Cee") ;-)
  9. 5.7V is a bit too much after the regulater, just as 14V is too much before the regulator. Try to put some load on the circuit (and LED + resistor) and see if the voltage on J1 and J2 drops to acceptable values. If not - get a new wallwart.
  10. *poof*
  11. That means someone built an mbSID with 0.12 SID in it. Hmmmmmm :-)
  12. You can easily leave out the opamp buffer board for testing. Just connect all three outputs via 10k resistors and add a pulldown of 1k-5k from that signal to ground.
  13. Since lemonhorse asked me to take some pics of my AY and I miserably failed to do that so far, here's a little compensation :-) Little mbAY-3-8912 Demo Drums are VSTi, added a some reverb and delay to hide the noise of my soundcard ;-)
  14. Yes, there's good news - the target is reached, the bulk order will happen. At the moment, the prototype boards are being made and will be thouroughly tested. After that, there'll be a "real" sign-up list on the WIKI - stay tuned! ;D
  15. http://www.midibox.org/forum/index.php/topic,11957.0/topicseen.html
  16. 1) dual-gang 500k pots 2) J25 (~9V-11V DC, for connecting to fan). 3) DB25 4) reichelt, conrad. Hey, how cool is that - all of the answers are right here: http://www.midibox.org/dokuwiki/wilba_mb_6582_base_pcb_construction_guide
  17. Work firewall?
  18. No.
  19. Possible.
  20. Schau mal rasteri's scratch controller an - der macht im Prinzip genau das ;-)
  21. beans good steak better
  22. Beautiful!
  23. nILS
    Midi Floorboard
    Aloa Enners und willkommen an Board ;) Das ist eine der schönsten Arten sich vorzustellen! Viel Spass mit Deinem Floorboard und den sicher noch folgenden Midiboxen :D
