Screaming_Rabbit
Frequent Writer-
1,431 -
Everything posted by Screaming_Rabbit
midibox fm chip bulk order 1 now finished
Screaming_Rabbit replied to airmailed's topic in Parts Questions
Hey Adam THANKS A LOT again for your efforts! Greets, Roger -
Ooops... yes, I mixed it up :-X ... but I'm also not into the SEQ ;D I have VISIO from at work as well ;). But where did you get those buttons from, I don't have those in my standart archive...or are those selfmade templates? Do you have a good link to download those or is it possible, that you mail them to me (if they work with VISIO2000... I think it should)? Greets, Roger
You could go from your main core with the buttons and the faders etc. out of the MIDI Through to your second core with the LCD. The MIDI Out of the core with the LCD doesn't have to be connected. - I think this should work ??? Greets, Roger
... looks cool! I can't say anything about the ergonomics, since I'm not interrested (for now) in the SID. What Software did you use for the drawing? Greets, Roger
Hello Taylor 2.) As far as I know, there are max. 128 Digital INs and 128 OUTs per core which MIOS can handle. But the problem will be, when you specify your controller as an LC- or Mackie-Clone in your host, the host software won't let you configure any additional functions because the functions are already specified in the protocol (please anybody correct me, if I got this wrong). I'm working with Sequoia V8 which let's me connect a maximum of 4 hardware controllers. So what I could do, is: Connect 3 LCs (1 master and 2 extensions) to have a 24 fader setup. For the 4th controller I can connect a MidiBox128 (for example) and adjust additional functions in "generic mode" 4.) Sorry... my experience as a sound engineer tells me: Don't do it ;)... but I don't have enough electronic background to give you any advice about it would work or not :-X 5.) I'm shure there is a possibility to "recalculate" this. I'll work on this next. Stick to this topic: http://69.56.171.55/~midibox/forum/index.php?topic=3179.0 Greets, Roger
Hey Taylor 1.) The number of 8-Fader modules is defined by your host software. I don't know of a software handling more than 4 units (32 faders). 2.) The functions you can lay on buttons is defined by the LC-protocol of the host software 3.) somebody else has to answer this. I think, you can use any display you can drive by MIOS, as long as you have a driver or you write one 4.) I think touch sensitive buttons are not a step ahead. I love to have a "click" for activating a function by a button. While mixing, you often put a finger on a button long before you need it and as soon as the time for activation comes, you finally press the button. With touch sensitive buttons you propably often activate a function without wanting it. 5.) There is no audio (digital nor analog) going through your LC. If you want an analog meter, you have to connect it to an analog out of your DA coverter. The LEDs in the dBFS meters of the LC are activated by MIDI messages from your host software. Greets, Roger
Standard Keyboard Switches for MidiBOX SID buttons ?
Screaming_Rabbit replied to ohmstudiste's topic in Parts Questions
http://69.56.171.55/~midibox/forum/index.php?topic=3651.0 Greets, Roger -
Touchpad for surround control
Screaming_Rabbit replied to Screaming_Rabbit's topic in Design Concepts
... just browsed through a link from "atomsize" and found this... http://www.goldmine-elec-products.com/prodinfo.asp?number=G1283&variation=&aitem=1&mitem=36 Greets, Roger -
... habe einen Link gefunden, in welchem mehr Informationen sowie ein Link zum Datenblatt (im 1. Posting) vorhanden ist. http://forum.lcdinfo.com/viewtopic.php?t=586&postdays=0&postorder=asc&start=0 Greets, Roger
Hey Jack Happy Skiing... und bring die Beine an einem Stück zurück! ... ist 5.43€/Stk. ... gehört sie eben nicht ;), ... somit kämen nur 7.6% MwSt der Schweiz dazu. + Versand, welcher bei 100 Stk. nicht sehr ins Gewicht fallen wird. Greets, Roger
Kuck-kuck??? ... kein Interesse, kein Kommentar? Greets, Roger
Hallo zusammen... bin zurück aus den Ferien :P Ich habe vor meinen Ferien hier eine Preisanfrage für eine grössere Bestellung gemacht: http://www.jelu.se/shop/product_info.php?products_id=54 Antwort: Was meint ihr? Der Vorteil wäre, dass man relativ günstig ein Stück zum Testen bestellen könnte und wir dann sicher wären, dass das Ding auch im Verbund mit MidiBox funktionieren wird. Ich nimm an, dass auch der Geldtransfer problemos ablaufen würde (immer noch Kopfschüttel, dass die HSBC dies zwei mal nicht hingekriegt hat) >:( Die Sammelbestellung würde ich organisieren. Greets, Roger
. .also ich nehm auch gern auch ein paar, hat einfach so ausgesehen das die beschaffung ein bischen schwierig und unsicher ist ... nun, das sieht nicht nur so aus ;) Greets, Roger
Hey noskule ... die Displays sind so billig, weil sie weltweit in tausenden von Handies eingebaut wurden. Die Entwicklungskosten waren also lange gedeckt und es zählten nur noch die effektiven Produktionskosten. Neue Handies haben fast alle color-displays. - Ob die von MIOS angesteuert werden können? Dass die Displays später nicht mehr erhältlich sein werden, finde ich kein Problem, da es sich bei unseren Kisten nicht um Serienanfertigungen handelt. Für diese paar $ kaufst Du einfach ein paar Ersatz-Displays mit und Dein Projekt ist gesichert ;). Der Treiber besteht auch schon... muss also auch nicht bedacht werden, ob es sich lohnt für ein "sterbendes" Display den Aufwand zu betreiben. Was meinst Du? Greets, Roger
Ich wollte letzte Woche eigentlich einen neuen Zahlungs-Versuch starten, wurde aber durch folgenden Artikel vorsichtig bzw. unsicher: http://69.56.171.55/~midibox/forum/index.php?topic=3835.0 ... habe dann nach einem Datenblatt verlangt. - Folgende Zeilen wurden geantwortet: ::) :-\ Ich bin ab Montag 2 Wochen in den Ferien und werde dann entscheiden, ob ich das Risiko eingehen und die erneute Überweisung dann tätigen werde. Falls Jemand zu oben erwähntem Beitrag weitere Informationen und Inputs hat. - Bitte posten! Greets, Roger
Hey Noskule Um die Forum-Beiträge nicht durcheinader zu bringe, habe ich Dir im ursprünglichen Beitrag geantwortet. Greets, Roger
MidiBox LC: Resolution of meter level
Screaming_Rabbit replied to dominik's topic in MIOS programming (Assembler)
... I didn't state, that there aint enough pins. But the OS "MIOS" allows you only to configure 128 INs and 128 OUTs (per Core). Greets, Roger -
... max. supported outs by MIOS: 128. If you want LEDs for indication of all the other functions you would need more than one "core", when using more than 11 LEDs. Greets, Roger -
Switzerland 08:30 local time, 2MBit DSL 100-250kb/s Greets, Roger
1. http://www.ucapps.de/mbhp/mbhp_multi_bankstick.gif Greets, Roger
What do you mean with that? Which additional (compared with?) pins? Does it look like this one? http://www.myplace.nu/mp3/images/nokia_lcd_large.jpg Greets, Roger
Danke für die Tips Weiss man eigentlich, ob die Jitter-Probleme von der Motoren Stromversorgung (12V) oder von der 5V Versorgung kommen bzw. kamen? Grüsse, Roger
Ich glaube die verschiedenen Forums-Beiträge betreffend Problemen mit Schalt-Netzteilen haben die allgemeine Verunsicherung in Sache PSU zu MidiBox LC ausgelöst (... wie es auch mich stark verunsichert hat, sonst hätte ich schon längst entschieden ein PC-Netzteil in's Silent-Rack einzubauen). Wenn man die Preise für fertige Transistor regulierte Fertig-Netzteile anschaut, ist verständlich, dass ein mancher solch ein PSU selber bauen möchte :) Greets, Roger PS: Habe mir nun ein Buch für den PSU-Selbstbau zugelegt.
