lukas412
Programmer
    269
    2
Everything posted by lukas412
  1. Took a closer look at this today. Seems that some drum track types do not work. The only two that work for me are: 64/2*64 128/2*128 In the other track types the VelN and VelA do not change the value. thanks, Luke
  2. Great ideas. Number 2 makes total sense to me if its possible.
  3. Hmm this only seems to occur on existing tracks. If i switch types and init it works. Also affects my preset tracks. Luke
  4. In v4.084 in drum mode, encoders for VelN VelA no longer function. Please let me know if there is any other info I can provide. thanks, Luke
  5. I think its: BD = bass drum SD = snare drum CH = closed hat PH = pedal hat OH = open hat MA = maracas CP = clap CY = cymbal LT = low tom MT = mid tom HT = high tom RS = rim shot CB = cowbell I believe they are taken from the general midi percussion. Luke
  6. lukas412
    Lemur BLM
    I have used the cck like this before with out issues. As soon as I get a chance I'll make sure it's still working.
  7. This is an excellent response, I'd say very accurate. Also a very satisfying experience.
  8. Very nice, so much diy!
  9. If I understand correctly, you could use the copy/paste functionality, or you could use the all function to set all of the steps in a pattern to be the same note/length/vel/etc. Then turn them on/off as needed. Luke
  10. This probably doesn't specifically help you, but I have been using my seq with an s3200xl and an s5000 with out any issues. I assume the s1000 is very similar so shouldnt need any special treatment. Luke
  11. Wow those look fantastic. Do they seem any brighter to you? They look way brighter than my current LCD's.
  12. Not sure how old your version was before update but the All button did change not too long ago. From the manual: NEW since v4.074: if the ALL button is active (regardless if pushed or not), and the encoder of an unselected step is moved, the editor will generate a ramp between the selected step and the moved encoder. This feature has been borrowed from Sequentix Cirklon - thanks for the inspiration! :-) Takes a minute to get used to but crazy powerful. Luke
  13. You are correct. I have yet to use it very much on normal tracks so I did not notice. Only an issue with the drum tracks. thanks, Luke
  14. Also thank you!
  15. I just tried with a track Drum (2*64/256) with Vel and Roll. I get different level accents but they do not change when I adjust the levels of VelN and VelA then regenerate a pattern, only the original two values are used. For example if you set VelN to 10 and VelA to 50, do you see the values get changed in the generated sequence? Mine just stays at the default of 100, 127. thanks, Luke
  16. Something else I noticed is that the controls for VelN and VelA in the Euclidian generator do not seem to do anything. Normal and accented always get put in as their default values. thanks, Luke
  17. I noticed that when using song/phrase mode for mutes that if you have individual drums or layers muted that they do not get unmuted when a song position unmutes an entire track. I can see the usefulness of both but in my case using song positions to reset a track its kind of cumbersome. Would it be possible to have a flag or another song position type to unmute all layers? thanks, Luke
  18. The feature works great! Even better than what I was hoping for. Having the actual note value on screen as well as the quantized value is perfect. Even noticed it updating in real time as I was modulating the global scale via the internal bus. THANKS!!! Luke
  19. Nice avatar!
  20. Ah I was wondering about this actually. I was playing around with the BLM and it seemed to always be forcing to scale even if the track I was using was set to OFF. I may have had another issue going on but this may be related. Ill dig around some more tonight. Luke
  21. Would it be possible to get a config param that would when in Force To Scale mode, show the actual note that the sequencer has been quantized to? I can see how this would be tricky and not the expected behavior in some situations. So an option would be nice, but I can see how this would be a lot of work. thanks, Luke
  22. Confirmed Fixed! Thanks! I will see if i can write a better report for the velocity issue. Thanks again, Luke
  23. No problem TK. One other small thing I have noticed, and not related to this release. In the euclid generator for drums (and maybe notes too) I see strange behavior with the velocity levels for normal and accent. It seems that sometimes, perhaps the first time i try it will use the values, but after that it just seems to ignore them using the initial setting again. I can't quite figure out what it's doing yet. I have noticed it for sometime but am just now digging into what its doing. Thanks, Luke
  24. Hello TK, I am noticing some crashing in version 4.082 When the sequencer is playing and you switch Sessions I am consistently getting a crash. Midi hangs and the MB freezes. Switching back to v4.080_pre2 the crashing goes away. Please let me know if there is any info I can provide. thanks, Luke
