Altitude
    1,184
    30
Everything posted by Altitude
  1. Just for everyones info, the jaytronics etching tank is $34 and includes a 1.5 gallon tank, board holder, bubbler, and heater. just picked on up and it is a dream come true (etches in about 5 minutes)
  2. The sockets i used already have the normally closed, steal from mix feature built in but I dont think the jacks would work the way you described. With a suitable jack, i'm sure this would work though
  3. Steve, They are switchcraft sockets (RN111PC and RN112APC). they were the only board mounted normally-closed sockets i could find at Mouser. To make it simple, i used the normally open version of it for the L/R outs (i'll send u my lbr) I'm not sue what a cue function would give u since the SID outputs are hardwired into the mixer
  4. So are there any potential pitfalls or problems with powering SID boards from a common power rail like the Core's in the optimized PSU schematic? I have to use a different PSU anyway (would TK's OPL3 PSU work here?) since I need the +/-12 V. Would the procedure be the same as for the cores? (Meaning pull the big cap and rectifier and then just short the regulator pins?). Also, for adding the 5V to the psu: is it better to branch everything after the rectifier, use 3 rectifiers, or the simply run the 5V regulator off of the +12 regulators output? thnks raph
  5. I will as soon as I get the pot board finished. I envisioned this thing as being all single sided so on the pot board u will install DIL header upside down so the long ends come out the back and the plastic riser keeps it in place on the front. This is still in the prototype stage so i would like to make sure everything works before I release all the files. I should have my new etching tank and parts this week.
  6. definitely. I should be etching boards this week so hopefully I'll have everything test soon
  7. Ok, here is the board layout. I decided to go with a DIL header since 24 wires does not seem to be a neat way of wiring the pots. Note that the TL084 needs a +/- 12 V input. I will have panel mounted pots on a 1 to 1 connection with the mixer board header ready shortly spaced for a 2u rack
  8. You cant upload mios 1.9 with the 1.1 bootloader, it will need to be updated to 1.2 (instructions are in the zip in the downloads section.) This may be a chicken or the egg type deal so I would at least try to bring it to the current version to make sure thats not the problem you are experiencing (I went through the same thing where it would just send the request no matter what i did to it) If your getting a request sysex string, then you should be good to go. You can also try just sending an older mios to see if thats the problem
  9. That means its correctly installed. What bootloader version are you running? If it is 1.1, you have to update it to 1.2 for MIOS 1.9 to work properly, that may be the problem you are having
  10. what r u powering with?
  11. Sorry to cpr this old thread, but what determines what kind of cap and how many to smooth the voltage before and after the regulator? I have been researching various linear PSU designs and it seems that everyones is very similar (rectifier -> smoothing caps -> regulator -> more smoothing caps) but the number, type, and values of the caps all vary considerably. Ray Wilsons uses 4 polar 4700 uF with a 1uF polar on the end. Yours (Smash) has one lytic and one non-polar one each side of the regulator while Seb Francis' bench PSU has one polar and one non-polar plus a load resistor and a reverse protecting diode. So I guess my question is what exactly is the theory behind the different cap types? My other related question is a little more specific to what I'm working on which is a +12/-12/+5 PSU from a 2 amp center tapped 25VAC transformer. Would it make sense to use a second rectifier behind the first to drop the voltage further before going into the 5V regulator or just driving it with the output of the main rectifier (12.5 VAC) directly the way to go?
  12. I would just use a 15V one and let the regulators do the work
  13. I do think they are SMT LEDs. be warned though, when you take apart a LCD getting it aligned and put back together is a nightmare, but then again at Smash's insane crazy low prices, its worth a shot
  14. Done: http://no-ho.com/mbhp_doutx4_v1.pdf http://no-ho.com/mbhp_dinx4_v2.pdf http://no-ho.com/8xBankstick_layout.pdf http://no-ho.com/8xBankstick.pdf
  15. Update. It does look like my brightness control is working but it is a TINY adjustment (barely visible, thats why i thought it didnt work). Shorting R7 does improve it to acceptable levels though. Will do some stress testing today to see how hot the whole deal becomes
  16. check your output voltage from the regulator and see if it dipped below 12V, IIRC there is usually a drop across the regulator so 12VDC may not cut it if the regulator is stuffed
  17. I'm sure it would work but there would need to be some code modification required
  18. Sounds like your PSU is on the low side. R u using a 6581 or 8580?
  19. So here a design for a panning mono to stereo mixer intended for a 4xSID box based on the TL084. It is pretty much an duplicate of Ray Wilsons MFOS (http://www.musicfromouterspace.com) mixer with the addition of normally closed mono jacks to steal the mono outputs from the stereo mix when a cable is connected. Each channel has its own level and pan controls and the whole deal is driven with +/- 12VDC. I will be building the prototype in the next couple of days so I should have brd's/partlists available shortly. Any comments are welcome. Cheers. Alt
  20. So what were ppls results? This looks like exactly what i'm looking for since i'm working on a 4 channel panning mixer for my 4xSID and +/- 12 V rails are what i need
  21. for audio cables, roll your own. Stateside, Mogami and Canare cable is no more than $1.50/meter and connectors are fairly cheap (1-3$). I'm sure that is the same case in Europe
  22. http://ucapps.de/mbhp/mbhp_core_v3.pdf or for the older R3 smash boards http://ucapps.de/mbhp/mbhp_core_v2.pdf
  23. *fixed links
  24. See the wiring diagram located on the Control surface page: http://ucapps.de/midibox_sid_cs.html or http://ucapps.de/midibox_sid_cs/2x16_enc.pdf U can change the mappings of what goes where but it would probably just be easier to do as is
  25. mclr is pin 1. look at the schematic and everything will be clear (ie those are the "names" of the pins)
