1,240 -
28
Everything posted by Smithy
I wouldn't count on them coming back anytime soon just fyi. Logan who was running the shop for John has left to pursue his own business - Low-Gain Electronics. John was too busy to manage it himself so unless he comes back or finds a replacement to run the shop people will be waiting. Also worth noting that John has not been active on the forum since April 2018.
Beautiful work!
LoopA V2 Introduction, Features & Support Thread
Smithy replied to Hawkeye's topic in MIDIbox User Projects
Edit: On second thought I had problems pushing one or 2 knobs as the heatshrink gets in the way. Best to use sellotape like peter said or some thinner material. I tr ied Peters method of securing the knobs to the shafts of the encoders with Sellotape but I found the tape simply would not stick well to the encoder shafts and sometimes fell down to the bottom causing noise when turning the knobs. So I came up with a more permanent or secure method. I used blue heathrink as you can see in the first pic that was as close to the diameter of the top half or the D shape of the shaft and shrunk them with my hot air station at about 200 degrees taking care not to heat up the encoders too much. Then I slipped on the knobs with some force and they secured quite nicely. Only con really is that more force is needed to get them off again but i'd rather that than having loose knobs getting lost! Hope this is of use to people. -
Lost count! Friday i spent most the day, saturday a half day, Sunday a half day, Monday most of the day, and finished it before lunch on Tuesday. But i take my time with things like this, and encountered a few problems like trying to fit the microcontroller in and cut all the legs! I think i was being overly cautious with cutting those pins as close as possible. -
Here's the time lapse video i recorded of the LoopA. I gave up on the solder paste and hot air method early in the build, as the solder paste I used didnt come with a plunger and my plunger was a bit too narrow. I have officially converted over to drag soldering now and its much faster. When I soldered the Mattias switches the recording stopped as a calendar notification popped up on the phone! Luckily its 99% of it is there! Thanks again to everyone involved, everyone is credited at the end of the video. -
Thansk guys! Yes even a noob like me can reproduce which is a good sign and will hopefully inspire other newbies! ;) By the way, all images have been fixed in my previous posts. I tried the right clicking, "copy image" and pasting from google images which caused the problem. This usually works fine on other sites but not with Community Software forums apparently. -
A wild midiphy LoopA appears! Huge thanks to Andy, Peter and TK for making my dream looper come true! I just need to test MIDI I/O now. -
Here's how the OLED header looks with the rear panel mounted: -
Shhhh! Its a secret! ;) Guys i think the I was sent the wrong sized nuts for the rear acrylic panel where 2 nuts slip into the slots. The nuts have a 3mm height and will not fit. Luckily I have 3mm nuts with a height of about 2.3mm that will do the job nicely. -
Photos aren't the best, I should really use an endoscope! But hopefully you can see it was necessary to trim the back upper corner of that connector. -
I have the row soldered and cut already but ill take a photo so you can draw imaginary lines down to the connector with your eyes! Ill take a photo and upload it at 9am GMT. -
When pushing down the Headers for the OLED I noticed that the top of the 8 pin DIN for the BLM got in the way despite filing off the "nip" as Peter put it. I had to file the corner / back of the connector off at an angle even further so the standard SIL pins would have enough clearance. Maybe my connector is slightly different to the one Peter used in the video? It sure looked the same, as it has the metal tab on front that needed to be filed down. Case goes on tomorrow morning and I should be done! -
Posting this in case I forget it. I couldn't receive a response from the Core using MIOS Studio 2.4.6 which i downloaded about 2 years ago. Using the latest version 2.4.8 allowed the core to respond and I was able to upload the firmware. -
@TK. if you could update the MIDIbox Chat link to the link for the discord server in time it would be great.
Great work. Now we just need to add channels and moderators. With Peter and Andys blessing we could push it on the midiphy facebook page also when its ready. We have quite a following on their already! ;)
Hey flexi! Great to see you back. A discord server for MIDIbox is a great idea! Has so much more features than IRC, now why didn't I think of that!
The trick to maximizing viewers in the tags and concentrating on one particular synth. You have so much stuff that people who are searching for specific sound demos on one synth will probably bypass your videos Pete. Thats my logic anyway.
For some reason the channels cancel each other out, I used an iriver H340 to record that demo, so if you're listening to it on a mono device like a phone speaker you hear nothing!
Be sure to share your patches in the patch thread! I haven't got deep into the MB SID yet but I made 3 patches: Irish Whiskey Driving Bass Strings
The HAARP, a Hardware Advanced Arpeggiator.
Smithy replied to Antichambre's topic in MIDIbox User Projects
Hi Bruno, what CAD software(s) did you use to design the mockups? im currently studying CAD at the moment, Thanks for yout time, Adrian. -
Interesting! How did you find this out Thomasch? Did you open yours up?
Wow, what a great device and what an amazing demo! Congratulations Bruno! I might have to remix that melody of yours too! ;) -
This may be useful for people for powering their music equipment while travelling or for mobile gigs etc... I was quite impressed and hope the company does well. https://www.youtube.com/watch?v=1sbECZ_HQqk
- 1 reply
- 1
A genuine Hakko 936 style tip works wonders over the Chinese clones also, really worth spending the extra money one from my experience.
