latigid on
Frequent Writer
    2,524
    149
  1. latigid on
    help me
    Not enough information, sorry. Can you please be more specific about your problem? Your LCD works correctly? Is it an issue with your soldering in the DOUT chain ?
  2. I've got Cubase 5 on PC. I haven't messed around with the MIDI part of it, but it looks like you can setup specific "MIDI devices" (i.e. one for each synth) where the outgoing datastream can be configured and filtered. pp328 in the Cubase 5 manual.
  3. $100k, good god! LED matrix, anybody?
  4. Nice work! Glad to help
  5. And are any unused inputs on the multiplexers also grounded?
  6. I'd suspect pot wiring. Are both of your pot's outer legs connected? I.e. one to Vs and one to Vd? If the pot is not grounded, you will never get true zero. Probably this is what the Wiki says.
  7. Ich war sagen wird, vergest du nicht Großbuchstaben für Nomen!
  8. Of course, the Omron switches are waaaay too expensive. :) I realise the SMD LEDs would be too short, but then could lower profile (shorter) tact switches be used as well? Or is the idea to mount other components (e.g. encoders) on the same board?
  9. Anyone remember these guys? Graham's is better though ;)
  10. The next question is whether SMD is okay? RG clear SMD LEDs from Mouser I tried searching for clear RG LEDs through hole; nothing jumping out at me.
  11. I'm in, but were you thinking about a PCB to make soldering life a little easier? :ahappy: Of course, these would be "easier": http://www.omron.com/ecb/products/pdf/en-b3w-9.pdf , but at ~2.20US each, TK's idea is more affordable http://mouser.com/ProductDetail/Omron/B3W-9000-RG2N/?qs=EHIUIbu4VmgJJhoE/NFbUA== Edit: Price breaks if interested: 1: $2.68 25: $2.39 50: $2.32 100: $2.20 250: $2.11 500: $1.96 1,000: $1.77
  12. Not necessarily cutting out the whole case, just where there are holes (encoders, buttons, LEDs, LCDs might be a bit trickier). That way your blind panel can be a bit rough or drilled with enlarged holes etc. It might even be a good way of getting a dual-use case, as you could then enlarge the FPE panel to 19" format :question: Sorry, just thinking out loud
  13. Although there would be a few "mils" of extra aluminium, one way to do it might be to get a nice panel from FPE and just drill the case yourself. Might work out a bit cheaper?
  14. Yamaha QY-70 http://www.synthmania.com/qy70.htm
  15. Sorry, OT (photo credit here) :cheer:
  16. Ehh, yeah, I'm thinking of an AC motor. Please ignore :blink:
  17. I'm probably wrong, but can't you add a series capacitor to get motors cranking? But I agree; using some unregulated voltage is a good idea. You could even add a resistor to control the speed (noise).
  18. I've got one of these: Very handy!
  19. Thanks TK I just ended up using another computer :whistle: Btw, on windows my USB MIDI port is called "USB Audio Device" not MIOS32 or something (?) Anyway, Core32 done. Now where did I put my SEQ CS? :)
  20. It is big, but things like this have been done before. Seeing as you mention "survey"ing I might add that encoders are not visual unless you put LED rings around them. Analog pots are, but there's no way to store their positions. It all depends on what you would like to do. I would agree with Wilba; a large project like this would probably take a _long_ time and wear you down unless you had a tremendous amount of spirit. But welcome anyway, it sounds like you're in the right place.
  21. I was putting together my Core32 board last night, following the instructions on uCApps. However, when it came to "activating" the MIDI port, I could not get Windows to find the MIDI port. The install goes okay; it finds a device called "MIOS32" then calls it a USB Audio Device (with a generic driver). However, when I go to find the MIDI ports in MIOS Studio, I cannot find them. I was searching through the MIDIBox forum and found a few links (some in the Spanish section!) to other forums (PIC forum etc.) where they tell you to delete registry filters etc.. I did try this, but still could not get it to work. Presumably there is some conflict between other devices on my system? Any ideas? Or am I stuck on enabling the Boot Hold and uploading via regular MIDI? Or using another OS like MacOS or Linux? Thanks Andy
  22. I know they offered a "Quiet II Upgrade". You can see the inverter circuits in later models (Version 3 hardware) (Not my image --> link
