75 -
2
Everything posted by gtxdude
MBSEQ V4 fitted into the Heidenreich enclosure
gtxdude replied to orange_hand's topic in MIDIbox SEQ
My front panel came from julianf in the UK. Mine fits like a glove. Top notch craftsmanship and cheaper that Scheffer or FPEx. And julianf is a swell guy to boot. See his site at: www.thebeast.co.uk I did use the back panel .fpd that TK provided and it worked great. -
I have been reading Wilba's mb-6582 construction guide this afternoon. there are several embedded links in the text that refer to specific threads in the forum. The URL's in these links look like this: http://midibox.org/forums/forum/index.php/topic,9623.msg70697.html#msg70697 i am assuming that they used to work? I have tried three different browsers, all with the same result: I just land on the front page of the forum section when i click on one of these links. Does anyone have a tip on how to make these work? Am i just being a dim-wit and missing something simple? Thanks for your help.
The two PCBs to the left of the CPU were acquired through a group buy run by seppoman about a year and a half ago. They are the MBHP_ETH PCB and the MBHP_SDCARD PCB. You might try pinging seppoman with a PM and ask if they are still available. That was the only time that I have seen those PCBs for sale on the forum. They were sold as blank PCBs, you had to source your own parts. If you do find a source for these let me know. I need another set of them for another project I'm working on right now. The middle PCB is the SD memory card receiver. Note that the eithernet card and the SD card connect to the CPU on a common cable. Good luck with your project! -
here is what i did with mine: http://www.flickr.co...ude/7503145096/ -
same here. enjoyed your survey!
Is that 90 degrees clock-wise or counter-clockwise?
Your symbol is a xeon flash blub, like what is used in a camera.
SEQ V4 TPD Track Position Display (+ live goa trance)
gtxdude replied to Hawkeye's topic in MIDIbox SEQ
Most impressive. I really enjoyed the track! The elephant looked very purple on my monitor, but I'm sure that he approved just the same... Well done Hawkeye, keep up the good work! -
The timing is great on this Altitude. I have a mixer that I would like to re-knob. It's an old berhringer mx9000. About 405 knobs. The problem is that this mixer uses knobs with a goofy orientation. If the knob pointer is at mid-point in rotation (12 o'clock), the flat of the pot is at 3 o'clock. I think this is known as a "west" orientation. I looked hi and low about 6 months ago and never found a suitable replacement and gave up. I like the black knob with the color insert-able pointer shown above. I need a push on 6mm shaft, 11 to 13 mm base diameter (prefer 11 mm), 5 or 6 colors and the WEST orientation mentioned above. If you can make this work in your order and the price is right, you can put me down for 405 of them. Thank a bunch, gtxdude
From the album: gtxdude
Another view. I have an enclosure designed for it. I am just waiting on julianf to move and get settled back down so he can make it. -
Just finished the electronic assembly of my GM5x5x5 card. My first SMD project. It took a little practice, but I finally got the hang of drag soldering. It's not so bad... -
I was luck enough to score another Wilba control surface for my nephew's SEQ. Thanks for all of the hard work Wilba and Smash, it is appreciated!! -
When I started my SEQ project I scored an UltraCore for my CPU and then the 32 bit platform came out. Rather that waste the UltraCore, I decided to use it in this project. -
I built this SEQ from leftover parts from my SEQv4 build a while back. I gave it to my nephew for his birthday this week. He was VERY pleased... -
Fantastic build orange! I'm with Antix - I love the color scheme. Well done!
Go it. Thanks TK & nILS! You guys are the best!
These guys are hard to beat: allelectronics.com They have killer prices and are quick and trustworthy. I have done a lot of business with them over the years.
Wow hawk, that's fantastic! definitely my favorite of everything that you have posted so far. (nice mash-up with the model plane video too, fine work!)
They also have software versions of this instrument available for the iphone and ipad. ($9.99 USD) There is a discussion forum at: http://www.reactable.com/forums/ I have the iphone version, it is a fun little toy. great time killer...
WOW! What a beautiful piece of equipment! I love it. You should be very proud, Congrats!
Doesn't run MIOS so officially not a user project..
gtxdude replied to NorthernLightX's topic in Miscellaneous
programming that new unit is a 20 year project. it will be the most life enriching project of your life. Congratulations and good luck!
