1,291 -
101
Everything posted by Antichambre
Hi Hal! Did you try the same thing with another software? Best Bruno
Hi, There's a lot of commercial controllers which are very close to your requirements. But if you really want to build your own you can first have a look on this topic. Best regards Bruno
Chiphead (another stereo SID bassline demo :))
Antichambre replied to Hawkeye's topic in Songs & Sounds
Yes, agree with that, I will add more, no need of automation when you're able to feel the music, when you know when and how to add a break or release the groove ;) Except if you can record it, automation is mathematical thing if you just draw it. -
Hi guys, On my last trip I retrieved a new stock of old transistors, I know that this is not the subject here but I prefer to make you benefit first, for example if some plan to make a fuzz pedal, I have some germanium. Most are from 60s / 70s, there are more than 1700 pieces, 260 references. Here is the list, by message if you are interested. https://www.dropbox.com/s/jdjd4jnlo71avoq/1904_NOS.xlsx?dl=1 Best regards Bruno
- transistor
- old
(and 2 more)
Tagged with:
Tell me, it remains some. They are in production... I finally ordered 500 pieces, 14 set, 8 are reserved it remains 6. Regards Bruno
Hey! This is 20 years thing! TK did it like that for the people who don't know how to program and flash on the PIC. So he created a MIDI bootloader.(Yes there's a bootloader ;) During some times the PIC was sold with the BL already flashed, then there was no need of a programmer, only a MIDI interface was necessary cause the MIOS8 and the App layer are uploadable with the MIOS Studio, the .hex file! Which is sent as SysEx to the PIC. I was a bit lost too at the beginning, without any ASM knowledge. But I tried, failed, succeed, and finally learnt a lot more than I expected. Most of the people don't want to change a line in the code, they just want a working machine after have building it. Conclusion if you want to change some lines in the code, you must be interested in mios8 and what it is. Follow the procedures, try, after a few steps, you will see everything lights up. ;) BR Bruno
In white 2800mcd 2600mcd was enough for me, but it's a question of taste. Note: there's a dedicated thread for this subject ;) BR Bruno
https://www.digikey.fr/product-detail/en/mec-switches/5GTH920/679-2611-ND/241155 or quiet version here: https://www.masterelectronics.com/apem-inc./5gth920q-45211465.html?utm_campaign=findchips&utm_medium=inventoryrefferal&utm_source=findchips&utm_content=feed caps at mouser: https://www.mouser.co.uk/ProductDetail/MEC-Switches/1LS096-150?qs=sGAEpiMZZMsGUKQWtoh9Z9Qq96%252bzy8X5H%252bl2qwcE4J8%3D or digikey too https://www.digikey.fr/products/en?keywords=1LS096-15.0
Done.
It's already ordered, but I can still put your name in the list. It remains 3 sets. Each set contains 35 keycaps finally as you can keep some spares. BR Bruno
The definitive or just a test? If just a test, I can help... Best regards Bruno
Done ;)
I haven't got the procedure in mind, but remember the manual is very clear. I've reopen the connectors of my cable, and compare, the diagram is fine. Note: On the diagram,The DIN which has no ground connected(pin 2) must be connected to the MIDI In of your Interface, it's the Output of your pedal. Best Bruno
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
Done!
That's kind, except if you really need/want 2 sets, I will order 10 sets anyway and stock them, I'm sure people will desire it when we will show the final result on our seq! ;) But this will be limited I will make only one bulk of 10 sets. And let the choice to Peter and Andy to add it to their shop if really more people want it.
This is some 909 keycap as example, that is good! It mixes both colors better too. It's even better in the other way, more brightness.
I took some keycap from my 909 to show you. This is clearly fine without changing any resistance value. And these keycap are grey not white and I asked for a bigger LED window! First isolation is good. It mixes both colors better. Even without changing the resistances, there's more brightness on the Seq than on the 909 for the red, I never heard Jeff Mills complain about a lack of brightness on his 909 when he played in a club. lol ;) Still more brightness in the other way. I will choose that one ;)
Done!
Hi Jeff, Just to be sure, the polymoon has to be configured for working in MIDI In and MIDI Out, did you do it? Best Bruno
- 69 replies
- jack
- `control port
(and 2 more)
Tagged with:
The machine was still switched on ;) Yes it's fragile, not over- engineered I simplified it in fact, it was only one side to cut. It's just a lot of time, cause the bit used is a 1mm diameter and I have to be around and check for first run. In fact removing the keycap without damage the switches was the more difficult ;) Did you try it? I need more to be discouraged, I will not lie, since the beginning I do not like transparent caps, all, MEC and ALPS, it is in my mind to change them since you sent me the first board ;) Yes I'm a bit suborn sometimes. Anyway, the machine is always in position and the code is done now then if you want a pair of blocker tell me, the machine will do it alone..... Best regards Bruno
Hi, I change the concept, the 3mm mask(light blocker) is put on the bolt 2mm over the pcb to get the mask highest as possible. It stops the light correctly between the switches body, but the keycap itself diffuses the light to its closest little friends, so it's not a perfect solution. This is the mask, the highest part is very thin 0.3mm to fit inside the keycap when pressed. It's mounted on top of the existing bolt to get a 2mm spacing to the pcb, I change the standoff for some with longer threading. Here the result: It's a bit better, but not perfect. This mask needed 4 hours of machining and it's not possible to make it with a laser cutting. We need a keycap with non transparent sides... humm... I'm sure a white keycap with this large LED window they accepted to produce for us will be better than others complicated solutions, please guys don't let me alone with this ;) I will do it anyway but it will cost me so much more. It's just 10 people for a descent price ;) Best regards Bruno
Try this maybe: https://www.laboutiquedubois.com/interieur-233/panneau-et-planche-408/panneau-bois-massif-1.html
@latigid on Should be something like this: front X-ray view I'm not sure 3mm will be enough high but I can already make and try one piece. Will be free but help me to try the custom keycap in return ;) Best regards Bruno
