1,291 -
101
Everything posted by Antichambre
Done!
Your 9 backplane, milling in progress...
Hi Yogi, Shipping to you will be more expensive than your 2 boards for sure! It's fine, thank you for thinking about it too:)
Thank you to think about it :) I think it's fine... I already decrease PCB price to 3Euro each, good surprise for everybody ;) Black color and ENIG finish: Mouser total order is around 200Euro for the 8 packages. And I will order some cables from ali or amazon like this: cut it and use only female sides. Easier, clean and it will decrease the breakout cable price too ;) Then it's ok. After ordered everything It will permits me to calculate and ask you the right price, not less and not more... But, again, thank you for thinking about it
Bulk is closed now. Total of 20 boards. BR
Bulk is closed now. Total of 20 boards. I order it in few days... Best regards
J'arrive peu-etre un peu tard, je viens rarement sur le groupe francais c'est une erreur. Pour repondre à tes questions: La velocité est codé dans le message de Note-On Note-Off(optionnellement) Dans l'ordre: datas note Off en hexadecimal: 0x8C 0xNN 0xVV, où C est le canal(4bits), NN la note(7bits), VV la velocité(7bits) datas note On en hexadecimal: 0x9C 0xNN 0xVV, où C est le canal(4bits), NN la note(7bits), VV la velocité(7bits) Deux types d'aftertouch: datas Aftertouch par note en hexadecimal, il transporte aussi le message de note pour savoir a laquelle il doit appliquer la pression: 0xAC 0xNN 0xPP, où C est le canal(4bits), NN la note(7bits), PP la pression(7bits) datas Aftertouch par canal en hexadecimal, il appliquer la pression au canal entier: 0xAC 0xPP, où C est le canal(4bits), PP la pression(7bits) datas CC en hexadecimal: 0xBC 0xCC 0xVV, où C est le canal(4bits), CC le controle(7bits), VV la valeur(7bits) Voilà
Ok! understood now what you're talking about, Yes there was a little bit of portamento ;)
Other solution... Forget everything about electronic or coding... Maybe someone, here, has a knowledge in genetic and cloning? Cause we just need to duplicate TK!!!
Thank you! TIA has no filter or fx, but its harmonics really deserves it. 5'20" your sure? ;)
A quick track, recorded on the fly. No post mix, no cut. The new Midibox TIA + TR909 drum I just play with EQ and reverb on the 01v96. I only use the "Bass" and "Buzz-Low" waveform of the TIA. Good Listening!
Hi Mr Spring ;) On the first version, because of the position of the TIA on the board, I made the mistake to supply everything else before it, this caused a crosstalk of midi (audible freqs) to the audio output. Now TIA is powered separately. Two different circuit from regulator output, this is the dash lines on the board ;) Then, there's no more noise. I haven't got any precise audio lab tool for noise floor measure but it's less than -70dB, which is already good enough. BR
Hi everybody, I made one to check before closing the bulk. - I've got some modifications to do in the Mouser BOM. - Some adjustment for the drilling cart. - Add a v2 version in firmware because TIA data register pinout differs from v1. - Change on the silkscreen for Audio Out Config Legend(to be seen with any IC socket). That's all! And It rocks!!! No more noise and crossover, it sounds clear now ;) I think I will close the bulk in January. Then... More interested people???
From the album: MB-TIA Cartridge
I like and use this one, up/down/left/right/button/jog but no shuttle.
Hello, There's a custom option for shine through at Maxkeyboard but it's expensive, cheaper with bulk order maybe. BR
Best DSA keycaps example: But on ALPS switchs. I didn't find this exact led window for MX stem. You can find some DCS profile at maxkeyboard and DSC, DSA, G20 and SA at Pimp My Keyboard but a little bit expensive.
A module of 16 MX in line, like the OLRE ;) You can find gateron for rgb smd led: Or use the common pinned RGB led for MX: My small board accepts both solution, I need to test if red spectrum of the leds will perturb the infrared detector...
Hi latigid on, If you plan to use MX format, I've found an easy way to add velocity sense to it. I told about it in the wilba's topic "Cherry Jammer Blog". Last week, I received PCB for test and it works fine... I'll explain everything when back home...
@ErMangaver Welcome!
Hi dnode, Ok one more! Thank you. Antichambre
