Altitude Posted September 7, 2010 Posted September 7, 2010 (edited) .. removed. Edited September 8, 2010 by Altitude
TK. Posted September 7, 2010 Author Posted September 7, 2010 was bypassing the threads too long... Okay: I want at least Desktop Case as well. (actually, may i get TWO ? i have a klee sequencer which i'd like to put in a case as well. Those are the 19" Version, but do they fit ? Maybe i can add wooden endcheeks then (similar to the FR Mobius) It should work if you change it to a 17" panel (resp. if you reduce the sides which are used to mount the panel into a 19" rack) TK, Can you glance at the linked FPE panel and confirm these are the changes that need to be made for correct slots? Modified Wilba Panel Currently I cannot confirm your changes as I'm waiting for input from Heidenreich. Background: I made some errors with my backpanel. The "rectangle in rectangle" wasn't specified correctly, so that only 1 mm of the border has been milled away instead of 2 mm. As a result it wasn't possible to plug the panel into the slots. Fortunately I was able to fix this with a file... Thereafter I noticed a misadjustment of the panel by ca. 1 mm, which doesn't look so nice. My tools are not good enough to measure dimensions with such an accuracy. And maybe it's better to have a frame of 1.5 mm at top/bottom (but not left/right side) instead of 1 mm... Therefore I have to redesign the layout based on the exact specs from Heidenreich, and probably should order a second prototype before publishing the .fpd file to ensure that you won't do the same errors. I also want to say: I'm the wrong person to ask for confirmation - somebody with more experience should do this! ;) The good news: mounting of internals is almost finished, pictures soon! Best Regards, Thorsten.
TK. Posted September 8, 2010 Author Posted September 8, 2010 Here are the exact measures: http://www.ucapps.de/midibox_seq/mbseq_case_measures.pdf Best Regards, Thorsten.
janvanvolt Posted September 8, 2010 Posted September 8, 2010 TK, can you tell me how to "cut" the 19" to 17" ? Sending the Panel to Schaeffer ? Or are they other alternatives ? (just wondering)
ilmenator Posted September 8, 2010 Posted September 8, 2010 TK, can you tell me how to "cut" the 19" to 17" ? Sending the Panel to Schaeffer ? Or are they other alternatives ? (just wondering) Use a saw... :blink:
Altitude Posted September 8, 2010 Posted September 8, 2010 (edited) Ok, That drawing helps a bunch. So add 1.8mm tall, 1.5mm thick lip to the top and bottom of the front panel. One question however, the drawing shows 1.3mm lip on the sides of the rear, front, and bottom panels in addition to the 1.8mm lip on top. I dont see these in any of the pictures and I dont really know why they are there, can you confirm/clarify? Also, the front panel as Wilba designed it is 431.8mm wide, the print shows the width as 434.50 (which is 431.9 wide when you subtract the two lips, within tolerance), is there a slot on the end panels for those features to fit into? Is that print available in DXF? Id like to go over it in autoCAD if possible.. Edited September 8, 2010 by Altitude
Altitude Posted September 8, 2010 Posted September 8, 2010 (edited) V2 of the front panel with lips matching the print.. FPD File DXF File Edited September 8, 2010 by Altitude
TK. Posted September 8, 2010 Author Posted September 8, 2010 That drawing helps a bunch. So add 1.8mm tall, 1.5mm thick lip to the top and bottom of the front panel. One question however, the drawing shows 1.3mm lip on the sides of the rear, front, and bottom panels in addition to the 1.8mm lip on top. I dont see these in any of the pictures and I dont really know why they are there, can you confirm/clarify? The sidepanels have slots as well. Also, the front panel as Wilba designed it is 431.8mm wide, the print shows the width as 434.50 (which is 431.9 wide when you subtract the two lips, within tolerance), is there a slot on the end panels for those features to fit into? yes Is that print available in DXF? Id like to go over it in autoCAD if possible.. I got it as a .pdf file, and I don't know if the original format was a DXF file - is a DXF really required? (I don't want to bother Heidenreich too often with such special requests...) Best Regards, Thorsten.
Altitude Posted September 8, 2010 Posted September 8, 2010 Ok, that explains it. Adding the 1.8mm lips to the top and bottom of the Wilbapanel should be it then..
TK. Posted September 8, 2010 Author Posted September 8, 2010 There are some new pictures: http://midibox.org/forums/index.php?app=gallery&module=user&user=3436&do=view_album&album=65 Note that they are commented. Best Regards, Thorsten.
janvanvolt Posted September 8, 2010 Posted September 8, 2010 (edited) So to get it right: in order to use the 19" panel for the Case: - cut it down to 17" - make lips on top and bottom of panel. Or can i omit it ? It does look very closed to me ... TK: When the Backpanel is ready, can you make it avail for download / order ? Edited September 8, 2010 by janvanvolt
Altitude Posted September 8, 2010 Posted September 8, 2010 (edited) So to get it right: in order to use the 19" panel for the Case: - cut it down to 17" - make lips on top and bottom of panel. Or can i omit it ? It does look very closed to me ... TK: When the Backpanel is ready, can you make it avail for download / order ? No, you cant add the lip to an already made panel, it is already the right height. It will fit just like TK's and can be attached with fasteners like shown in the pics. The panel with the lips needs to be made that way from the start. @ TK. Thanks for the pic of the slots. Do you think it is worth it to add the lip to the side of the front panel also? Edited September 9, 2010 by Altitude
Davo Posted September 9, 2010 Posted September 9, 2010 What connects to to the inner side of the CV expansion port?
TK. Posted September 9, 2010 Author Posted September 9, 2010 @ TK. Thanks for the pic of the slots. Do you think it is worth it to add the lip to the side of the front panel also? Yes, if you have the possibility it would be better. What connects to to the inner side of the CV expansion port? J5A/B/C (Gates/Clk) and J19 (AOUT interface) I'm using the same pin layout as on my MB6582, so that I can connect the same breakout-box Best Regards, Thorsten.
Davo Posted September 10, 2010 Posted September 10, 2010 I just noticed that there may not be enough clearance between the SD slot and the expansion port to accomodate a D25 plug and an SD card at the same time, or at least allow one to swap cards while the plug is inserted. Another thing... Analogue sequencers (ie Dotcom Q960 or Moog Q960) are capable of being used as complex waveform generators if you run the sequencer fast enough. Midi is too slow for stunts like this. Is MIOS capable of driving CV outputs that fast?
janvanvolt Posted September 12, 2010 Posted September 12, 2010 (edited) As i am ordering tomorrow at reichelt: Which standoffs (size) do you use for the mounting ? Some news on the backpanel ? Edited September 12, 2010 by janvanvolt
TK. Posted September 12, 2010 Author Posted September 12, 2010 I just noticed that there may not be enough clearance between the SD slot and the expansion port to accomodate a D25 plug and an SD card at the same time, or at least allow one to swap cards while the plug is inserted. Fortunately there is enough clearance, see also: http://midibox.org/forums/index.php?app=gallery&module=images§ion=viewimage&img=471 Another thing... Analogue sequencers (ie Dotcom Q960 or Moog Q960) are capable of being used as complex waveform generators if you run the sequencer fast enough. Midi is too slow for stunts like this. Is MIOS capable of driving CV outputs that fast? MIOS (and MIOS32) can do this, but the software architecture of MBSEQ isn't designed for generating events with a period of less than 1 mS (1 kHz), because it needs this time for doing complex calculations on all 16 tracks. Best Regards, Thorsten.
TK. Posted September 12, 2010 Author Posted September 12, 2010 As i am ordering tomorrow at reichelt: Which standoffs (size) do you use for the mounting ? DA 10MM and DA 20MM Some news on the backpanel ? I'm still working on the backpanel. Today I got an idea for solving the SD Card issue: by flipping the SD Card PCB inside the case there is no collision with the frontpanel LCD connector anymore. Disadvantage: the SD Card has to be inserted upside down (but thats acceptable for me) -> http://midibox.org/forums/index.php?app=gallery&module=images§ion=viewimage&img=470 Best Regards, Thorsten.
janvanvolt Posted September 12, 2010 Posted September 12, 2010 (edited) Excellente :-) Just ordered at reichelt (for other projects as well). So any more issues to sort out for the backpanel ? Edited September 12, 2010 by janvanvolt
TK. Posted September 13, 2010 Author Posted September 13, 2010 I ordered a new backpanel and asked Schaeffer to compare it with the dimensions of the original panel before producing it. You don't really want to use (or even blind-order) my .fpd file before I tested the new panel, because it could cost you some money (ca. 75 EUR) or some fixing effort (three evenings at my side) if anything is still wrong! Best Regards, Thorsten.
robotfunk Posted September 15, 2010 Posted September 15, 2010 Is there a chance I could have a sneak peek at the back panel fpd? I'm not planning to build this case you are making, just wanted to know the size/distance of the holes for USB and MIDI ports of the core32 , and the size and position of the Ethernet hole. from the look of your pictures those seem to fit at least.. Also I see you are drilling your own holes in the bottom plate .. are you selftapping the spacers into them? Or are you using a tapping drill bit? cheers
robotfunk Posted September 15, 2010 Posted September 15, 2010 ah I see, you are using 'double female' spacers, was thinking of the ones with a threaded 'male' side on the bottom.. are they 20mm?
TK. Posted September 15, 2010 Author Posted September 15, 2010 you got mail... i'm using 20 and 10mm spacers, no 'double female' the screws are at the bottom side, i guess that there are better solutions? if a spacer was not long enough, i added a screw nut to extend it - this was the cheapest solution for me, no special reichelt order required. best regards, thorsten.
Altitude Posted September 16, 2010 Posted September 16, 2010 (edited) I actually decided to use some 90 deg brackets on the SD card instead of mounting it the bottom panel. This allows me to also mount the card sideways if I choose to.. Edited September 16, 2010 by Altitude
findbuddha Posted September 17, 2010 Posted September 17, 2010 Where does one find such cute little brackets? /stupid question
