cit Posted March 20, 2013 Posted March 20, 2013 hi, im not good in making files in eps. i drilled them myself. it was a bit tricky, but i got it. you had 4 screws for mounting the case, take 6 , 2 in the middle so the case will close properly. i have to drill them manuly too. any how thanks a lot for your work. i have now a nice case for round about 25€. thanks.
ilmenator Posted March 20, 2013 Posted March 20, 2013 any how, nice case. picture is here: https://www.facebook.com/photo.php?fbid=168628226624561&set=a.147360718751312.35191.100004321531447&type=1&relevant_count=1&ref=nf <broken record>offsite docu bad</broken record>
EsotericLabs Posted March 27, 2013 Posted March 27, 2013 Hello SEQV4L fans, I activated the remote keyboard function and modified it for SEQV4L. Here's the SEQV4L layout and the modified seq_ui.c.
TK. Posted March 28, 2013 Author Posted March 28, 2013 Cool! I merged your changes into the official branch Best Regards, Thorsten.
Koerby Posted April 22, 2013 Posted April 22, 2013 Hi I've some problems with the new quantisation feature. When ever I enter the command: set rec_quantisation <50> i get the answer "Quantisation should be between 1%..100%!" what is wrong? Gruß Marcus
TK. Posted April 22, 2013 Author Posted April 22, 2013 Hi Marcus, you've to enter: set rec_quantisation 50 store without brackets - the brackets are only used to describe the syntax Btw.: from Christian I got the confirmation that 20 is a good matching value. 50% is probably too much - but you will see this. Best Regards, Thorsten.
cd_reloaded Posted April 29, 2013 Posted April 29, 2013 Hi folks, at the moment I'm working with 50%, I'm satisfied with that.
TK. Posted May 5, 2013 Author Posted May 5, 2013 at the moment I'm working with 50%, I'm satisfied with that. Interesting to know, thanks for the feedback! A new version is available: MIDIboxSEQ V4L.075 ~~~~~~~~~~~~~~~~~~ o MIDI remote keyboard function now also deactivated when Note On with velocity 0 received Best Regards, Thorsten.
slo Posted May 6, 2013 Posted May 6, 2013 I want to enable Midi 2 Out to send midi notes as in the previous post, but I can't find the Filebrowser in MIOS Studio, what am I missing here?
TK. Posted May 6, 2013 Author Posted May 6, 2013 Please use the most recent MIOS STudio release (2.4.5) Best Regards, Thorsten.
slo Posted May 9, 2013 Posted May 9, 2013 That worked, thanks TK. I used MIOS studio 2.4.5, made the new file under root and added the magic line, and....midi notes on MidiOut2. Beer on the way. George
slo Posted June 23, 2013 Posted June 23, 2013 I've tried uploading the Bootloader update app V1_012 with MIOS32 V2_4_5 in Win XP and I'm getting "Upload aborted due to error #14:Invalid sysex command" error message. I have just the USB cable plugged in (no midi cables) and MIOS does see the SeqLite board. Any help? George
TK. Posted June 24, 2013 Author Posted June 24, 2013 Hi George, this is strange! Are you using a special USB MIDI driver (could be problematic), or the M$ legacy driver which comes with WinXP? It would also be interesting, if the upload is working if the core is in "boot hold" mode (close jumper J27, re-connect the USB MIDI cable, and re-open MIOS Studio) Btw.: which MBSEQ V4L version is currently installed on your core? Best Regards, Thorsten.
slo Posted June 25, 2013 Posted June 25, 2013 Ok, using J27 I was able to load the bootloader, I then had to load V4L 075 to get it going again. It's very erratic now trying to load the bootloader to make the changes I wanted. 2 times it crashed MIOS with an error message and once I was able to load the bootloader and make the changes then store, then it crashed again as I tried the upload again. I'm using the M$ legacy drivers, a single usb port hooked up to the SeqV4L and have had no trouble in the past doing all the firmware updates. SeqV4l 074 was installed before. George
TK. Posted June 25, 2013 Author Posted June 25, 2013 You are the first who reports this; actually nobody reported issues with the updated USB handler yet, especially when the "single USB" option is activated if Windows doesn't like multiple USB ports. Could it be that due to experiments in the past the Windows USB driver is wrongly configured (or corrupted)? What happens, if you uninstall the driver (can be done somewhere in the windows hardware settings, right-click on the MIOS32 USB device and remove it)? After the driver has been removed, just disconnect the USB cable, and connect it again. Windows should re-install the driver thereafter with proper settings. Best Regards, Thorsten.
slo Posted June 27, 2013 Posted June 27, 2013 I'm going to leave it alone for now, it's all working and updated. I did it on a Win 7 computer, the single_usb and name change still don't show on the XP computer though. Time for new latop! Thanks TK GeoW
mühvial Posted August 17, 2013 Posted August 17, 2013 (edited) it would be nice if the orginal KIKAD file would be released, so i can modify it for "isolation drill - cnc" german: "isolations-cnc-fräsen" since the isolation-routines should be done directly out of the the orginal PCB-Tool. thx michael Edited August 17, 2013 by mühvial
DanDerMann Posted August 20, 2013 Posted August 20, 2013 (edited) yes, the file format is compatible, and the complete engine is available. So: you could prepare patterns on a MBSEQV4 and play back on a MBSEQV4L And vice versa (e.g. step/live recording patterns on a MBSEQV4L is more intuitive) Just swap the SD Card -> done In fact MBSEQV4L is identical to MBSEQ V4, just only the user interface has been reduced (e.g. a LCD will *never* be supported!) See also http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fsequencers%2Fmidibox_seq_v4_lite%2F There is a separate hardware configuration file called MBSEQ_HW.V4L (instead of MBSEQ_HW.V4) to avoid clashes with the different hardwares. yes, it's available as well (-> transpose button) yes, all CV outputs are available, but only two gates since J5A/B is connected to the button/led matrix (J28 provides DIN Sync Clock, Start/Stop, Gate of CV#1 and CV#2) Best Regards, Thorsten. Hi everybody, I bought the PCBs and the parts for this project a while ago...I have completed the project but the sequencer does not work... :(((( All the LEDS power up in some sort of sequence and then they switch off in a particular order...then DEAD! Is there something I am doing? Wrong? Is there some initialization procedure? Can you guys help me? The programmed board is fine, I checked it and it says it is OK. I would be willing to pay for someone to have a look at it... I am not sure if the ribbon cables are right...but since ALL LEDS light up it means is Ok isn't it? Please contact me off list dubld68@yahoo.co.uk If nobody wants to help then I will seel the built project, I am sure someone will be able to make it work in 5 minutes... You may need to double check your connections from the core to your control surface. I think I have the same problem as Shimoda I bought the PCBs and the parts for this project a while ago...I have completed the project but the sequencer does not work... :(((( All the LEDS power up in some sort of sequence and then they switch off in a particular order...then DEAD! Is there something I am doing? Wrong? Is there some initialization procedure? Can you guys help me? The programmed board is fine, I checked it and it says it is OK. I would be willing to pay for someone to have a look at it... I am not sure if the ribbon cables are right...but since ALL LEDS light up it means is Ok isn't it? Please contact me off list dubld68@yahoo.co.uk If nobody wants to help then I will seel the built project, I am sure someone will be able to make it work in 5 minutes...I have the top panel in acrylic transparent blue-ish from Formulor...anyone interesetd in it? 15£ only, plus shipping! contact me dubld68@yahoo.co.uk Edited August 20, 2013 by DanDerMann
MeToo2 Posted August 28, 2013 Posted August 28, 2013 I built a Seq V4Lite over the last couple of weekends (using parts from Reichelt, SmashTV (PCB) and Farnell (LPC card)) as my first Midibox project. It worked first time. Only issue I had was getting some Win XP drivers to work with the NXP/ CodeRed software development environment in a VMWare install . I had to use the "HID drivers" at 100KHz, and it took lots of attempts to get the initial MIOS32 bootloader to flash, but once that was done it was plain sailing. This was nothing to do with midibox, but I got a BSOD using the USB based drivers that came with the CodeRed dev environment. What can I say? Excellent project. Excellent software. And last but by no means least, excellent documentation. Thanks! :smile:
TK. Posted September 1, 2013 Author Posted September 1, 2013 Thanks for the feedback! :) Best Regards, Thorsten.
TK. Posted November 25, 2013 Author Posted November 25, 2013 A new version is available which inherited functions from the big brother ;) MIDIboxSEQ V4L.079 ~~~~~~~~~~~~~~~~~~ o added new MIOS Terminal commands: new, saveas, save, load, delete, session, sessions Similar to "the big brother" MIDIbox SEQ V4, you are now able to create multiple sessions on SD Card, or to create a backup of your current session. Best Regards, Thorsten.
