Midibox TWINsid is a light midibox sid v2 on three pcb wiht only 2 sid chip for stereo sound
and a control surface for the clasic parameter (env flt ...)
Midibox twinsid features :
Clasic 100x160mm pcb
2x16 lcd screen
The main board pcb integrated :
1 x psu parts (12v or 9v jumper setting)
1 x core module
8 x bankstick (7 for 896 patchs 1 for 128 ensemble)
1 x ltc module for midi thru and second midi out
2 x sid module
The SR board integrated the din and dout module
The CTRL board have 13 pots and 13 switchs for an easy programming
The enclosure and the pcb Layout coming soon ...
Best regards
Pascal
Edited by yodabe
  • 4 weeks later...
Did you redo the enclosure as well?
yep -)
the plan are send to the cnc laser cutting industry
one of my friend work on this sector that's good for me
i wait for ...
