The ethernet connector for the LPC17 core is a bit difficult to find in the Netherlands. And with USB and Midi ports, I'm not sure what to use it for.
Will the LPC17 Core module work without the MagJack? If so, then I could simply leave it out.
Posted (edited)
I was able to score a bunch of those for about 2.20€ each a while ago. I bought them at Encitech. If that becomes too expensive, drop me a PM. I could send you one or two in that case.
Edit: Encitech were out. Eek!
Cheers!
/J
Edited by jojjelito
The LPC17 core will work fine without an Ethernet MagJack.
Depending on your connectivity requirements, you can leave out some more components, e.g. for a USB-powered SEQ V4 Lite... but it is generally recommended to fully populate the boards as it is only a few dollars more, and you have a reusable standard module, then. The MagJack is a bit of an exception, as it can be quite expensive and hard to get. You can always solder the Jack on later, when you need MIDI over ethernet :)
Bye,
Peter
Posted (edited)
I have to get some a couple too. Think you can buy em in germany.
Maybe this will work?
Edited by Shuriken
Thanks for the help guys,
I found several mag jacks but wasn't sure it's the same type. There are so many around.. Jojjelito has some 60024 for sale.
Posted (edited)
I ordered one at iprototype.nl...let's see if it is a good substitute.
Update:
I received it today.
Physically fits perfectly and the specs it seems to be pretty similar.
Edited by Shuriken
  • 7 months later...
Update:
Hi Shuriken.
Any news about the compatibility of your "Magjack"?
Best regards,
Jerome.
  • 2 weeks later...
I just tested it today, but it does not seem to be working.
[6707.368] [network_device_init] link speed determined
[6707.468] [network_device_init] link available
[6708.168] [network_device_init] lost link
This is what i get in the MIOS Terminal.
After that i tried another a 10/100 Switch instead of the 10/100/1000 Switch and then it doesn't do anything. Maybe the tolerances are different, i don't know. Guess i will have to look for MagJack instead.
In the same time I made a "round" of the MagJack manufacturers and I found an equivalent of the SI-60024-F: It is the Hanrun HY931110C.
The only differences are the diameter of the pins which are slightly bigger and the LEDs which are simple LED and not duoLED.
I made an Eagle library and I will use this reference on the upcoming LPC1769 core I'm designing.
I'm in communication with Hanrun for a big order for a future BO, the price should be 2€ each.
Best regards,
Jerome.
The footprint is ok but unfortunatly I have no populated LPC Core to test it.
I will able to test it only onto the prototype board at the end of the design.
Best regards,
Jerome.
  • 4 months later...
Hallo. I'm new to this forum, but I hang around on www.groupdiy.com and I've built a fair bit of DIY electronics before (G-1176 compressors, G9 tube mic pres, gssl compressors, API 312 mic pre clones, LA-2A tube compressor clone, own design vari-mu tube compressor ... )
Just started with the LPC17 core build. Looks like a wonderful project. It's obvious that there's been a lot of thought gone into this. Thanks.
I'm also looking for source of the specified magjack si-60024-f RJ45 connector for Ethernet.
They can be ordered from digikey.nl with part number 380-1117-ND 4.71 ex VAT.
Would anyone in Europe be interested in a group buy? I'd be in for 4 myself.
  • 4 weeks later...
No replies so far, so I'm just going to sort myself out.
I need a couple as well. But i am not in a big hurry. So if me ordering another 4 takes your order over 100 dollar, i am willing to participate. Otherwise i am gonna wait until i need something more. Paying more shipping costs then for parts feels wrong ;)
  • 3 months later...
Posted (edited)
Digikey is out of stock until March 2014, anywhere else?
Edited by renegadebliss
  • 1 month later...
So Digikey are still out until end of March.
I did find here:
http://ucapps.de/mbhp/mbhp_core_lpc17_orderlist.txt
Reichelt doesn't sell the MagJack
        There are several hobbyist distributors for these components, e.g.
        http://www.csd-electronics.de
          o MagJack 8 polig print 4xLED (#015-54085) for 3.49 EUR
So I see that they actually have some now for 3.95 Euro.
But I'm still trying to find somewhere stateside to get these, do you think that these will work from Sparkfun?:
here's the datasheet for it:
Can I use this for the LPC17CORE?
Thanks!
  • 3 weeks later...
  • 2 weeks later...
