mrspring Posted December 20, 2016 Posted December 20, 2016 Ah OK, so there was some 'machine noise' caused by the MIDI and other processes - the digital cockroaches :) i thought You were hearing the audio channels crossing into each other on the TIA outputs, which is no big deal really for us PAL TIA people who have only 1 channel output anyway! Nice, and the audio clip sounds very clean - i cannot hear any whine or rustle going on in the opening part between the notes. When i turn up the gain here i hear the nosie of my amplifier. Hmm.. some nice clipping/glide from around 5'20"? Yeh this is all good. the patch used in this sounds animated, and you sweeping the EQ shows it's quite a rich waveform there, it should go very well thru' a nice phase-screw patch or a barber pole phaser..
Antichambre Posted December 22, 2016 Author Posted December 22, 2016 Thank you! On 20/12/2016 at 5:22 PM, mrspring said: it should go very well thru' a nice phase-screw patch or a barber pole phaser.. TIA has no filter or fx, but its harmonics really deserves it. On 20/12/2016 at 5:22 PM, mrspring said: Hmm.. some nice clipping/glide from around 5'20"? 5'20" your sure? ;)
Antichambre Posted December 23, 2016 Author Posted December 23, 2016 On 20/12/2016 at 5:22 PM, mrspring said: Hmm.. some nice clipping/glide from around 5'20"? Ok! understood now what you're talking about, Yes there was a little bit of portamento ;)
Antichambre Posted February 2, 2017 Author Posted February 2, 2017 Bulk is closed now.Total of 20 boards. I order it in few days... Best regards
Antichambre Posted February 2, 2017 Author Posted February 2, 2017 (edited) Thank you to think about it :) I think it's fine... I already decrease PCB price to 3Euro each, good surprise for everybody ;) Black color and ENIG finish: Mouser total order is around 200Euro for the 8 packages. And I will order some cables from ali or amazon like this: cut it and use only female sides. Easier, clean and it will decrease the breakout cable price too ;) Then it's ok. After ordered everything It will permits me to calculate and ask you the right price, not less and not more... But, again, thank you for thinking about it Edited February 2, 2017 by Antichambre 1
yogi Posted February 2, 2017 Posted February 2, 2017 Awesome news, been watching/hoping for news the last few weeks :) And like Phatline said, ready to pre-pay if you want. Yogi 1
Antichambre Posted February 2, 2017 Author Posted February 2, 2017 Hi Yogi, Shipping to you will be more expensive than your 2 boards for sure! It's fine, thank you for thinking about it too:)
Antichambre Posted February 5, 2017 Author Posted February 5, 2017 (edited) Your 9 backplane, milling in progress... Edited February 5, 2017 by Antichambre
mrspring Posted March 1, 2017 Posted March 1, 2017 mmmm CNC satisfaction! got to love that nice clean finish on the plates.. looking good!!
Antichambre Posted May 3, 2017 Author Posted May 3, 2017 Hello everybody! I'm back. I just received 30 TIA Pal. I'm waiting for the cables... And I've got a problem with the PCB fab. There's an issue on the board I don't explain it to myself, I checked what I sent to them and it's good on my side. it can be easily corrected. But boards are not perfect, I'm disappointed. Tell me if it's a problem for you and I order new pool from an other provider. Here the track to add. Otherwise Everything else is fine, new TIA chip too: Tell me... Best regards 1
yogi Posted May 3, 2017 Posted May 3, 2017 Looks like a minor fix, not a problem for me :) Looking forward to the board. Yogi 1
Antichambre Posted May 3, 2017 Author Posted May 3, 2017 Just now, yogi said: Looks like a minor fix Yes it is minor, but not perfect :/
gerald.wert Posted May 3, 2017 Posted May 3, 2017 Looks easy enough to get going. I don't have a problem with a simple fix. 1
ErMangaver Posted May 11, 2017 Posted May 11, 2017 I didn't realize sooner things were moving, no problem for me too.
Antichambre Posted May 12, 2017 Author Posted May 12, 2017 (edited) Ok seems this issue is not a problem for everyone :) Yesterday I received all cables. I made one breakout cable for example, this is what you will receive, it will remain to you to cover the DB25 with housing and solder the DC connector. Clean and cheap. Best regards Edited May 12, 2017 by Antichambre
ErMangaver Posted May 12, 2017 Posted May 12, 2017 (edited) ...I love them drums ;) Edited May 12, 2017 by ErMangaver
Antichambre Posted May 12, 2017 Author Posted May 12, 2017 Samples from SynthCart I thing. You will discover something drastically more musical, soon ;) 1
Antichambre Posted May 16, 2017 Author Posted May 16, 2017 Last track made with it. You cannot do that with the synthcart or other project based on the TIA Listen to the harmonics ! ;) 1
Antichambre Posted May 16, 2017 Author Posted May 16, 2017 Thank you, I made this very quickly, i think I will come back on this track later. It deserves to be on a timeline.. That's the point!.. Of all our work, it's not just a geek thing! isn't it? You will test it by yourself soon, I'm in a hurry to listen to what everybody will do with it Best
mrspring Posted May 16, 2017 Posted May 16, 2017 yeh, some nice drifty sync phasing there in that track.. and the lead sound sounds nice and wonky too.. Also: on the capacitor issue (it is the cap, right?) - that's not a problem to me.. Must be annoying to see it at this time for You Antichambre, but it's no big deal. In fact, let's start a rumour NOW that this early revision SOUNDS BETTER because of the orientation of the cap. Oh Yes.. There it is... ;)
