Antichambre Posted June 20, 2018 Author Posted June 20, 2018 don't worry about this message, did you try it with the MIOS Studio first?
Antichambre Posted June 23, 2018 Author Posted June 23, 2018 (edited) For everybody ! In case of led meter strange behaviour.Upload a refreshed version on the HEX here, upload it to the box ;)https://www.dropbox.com/s/bfjf11v8xdav585/setup_tia_cartridge.hex?dl=1 and trash the old one! Thank you Best regards Bruno Edited June 23, 2018 by Antichambre
wired Posted June 26, 2018 Posted June 26, 2018 Hi Bruno, I flashed the new HEX, I think everything works better... except the led meter :) I get the start up behaviour, but when I'm playing, I just get MIDI IN (upper led) reaction. No other led-animation from the eight other leds. Nicolas
Antichambre Posted June 26, 2018 Author Posted June 26, 2018 (edited) I built more than 10 boxes and I never got this issue. Academic Planner has the same issue as you on 1 of his 3 built synth, he will send it to me as I can fix it. This is just a question of time... ;) Best regards Bruno Edited June 26, 2018 by Antichambre
Antichambre Posted July 4, 2018 Author Posted July 4, 2018 1 hour ago, wired said: What a fine invader it is... http://www.midibox.org/dokuwiki/doku.php?id=midibox_tia#customized_labels ;)
Antichambre Posted July 11, 2018 Author Posted July 11, 2018 Hello, I found the issue but I'm not able to explain it. There's a flag to refresh the LED_METER in tia_sr.inc: This flag is set on each TIA registers value change: bsf TIA_LEDMTR_STAT, TIA_LEDMTR_AUDX_REQ in TIA_SR_Handler ;; -------------------------------------------------------------------------- ;; Check for changes in TIA registers, transfer values to TIA ;; and handle Wavetable ;; -------------------------------------------------------------------------- TIA_SR_Handler btfsc TIA_STAT, TIA_STAT_ENGINE_DISABLE return ;call TIA_WT_Handler ; call wavetable handler before continue _TIA_SR_Handler TIA_SR_Start TABLE_ADDR TIA_SR_REGWRITE_TABLE ; contains order of register accesses movlw 6 ; number of registers (0x06) movwf TMP1 ; TMP1 is the loop counter lfsr FSR0, TIA_BASE ; store base address of TIA registers in FSR0 lfsr FSR1, TIA_SHADOW_BASE ; store base address of shadow registers in FSR1 IRQ_DISABLE ; disable interrupts TIA_SR_Loop tblrd*+ movf TABLAT, W movff PLUSW0, MIOS_PARAMETER2 ; store value of TIA in MIOS_PARAMETER1 and increment FSR0 BRA_IFSET TIA_STAT, TIA_STAT_FORCE_REFRESH, ACCESS, TIA_SR_Transfer; don't skip if refresh has been forced movf PLUSW1, W ; get content of appr. shadow register cpfseq MIOS_PARAMETER2, ACCESS; transfer to TIA if not equal rgoto TIA_SR_Transfer rgoto TIA_SR_Next ; skip following code if equal TIA_SR_Transfer ;; register change: write value into shadow register and transfer it to TIA movf TABLAT, W movff MIOS_PARAMETER2, PLUSW1 ; store value in shadow register movf TABLAT, W ; extract address, add offset addlw 0x05 movwf MIOS_PARAMETER1 ; store in address register rcall TIA_SR_Write ; transfer to TIA bsf TIA_LEDMTR_STAT, TIA_LEDMTR_AUDX_REQ TIA_SR_Next decfsz TMP1, F ; decrement loop counter until it is zero rgoto TIA_SR_Loop IRQ_ENABLE ; enable interrupts again bcf TIA_STAT, TIA_STAT_FORCE_REFRESH; clear refresh request (if it has been set before) return When the LED_METER Handler is called It first checks the flag and decides what to do ;; -------------------------------------------------------------------------- ;; LEDMTR module Handler ;; -------------------------------------------------------------------------- TIA_LEDMTR_Handler SET_BSR TIA_BASE ; prepare BSR for TIA register access BRA_IFCLR TIA_LEDMTR_STAT, TIA_LEDMTR_AUDX_REQ, ACCESS, TIA_LEDMTR_Handler_End TIA_LEDMTR_Handler_Meter_Norm bcf TIA_LEDMTR_STAT, TIA_LEDMTR_AUDX_REQ clrf TIA_LEDMTR_VALUE movlw 0x01 cpfslt TIA_AUDV0 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR0 movlw 0x07 cpfslt TIA_AUDV0 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR1 movlw 0x0b cpfslt TIA_AUDV0 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR2 movlw 0x0e cpfslt TIA_AUDV0 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR3 movlw 0x01 cpfslt TIA_AUDV1 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR4 movlw 0x07 cpfslt TIA_AUDV1 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR5 movlw 0x0b cpfslt TIA_AUDV1 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR6 movlw 0x0e cpfslt TIA_AUDV1 bsf TIA_LEDMTR_VALUE, TIA_LEDMTR7 movf TIA_LEDMTR_VALUE, W movwf MIOS_PARAMETER1 rgoto TIA_LEDMTR_Handler_Set TIA_LEDMTR_Handler_Set movlw TIA_LEDMTR_REG rcall TIA_LEDMTR_Write TIA_LEDMTR_Handler_End return It seems to be something like a RAM issue. cause when I change the TIA_LEDMTR_STAT register address in app_defines.h it solves the problem. This is what I changed: ;; ========================================================================== ;; free: 0x027-0x066 ;; ========================================================================== MIDI_RXTX_RX_CTR EQU 0x067 MIDI_RXTX_TX_CTR EQU 0x068 MIDI_RXTX_BEAT_CTR EQU 0x069 ;; ========================================================================== TIA_LEDMTR_STAT EQU 0x06a TIA_LEDMTR_VALUE EQU 0x06b to ;; ========================================================================== ;; free: 0x027-0x04f ;; ========================================================================== TIA_LEDMTR_STAT EQU 0x050 TIA_LEDMTR_VALUE EQU 0x051 ;; ========================================================================== ;; free: 0x052-0x066 ;; ========================================================================== MIDI_RXTX_RX_CTR EQU 0x067 MIDI_RXTX_TX_CTR EQU 0x068 MIDI_RXTX_BEAT_CTR EQU 0x069 ;; ========================================================================== ;; free: 0x06a-0x06b I've checked for address conflict, there's no :(If anyone can explain me it, he is welcome !!! Best regards Bruno PS: I will share a new firmware version asap...
Antichambre Posted July 11, 2018 Author Posted July 11, 2018 Hi All, Here the new firmware version with the LED_METER workaroundhttp://www.midibox.org/dokuwiki/doku.php?id=midibox_tia#firmware1 This is Academic Planner's box, he sent me it as I can work on a faulty one: This is fine now! Best regards Bruno
Antichambre Posted July 12, 2018 Author Posted July 12, 2018 Good Morning, I just received @wired's box, upload new firmware and this one works fine now too ;)@Phatline, @dnode, @ErMangaver, @mrspring, @yogi, @scrubber, @gerald.wert Please update the firmware...http://www.midibox.org/dokuwiki/doku.php?id=midibox_tia#firmware1 and let me know ;) Best regards Bruno
wired Posted July 12, 2018 Posted July 12, 2018 Hey Bruno, would you have some spare fasteners to fasten my SUB-D25 to the aluminium backplane? Thanks!
Antichambre Posted July 12, 2018 Author Posted July 12, 2018 13 minutes ago, wired said: Hey Bruno, would you have some spare fasteners to fasten my SUB-D25 to the aluminium backplane? Thanks! Yes I saw that it's already done! There was no sound because jumper for audio was not in the right position. I remove the drilling helper from inside your box, this part is just to help you for drilling Leds holes and must be removed after hihi :) Your box shines now ;) Best regards Bruno
Antichambre Posted July 12, 2018 Author Posted July 12, 2018 For your old dusty cartridge.https://www.amazon.fr/BELGOM-05-0500-R%C3%A9novateur-Plastiques-500/dp/B0039JPUA4/ref=sr_1_7?s=automotive&ie=UTF8&qid=1531386315&sr=1-7&keywords=renovateur+plastique You can find it in all cars specialist shop ;)
Antichambre Posted July 12, 2018 Author Posted July 12, 2018 Just now, wired said: Thanks. Strange because I had sound... But thanks! You maybe change it after testing ;)
Keeze Posted October 19, 2020 Posted October 19, 2020 (edited) And another TIA cartrige bites the tones :) Tnx @Antichambrefor this project and your patient support :) Edited October 19, 2020 by Keeze 1
emerson Posted March 17, 2021 Posted March 17, 2021 (edited) I've made it to the "power it up and see" phase of building the cartridge TIA box. When I do apply power, the LEDs for MIDI In and Out blink briefly, which feels like a booting-up indicator, and then the MIDI In light turns on and stays on. That seems like a bad symptom so I pull power immediately. I've tried reflowing some of the solder joints around the optocoupler's cluster of components and the DIN pins for MI+ MI-, also looking for solder bridges etc, but no luck so far. FWIW, MIDI Out is working as expected -- when I power it up connected to MIOS Studio, it sends the "f0 00 00 7e 40 00 01 f7" as expected. It's just the MIDI input on the cartridge that seems bad. Any hints on where to look next for this? I'm bumping up against my late-beginner limits. Thanks in advance. Edited March 17, 2021 by emerson
Antichambre Posted March 18, 2021 Author Posted March 18, 2021 Hi do you use the provided DB25 adapter cable? Check it also please. Did you try to upload the application again? Best regards Bruno
Antichambre Posted March 18, 2021 Author Posted March 18, 2021 (edited) On 10/19/2020 at 7:49 PM, Keeze said: And another TIA cartrige bites the tones :) Tnx @Antichambrefor this project and your patient support :) @Keeze Could you share your illustration as I can add it to the other Thanks! Edited March 18, 2021 by Antichambre
Keeze Posted March 18, 2021 Posted March 18, 2021 35 minutes ago, Antichambre said: @Keeze Could you share your illustration as I can add it to the other It's already on midibox_tia [MIDIbox]? Cheers
Antichambre Posted March 18, 2021 Author Posted March 18, 2021 Just now, Keeze said: It's already on midibox_tia [MIDIbox]? Cheers Yes sorry I was on an old dokuwiki revision ;) 1
emerson Posted March 18, 2021 Posted March 18, 2021 (edited) 18 hours ago, Antichambre said: Hi do you use the provided DB25 adapter cable? Check it also please. Am I right in seeing that the center pin of the MIDI Out DIN should be attached to pin 15 / ground of the DB25? That one is not, I'll look to fix it. The other four from the two MIDI DINs are correctly connected (ie, MIDI In seems to be hooked up correctly, unless it relies on the pin 15 / ground from the MIDI Out DIN). (Edit: Or is this the thing I vaguely remember where you ground the MIDI cable shield but don't attach it to one of the pins?) 18 hours ago, Antichambre said: Did you try to upload the application again? MIDI In isn't working, and I don't have a PIC burner for surface-mount PICs, so... not yet. Am I correct in thinking that the MIDI light staying on is possibly destructive and I shouldn't keep it powered up that way? Thanks! Edited March 19, 2021 by emerson
Antichambre Posted March 19, 2021 Author Posted March 19, 2021 (edited) 10 hours ago, emerson said: Am I right in seeing that the center pin of the MIDI Out DIN should be attached to pin 15 / ground of the DB25? That one is not, I'll look to fix it. The other four from the two MIDI DINs are correctly connected (ie, MIDI In seems to be hooked up correctly, unless it relies on the pin 15 / ground from the MIDI Out DIN). (Edit: Or is this the thing I vaguely remember where you ground the MIDI cable shield but don't attach it to one of the pins?) Good pinout is this one:Check if IN pins are not inverted MIDI IN pin4 connected to MI+. DB25 pin14, wire should be green MIDI IN pin5 connected to MI-. DB25 pin1, wire should be white MIDI OUT pin2(center) connected to ground. DB25 pin15 MIDI OUT pin4 connected to MO+. DB25 pin2, wire should be green MIDI OUT pin5 connected to MI-. DB25 pin3, wire should be white 10 hours ago, emerson said: MIDI In isn't working, and I don't have a PIC burner for surface-mount PICs, so... not yet. There's no specific burner for surface mount, if you've got one you can connect it like this: 10 hours ago, emerson said: Am I correct in thinking that the MIDI light staying on is possibly destructive and I shouldn't keep it powered up that way? No it's not destructive, le led are software driven, they their own pic pins. Do you try to do a "Query" in MIOS Studio even with this led behavor? (with MIDI In and Oout connected). Edited March 19, 2021 by Antichambre
emerson Posted March 19, 2021 Posted March 19, 2021 1 hour ago, Antichambre said: Check if IN pins are not inverted MIDI IN pin4 connected to MI+. DB25 pin14, wire should be green MIDI IN pin5 connected to MI-. DB25 pin1, wire should be white MIDI OUT pin2(center) connected to ground. DB25 pin15 MIDI OUT pin4 connected to MO+. DB25 pin2, wire should be green MIDI OUT pin5 connected to MI-. DB25 pin3, wire should be white The green and white ones are correct, both pairs, and my meter tells me that the DIN pins and the DB25 pins for those are connected as you say. Weirdly, DIN pin2 isn't grounded, even though the third wire from the MIDI Out cable goes to that pin. I guess it didn't connect well when they made it, and I'm gonna have to take the connector apart more to debug that. 1 hour ago, Antichambre said: There's no specific burner for surface mount, if you've got one you can connect it like this: Hmm I used my PICkit clone to reprogram the bootloader into the PIC, and MPLAB reported success. Now, though, when I put power to it while connected to MIOS Studio, it doesn't even give off the initial "f0 00 00 7e 40 00 01 f7" that it did previously. I re-tried flashing the bootloader with MPLAB, and again it reported success, so the PIC is alive, at least, just not... doing anything. 1 hour ago, Antichambre said: Do you try to do a "Query" in MIOS Studio even with this led behavor? (with MIDI In and Oout connected). That doesn't work, and didn't work previously before I started tinkering with MPLAB -- it just gave the normal "No response from MIOS8 or MIOS32 core!" etc etc error.
