Fairlightiii Posted February 25, 2014 Report Posted February 25, 2014 (edited) Dear members. In the perspective of the upcoming bulk order of the MB-LRE8x2CS (Rev 4.6) I opened a waiting list. It is a all-in-one board including DINx4 module, improved DOUTx4 module, 16 LEDrings and 16 encoders. This control surface board is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. I included also 3 others boards to the list: MB-LR4x2CS_RED: 4×2 LEDrings board already populated by (128x) 1206 red SMD LEDs, MB-LR4x2CS_BLUE: 4×2 LEDrings board already populated by (128x) 1206 blue SMD LEDs, MB-E4x2CS: 4×2 Encoders board, MB-LR4x2CS and MB-E4x2CS are stacked one on the other. And 16mm undetended encoders (with 20 and 25 mm shaft) to know how much is there an interest for. You will find more informations on my Wiki page. Best regards, Jerome. Edited February 25, 2014 by Fairlightiii Quote
latigid on Posted February 25, 2014 Report Posted February 25, 2014 Nice, have improvements been made with regard to LED saturation? Quote
Fairlightiii Posted February 25, 2014 Author Report Posted February 25, 2014 Nice, have improvements been made with regard to LED saturation? No, but deep test made by Thorsten showed that the ULNs are necessary even in 4x2 context. The problem of brightness of LEDs occurs mainly with rectangular LEDs but not enough test (...or feedback) have been filled in the LED black list to propose a (some) good candidate(s). ...of course, members are still welcome to fill the list with their LED feedback ! Best regards, Jerome. Quote
m00dawg Posted March 3, 2014 Report Posted March 3, 2014 Wiki page lists the board as slightly less than 2U. I assume it wouldn't require anything fancy to modify your frontpanel design to make it rackmount? Quote
Fairlightiii Posted March 3, 2014 Author Report Posted March 3, 2014 (edited) Wiki page lists the board as slightly less than 2U. I assume it wouldn't require anything fancy to modify your frontpanel design to make it rackmount? 2U= 3.469 inch and the board is 3.35 inch. Nevertheless, be careful to the the thickness of your top and bottom rack enclosure. Regarding the *.svg file, you only have to add the mounting holes (to the rack). Best regards, Jerome. Edited March 3, 2014 by Fairlightiii Quote
m00dawg Posted March 3, 2014 Report Posted March 3, 2014 2U= 3.469 inch and the board is 3.35 inch.Nevertheless, be careful to the the thickness of your top and bottom rack enclosure.Ah well, if I did that, I would likely just mount the panel directly to the rack without an enclosure. So basically the board would just hang off the panel and the panel would mount directly to the rack. Seems to make things like clearance so much easier and I haven't found 2U+ enclosures I have liked that are also reasonably priced here in the US. That plus I have about 2U of space where I can mount something like this to the mixer rails of our rack and, in doing so, wouldn't be able to use a normal enclosure anyway.I guess, what I should have asked was has anyone mounted this thing on a rack before? Seems like it is possible just curious if someone has gloriously paved the way already :smile: Quote
Fairlightiii Posted March 3, 2014 Author Report Posted March 3, 2014 Ah well, if I did that, I would likely just mount the panel directly to the rack without an enclosure. So basically the board would just hang off the panel and the panel would mount directly to the rack. Seems to make things like clearance so much easier and I haven't found 2U+ enclosures I have liked that are also reasonably priced here in the US. That plus I have about 2U of space where I can mount something like this to the mixer rails of our rack and, in doing so, wouldn't be able to use a normal enclosure anyway. I guess, what I should have asked was has anyone mounted this thing on a rack before? Seems like it is possible just curious if someone has gloriously paved the way already :smile: Milky did: Quote
m00dawg Posted March 3, 2014 Report Posted March 3, 2014 :shocked: WHOA! Impressive would be an understatement. Well, sweet good to know it'll fit! Quote
Lamouette Posted March 4, 2014 Report Posted March 4, 2014 What the fuck is all this stuff ? Only controller ? Some videos to see how it's used ? Quote
sneakthief Posted March 4, 2014 Report Posted March 4, 2014 Lamouette: mon gars - calme toi les nerfs :P :D It's just some rotary encoders and LED's. As the man says, check out his wiki: http://www.midibox.org/dokuwiki/doku.php?id=mb-lre8x2cs_rev4.6 Quote
m00dawg Posted March 4, 2014 Report Posted March 4, 2014 Lamouette: mon gars - calme toi les nerfs :P :D It's just some rotary encoders and LED's. As the man says, check out his wiki: http://www.midibox.org/dokuwiki/doku.php?id=mb-lre8x2cs_rev4.6I thought he was referring to all the stuff in Milky's setup (presumably many of it being controlled via the LED rings)? Quote
sneakthief Posted March 4, 2014 Report Posted March 4, 2014 MIDIbox Seq and a bunch of GM modules being controlled by the LRE8x2 boards: Quote
Fairlightiii Posted March 4, 2014 Author Report Posted March 4, 2014 What the fuck is all this stuff ? Only controller ? Some videos to see how it's used ? All I can say seeing this stuff that some men are lucky to have understanding wife (...or to not have at all a wife !). Quote
Milky Posted March 5, 2014 Report Posted March 5, 2014 Hello, Some explain about the photos published by Jérome . This projet , in four slim 19" rack , contained 2 seq ( V4 & V3 ) four leds ring and other personnal midibox. It contained 6 DB50XG yahamha sound card to , sound incredible and spécial midibox for editing QS300 sound . Actually 90% is done an fonctional. ( sorry for my poor english). Thank to Jérome for these beatiful printred board easy to start, rack mounting are also easy as you se on the photos. I am very busy those time ( job and familly ) I hope in some time y could answer question on the forum. But only for fun... Quote
Lamouette Posted March 5, 2014 Report Posted March 5, 2014 That's a real cool ,and massive project ! I will check your profile to see if you up sone sounds :smile: Bye Quote
DubplateDerek Posted March 26, 2014 Report Posted March 26, 2014 Hey Jerome So I am just starting to plan a MidiBox NG and I would like to include these rotary encoder PCBs. I'm not sure right now whether I'll go for 16 or 24 channels, but I think they'll be in banks of four, so using 16 channels as an example I would need : MB-LR4x2CS_RED x 4 MB-E4x2CS x 4 25MM shaft encoders 32 (though I see you sell them in multiples of 25) Is that correct? Is there any advantage or disadvantage of using MB-LRE8x2CS instead of MB-LR4x2CS_RED except that the LEDs are pre-soldered on the MB-LR4x2CS_RED modules? Of course, each board is 8 channels instead of 4, but apart from that and the pre-soldered LEDs, are there any differences? Thanks, DD Quote
Fairlightiii Posted March 26, 2014 Author Report Posted March 26, 2014 so using 16 channels as an example I would need : MB-LR4x2CS_RED x 4 MB-E4x2CS x 4 25MM shaft encoders 32 (though I see you sell them in multiples of 25) Is that correct? If you mean 16 channels = 16 controllers, you would need: MB-LR4x2CS_RED x 2 MB-E4x2CS x 2 25MM shaft encoders 16 Is there any advantage or disadvantage of using MB-LRE8x2CS instead of MB-LR4x2CS_RED except that the LEDs are pre-soldered on the MB-LR4x2CS_RED modules? Of course, each board is 8 channels instead of 4, but apart from that and the pre-soldered LEDs, are there any differences? MB-E4x2CS/MB-LR4x2CS can handle 8 controllers and MB-LRE8x2CS can handle 16. There's technically no much difference but you will be able to reach the maximum allowed number of SR (32) by the system with 10x MB-LR4x2CS (=80 controllers) or 8x MB-LRE8x2CS (=128 controllers). The main advantage of the MB-E4x2CS/MB-LR4x2CS is the time you won't spend to solder the LEDs. Best regards, Jerome. Quote
DubplateDerek Posted March 26, 2014 Report Posted March 26, 2014 OK, thanks. I presumed that MB-E4x2CS which has two rows of four pots would be two pots per channel. Can it be configured that way if I want? One pot for pan say, and another for let's say an aux send both on the same channel? Cheers! Quote
Fairlightiii Posted March 26, 2014 Author Report Posted March 26, 2014 OK, thanks. I presumed that MB-E4x2CS which has two rows of four pots would be two pots per channel. Can it be configured that way if I want? One pot for pan say, and another for let's say an aux send both on the same channel? Cheers! Yes. You can assign any MIDI parameter that your host can handle to each controller. Best regards, Jerome. Quote
Fairlightiii Posted March 26, 2014 Author Report Posted March 26, 2014 Dear members. I would like to inform that the prototype boards I ordered are on the road. I will give more technical informations about the board as soon as I will make them work. So the time frame of the bulk order could be known. Best regards, Jerome. Quote
DubplateDerek Posted March 27, 2014 Report Posted March 27, 2014 Perhaps I'm being thick, but I can't see a way to register an account on the Wiki, which is apparently necessary mow according to a sticky on the forum. Jerome, please would you register my order on your waiting list? MB-LR4x2CS_RED x 4 MB-E4x2CS x 4 25MM shaft encoders x 50 Thanks, DD Quote
Fairlightiii Posted March 27, 2014 Author Report Posted March 27, 2014 Jerome, please would you register my order on your waiting list? MB-LR4x2CS_RED x 4 MB-E4x2CS x 4 25MM shaft encoders x 50 Thanks, DD Done. Best regards, Jerome. Quote
Fairlightiii Posted March 28, 2014 Author Report Posted March 28, 2014 Dear members. I would like to inform that the prototype boards I ordered are on the road. I will give more technical informations about the board as soon as I will make them work. So the time frame of the bulk order could be known. Best regards, Jerome. PCBs received ! I will post some pictures before next mid-week. Best regards, Jerome. Quote
Tr1ptron1c Posted March 30, 2014 Report Posted March 30, 2014 (edited) Hi Jerome, Iam also somehow Not able to create an Wiki Account. I would like to Join the List with : MB-LRE8x2CS rev 4.6 x 1 MB-LR4x2CS_RED x 2 MB-LR4x2CS_Blue x 2 MB-E4x2CS x 4 16mm Encoder 25mm Schaft 25Stk. Best regards Tr1ptron1c Edited March 30, 2014 by Tr1ptron1c Quote
Fairlightiii Posted March 30, 2014 Author Report Posted March 30, 2014 MB-LRE8x2CS rev 4.6 x 1 MB-LR4x2CS_RED x 2 MB-LR4x2CS_Blue x 2 MB-E4x2CS x 4 16mm Encoder 25mm Schaft 25Stk. Done. Best regards, Jerome. Quote
