The HAARP, a Hardware Advanced Arpeggiator.
Antichambre
Hello...
I hope everyone who is stranded at home has found a good occupation!
Here some picture of the Desktop version enclosure.
large.IMG_1547.png.e79a3b1d8845f590af025d8ba477a330.pnglarge.IMG_1546.png.d222a23d975b3d04ab9d9ce5bcedf32e.png
Shape of the side face, I found some ebony for the wood sides ;)
Check of the assembly before paint.
large.IMG_1536.png.13e81f1c5f1f2a8d45729
Some more pictures in the HAARP album.
Best regards
Bruno
Edited by Antichambre
Thank you Bruno for the great job!
I was thinking about "pure" analog clock (DinSync or just analog pulses), because I try to avoid any MIDI conversion... this is the reason why my actual main clock is coming from a Cirklon unit, which drives all my drum machines via DinSync (and also my TB-303). On the MIDI part, I only send notes, no clock information... ;-)
The other clock source I sometimes use, is Roland's SBX-1 which also has DinSync...
Anyway, that's not an issue with HAARP at all! Keep on going!
F.
  • 4 weeks later...
  • 6 months later...
6 hours ago, rosch said:
Très chic!
Merci!
I've played a lot with Xfer's Cthulu, a real arpeggiator in HW would be awesome.
This one has a pot for each parameter, it changes the game! ;)
Is there a way to get some boards / case to build one?
I will propose it soon now, I hope in the next months...
  • Like 1
  • Antichambre changed the title to The HAARP, a Hardware Advanced Arpeggiator.
On 1/30/2021 at 3:44 PM, Altitude said:
nice.  Need to start paying more attention here, lots of great projects slipping under the radar
Thanks!
I spent my free time of the two last month to get the firmware I wanted for it, that's done :happy:
I started to write the manual during few days before leaving France for work but it seems coding in C is easier than setting a page or a column break in word software! :shock: ahah!
Best regards
Bruno
Hi Bruno.
Whenever you'll be ready, you can pass the manual to me for reviewing.
BR,
Flavio.
PS: any news about the enclosure?
  • Like 1
  • 3 weeks later...
Quick test for CC automation.
The HAARP is only connected to my laptop and Ableton Live is running. Live gives the sync.
Only the Drum Track is programmed. I play with 4 differents clips.
There's 3 synth used, BAss, Saw and Choir they are some of the basic provided with Ableton, no sequence, direct input are activated on the synth tracks.
Preset, Mute change, and some of the parameters of the HAARP are automated, by a previous MIDI record.
  • Like 1
Hi Flavio,
The enclosure is still one of the two prototypes Adrian sent me. They are not *perfect* ;)
Don't worry, the first *perfect* one is for you... I know it's long but I currently have a lot of work and the covid don't make things easy.
Best regards
Bruno
PS: And thank you I love Gus Gus, that's a great compliment :happy:
  • 3 months later...
  • 5 months later...
10 hours ago, Spraytex said:
Idem, il va transformer mon AX80 , slurps.
Plus sérieusement, bravo pour le travail effectué, félicitations!
Si j'ai bien compris, il n'est pas polyphonique?
Merci d'avance pour la réponse.
Oh si il est polyphonique ! Tu as 8 voies simultanées que tu peux router vers un canal/port midi dédié !
Yes it it polyphonic, you have 8 simultaneous voices you can route on a dedicated midi channel/port !
  • Like 1
Comme l'indique Raphaël(rmouneyres) c'est 8 voix en // qui basiquement font tourner 8 arpèges mono, le note off de la dernière note est toujours envoyé avant une nouvelle note, le GATE ne permet pas de chevauchement de note,
Il y a aussi une fonction avancée qui permet depuis un clavier midi de jouer des accords du même arpège, chaque note va déclencher un arpège qui sera transposé en fonction de la note joué.
On 4/4/2022 at 10:21 AM, electromaitre said:
Salut bruno, on fait comment pour t'en acheter un ? ;o)
On patiente un peu encore ;)
