MBSID V2 Drums Teaser #2
So, here the second part: a quickly recorded a session where I'm using Drum and Bassline sequencer in parallel - sequences and bassline parameters are selected/controlled live from a MIDI keyboard.
The drum sequencer provides 8 patterns with 8 tracks. Since there are 16 drum instruments available per patch, each track can trigger two of them in a special way:
(edit screen of track #4 of sequence #7)
.: no instrument is played
*: default instrument will be played
A: the default instrument will be played w/ accent
S: the secondary instrument will be played (w/o accent)
Track 1 Controls Instrument #1 (default) and #2 (secondary)
Track 2 Controls Instrument #3 (default) and #4 (secondary)
etc...
The advantage of this method: it saves memory (8 sequences available instead of 4), and it allows to realize the typical Open/Close HH or High/Low Tom scheme from a single track.
Here the demo (I just have noticed, that the BD is really low tuned... you won't hear it with cheap speakers):
http://www.ucapps.de/mp3/midibox_sid/mbsidv2_drums_demo1.mp3
During the session I noticed a lot of imperfections, which need to be solved :-/
Maybe something related to the display printing "GAS"?
KABOOM
er TK that explosion was that BD or you forgot to turn off the gas?
Cool drums TK!
fossi.bs thinks jimp is onto something.
Although, I'm pretty sure that I heard the gating flux capacitor moan somewhere around measure 14 - so it could stand for "Gate Allocation System"
