1,277 -
71
Everything posted by Phatline
LoopA V2 Introduction, Features & Support Thread
Phatline replied to Hawkeye's topic in MIDIbox User Projects
thx... have more detail to the problem i think: the Bootloader switch was in "bootload" position everytime... i did because, in this position it booted up normal - so i guessed... now after i give it that 330ohm resistors R102 R101, --- it dont boots up in the same position because it is in "real" bootload position.... after switching it to the other side the problem is gone! ---good to have a functional bootloadswitch in this time... because in some month when i need it in real (hacking into code maybe) - i would come in some serios trouble - because of thinking the switch do its job - and the MCU which is fix soldered - is gone or something THX -
interesting, i tested the loopa, without case & with that without the SWITCH i now soldered in the two 330OHM resistors... now it is working --- maybe this changes when the device is assembled again... i will report (also i will destroy usb cable to see the power draw :) ) -
i dissambled the thing now to get to the core pcb --- it is set to 3.3V' yes. -
in about 24 minutes the video with the problem showing is up here: -
i always connect midi first --- at last i give Power over USB.... i dont hot swap ( i do now because of workaround reasong - to get the loopa booting It doestn matter if a midi IN is Connected or not... so focus the Topic on this without connecting anything on MIDI IN: When there is a Midiconnection from any Loopa MidiOut (DInSocket) --- to a synthesizer --- then it dont boots up >>> no Midiloops because no Input Connected on the Loopa. Its not hardwarestress on the sockets or some Hair-Cut PCB Failure ... because - if the Midiconnection is pluged out on the Synth-side ... and the cable is still plugged into the loopa --- the loopa boots up! Ground loop: i rotated the 230V power 180° of my synth - doesnt matter I powered the loopa via a 2A USB PSU - doesnt matter I powerd the loopa via a Lenovo T440P laptop on Battery without connected a PSU (so its isolated from any loop!) - doesnt matter so no ground loop here. when connected to my laptop - and the loopa is not booting up - i dont see the loopa in mios studio (no bootloader mode or mios32 entry here) & it is not the cable itself: i have tested 3 different ones (one bought from thoman), and 2 i made myself (thick sommer cable, neutrik connectors...) & when i trickked the loopa to boot up (hot plug Midiout after booting) - it is running normal - it receives notes, and it sends notes . ( as far as i can say, since it is a new device for me) -
what can that be?: * the loopa is totally unconnected... then plugin usb cable --- loopa and display boot up - normal * the loopa is tottaly unconnectet... then plug in midiIN1 or 2 ---then plugin in usb cable --- all ok * the loopa is totally unconnectet... then plug in MidiIN1 or 2 ---then plugin in MidiOUT1 or 2 or 3 - but without connecting a synth on the other end --- plugin in usb & loopa boots up - all ok * the loopa is totally unconnected... then plugin midi''IN1 or 2 --- then plugin in MidiOUT1 or 2 or 3 - connected to a NordRackII or Dipcore - plugin in usb & loopa dont boot up (power led blinks 7 times i think, then it stays on power) when i then disconnect the Midiout plug after a time it boots up the last case, isnt pysical stressed --- i connect on one of the midi outs with a loose cable (without a synth on the other end...) --- then it boots up normally. i tested it with a Nordrack III and DipCoreV2 (cc-looper) workaround for now is to connect the Midiouts every time new before booting up the LoopA ---- but i dont want to stress the MidiSockets for ever.... -
it took me a long night ---but --- i finished my loopa now: some notes to the video, and build up: on the start of the video i saw on your video footage that you had stuffed PD11 --- i think on later video minutes it isnt stuffed anymore (and thats is correct, since with the jumper cable stuffed you are in bootloader mode forever) on the lcd capter - a bit confusing - it came to my mind - i saw that you solder the package together without removeable female headers... or at least it looked like it... i nearly did that... i hadnt that tiny m2 toax screwdriver at home... lukely i had fitting flat one... the fix solderd lcd i dont like (specially i got headaches when the lcd dident come up - because of bad PSU - i thought i had to de-solder the thing ) its much easy to put the white button caps into the button, when the button already sits in the pcbs! ( i scratched my finger with one of the Button-legs...) a good place for a Bootloader-switch is above the Reset Switch... the display has sharp edges that scraped my plexy window while mounting it and position it... so stick the plexi with tape on the top case bevore (i dont think the plexi part was in the video) most of the times the displays dont startup (stay black) when the loopa is connectet to my lenovo t440p --- on 2A usb wall Supplys it starts everytime... Missing parts: 8x Beilagscheiben (only 8 deliverd) - so i only stuffed them in the inside of the case (base pcb mount on metal case) 3x Nuts, where 1 was my fault (gone to floor...) so i think 2 where missing (to bad that i have thousends of m3 but not one m2 nut) its ease to destroy the winding of those m2 standoffs-outside windings... when you suddenly found a m2 nut - and its a stainles one.... i must say its not the easyest project... specialy this clever sandwitch... i had to assambly and disambly the things many times... next time it will be easyer... the video method i like, but on some points - i whish i had normal website and still pictures (aka assambly manual) --- specially when my internet connection is bad again... I like the look and feel of the device! i made a timelapse while building... so there will be a video some time... -
thx me too... feels like there are too much possible projects sometimes... ---luckely finally all loopa parts (mouser delayed) are arrived - and i can begin to integrate it to a Guitar-Synth --- some kind of Footboard to remote it. so me and my guitarist can jam together more better...
- 2 replies
- 1
- michael sigl
- funkeln 2010
(and 3 more)
Tagged with:
10year old track, and some stop motion night sky videos....
- 2 replies
- 1
- michael sigl
- funkeln 2010
(and 3 more)
Tagged with:
ok when height dont matter than this is the only replacement at the moment: (2,54mm, 2Row, 10 Pins, Female, Thruhole, without cutting a more pinned header...) https://www.mouser.at/ProductDetail/3M-Electronic-Solutions-Division/929975-01-05?qs=bX1%252BNvsK%2FBrGbqaIqQvrfA%3D%3D i phone mouser now.... to change my order... want to start solder ;) not to wait. EDIT: mouser munich - nice - ok will get it soon ;) thx -
is there a alternative forhttps://www.mouser.at/ProductDetail/te-connectivity/5-534998-5/?qs=xDp7PGUNC%252bs6ZU%2FXKidt5w==&countrycode=DE¤cycode=EUR this part bis delaying most of my parts.... 21 weeks leadtime -
prototype is running... with some modwires... so the pcb has to be changed a bit. i made a video on: how to upload bootloader, app, and buil app and so on for the DIPCORE:
- 27 replies
- cc-recorder
- controlchange looper
(and 1 more)
Tagged with:
ok i want to order the metalcase kit with the old caps - since i am in hurry... how we do that? - i have registered on midiphy. -
it was again this cc1 link thing.... - now working "ln -s /home/inet-stick/midibox/gcc-arm-none-eabi/lib/gcc/arm-none-eabi/4.7.4/cc1 /home/inet-stick/midibox/gcc-arm-none-eabi/arm-none-eabi/bin/cc1" (then restart!) and in Environment variables the LCD was missing: now Working... i hope i never ever have to install a new linux... but badly the day will come - and the horror begins from new on...
hi...was looking on midiphy - and the essential kit with metalcase is out of stock, while the metalcase itself is in stock. (maybe because of the button caps?) i have a band project now where i dont only play the beats, but also the bass now... so i need a loopa.... when i buy a kit without case: is there a describtion to place the right LED-Leg-Length - in order to build the ready soldered pcbs into a metalcase later? thx 4 advice -
i am working on @Antichambre dipcore... on other platforms (OSX) its working... on Linux from my side - i always have problems to set it up.... i remember: my environment variables and path is: the toolchain is in here: make --trace return me: Antichambre & Me teamviewd half yesterday but didnt find out... ...maybe someone can lead me in the right direction. thx
can underline this... a big SMD make less work then THT (when thinking on the BLM 4148 leg bending actions...)
dont matter - there are IN and OUT Lines, and they are connected thru the PCB... but put the DIN first, since it senses - and therefore it is more "sensible"
Thinking about designing my rackmount SID again...
Phatline replied to m00dawg's topic in MIDIbox SID
i also like rackmount more... you can port eagle to kicad ... search for the script "Eagle2Kicad-master" from the readme: i have sucessfully made pcb, sent the gerbers to china, and got them without failures... kicad is cool -
beeing creative in the garden ... machete me and urzeitcode.... you are flying here? and the wing in front is this also human or visa versa?
The HAARP Desktop case prototyping.
Phatline commented on Antichambre's gallery image in Members Gallery
@Antichambre : @Dipcore thx... @Case: I have UI-LEDs specially to lighten up the PCB - to Read the Labeling on it, so the Frontpanel will be Transluent. And i will make a DIY Wooden Case for the prototype - and document the Measurements, after that i have more an Idea how a Alu-Case could look... but looking on the size it would be more logical to use IRON --- heavyness... so not a real plan @ the moment @english: mine too... if i have spoken German or more Austrian, than the video hasent take 19 minutes ;) . maybe Subtitels next time ;)
- 27 replies
- 1
- cc-recorder
(and 1 more)
Tagged with:
