1,285 -
72
Everything posted by Phatline
yes it works:
cant wait to start soldering. nice one.
i got a message from FORMULOR: I dont get the product up to now, so i cant proove that, i let you know... BLM_spacer_3mm_Formulor.eps
i dont find the the link to the button spacer? monoko? BOM? Help. edit: found it in the first post.... *`.eps
surved thru it, heard some of your ohter stuff, i like "NinetiesRaveExtravaganza because like those poly sounds, cant identify with monolead sounds.
check what out, i cant see a link! (ubuntu, firefox browser)
BLM 16x16+X PCB and case order [CLOSED/waitlist]
Phatline replied to latigid on's topic in Bulk Orders
got mine! light and beauty! ...in my dreams a few weeks ago i saw a some mushrooms in the wood, suddenly i saw a 16x32 blm on a dirty wodden desk, the set arround was a dessert party place, but the blm was still playing... in this moment i saw a woman and i decided to follow her... thx -
got mine. thx! -
für die dies verstehn...einfoch des o und das e gegen ein a austauschen >>> Österreich ;) das konzept hier nochmal erklärt.
very cool idea...to get some main beat grid for fitting lyrics (e.g. Hip hop)
ja ja jaaaaa! -
My experience with the pcb manufacturer 3PCB.com
Phatline replied to AndyJott's topic in Miscellaneous
5x350x350mm=233USD...ok good price...wtf how? ok i know how china... yes start such a synth on this platform... because i dont know how to , but i like to watch and learn from... (grabbing the code) cheers. Edit: did you paid "zoll" (landed cost)??? evertime i order pcbs from smash tv (america) i pay "zoll" (to Austria) past week i paid for a 160$ order 40€ "zoll" -
1st electronic labor jam made with some parts of an old SIEL-E-Organ > spring reverb/driver > amp > filters also a rose-crystal coil - transducer, which also act as a lopass filter when hold over a spring reverb... korg electribe rythm and mbase...straight outha my electronic labor 3rdRootsJam a midiboxified CRUMAR Model 198 e-organ triggerd with a kord electribe rythm... the program on it is the triggermatrix. straight outa my sun room, more info about that in this forum article: crumar-198-electrical-organ-midification-triggermatrix
so then 32x
ok then reed relais - thankz folks.
you see right, but, thats also for some play-automatic thing which pcb´s i already trashed. the bass working great with only the middle row switch parts... ya reichelt: http://www.reichelt.com/index.html?&ACTION=446&LA=446&SEARCH=jfet&OFFSET=16&SORT=artnr&SHOW=1 or english: http://www.reichelt.com/index.html?&ACTION=446&LA=446&SEARCH=jfet&OFFSET=16&SORT=artnr&SHOW=1 but 2n 2p jfet > like i said > i know nothing about fet-types - is there a nother word for that 4channel type you suggested? I am interested in this because up to now it seems to be the cheapest solution.
yes i am sure... the other contacts are for rythm automatic, and autocord stuff... wich i completely replaced with my own things... @reed relais as describet here 1,54€x13= 20€ http://www.reichelt.com/SIL-7271-D-5V/3/index.html?&ACTION=3&LA=446&ARTICLE=27672&artnr=SIL+7271-D+5V&SEARCH=sil7271 max4066 =15€ 4N25 0,25€*13=3,25€ http://www.reichelt.com/index.html?&ACTION=446&LA=446 but i am doing hard to find a 2n 2p fet, and i dont have any expirence downside pipolar transistors
does it work? depends on price,16 up to 64
hi! Digital DC & Tranisostors: is there a change to clean that DC with a Capacitor? Transistor would be the cheapest soluditon it is not necessery to be DPDT.... it is also possible to hear all notes together (i soldered 2 "Notes" together and there is no problem), i could do that software side anyway (but i dont need it) 6VAC peak...: @ the end of the day i need 0.26V to drive Bass-Post-Amp, so it want peak. as far as i know from transistors is: that there is a BASE-Collector Voltage, even if there is no Voltage on the Emitter - so have a LEAK, i measured 20mv, which i alreaedy said - is hearable as silent bass (since the base is the bass-signal).... i was thinking to make a noise-gate circuit after summing all Bass-notes...but then i thougt when i summing all 13 Bass-Notes, with its 13 20mV leaks, it would be pretty loud, and maybe then i have to set the threshold to high...and also i will hear all notes together - of course the played note is louder then the other,there will be "hum" if i cant avoid the B-C-Leak. i searched for analog switch ic, and found this: MAX4066: http://www.mouser.at/ProductDetail/Maxim-Integrated/MAX4066CPD+/?qs=sGAEpiMZZMvbyeSUH4qH%2fNdIvyU6Oqzm http://www.mouser.com/ds/2/256/MAX4066-MAX4066A-72194.pdf ...i am looking for a lofi locost solution.... when i want it better i just connect my waldorf pulse via midi to the pedal. but 2.66€x5=14€... thats ok do you think the max4066 could do the job? optoisolators are to expensive (keep in mind there are x13notes)
i need some audio-switching in my crumars 198 organ, the bass pedal is just a analog switching matrix, which decides which note will be played... to bad that all 13 notes via AUDIO are going to the pedal, not the other way around (not:pedal send gates to oscillator...this: frequencedivider sends audio signals to pedal) i want to controll the bass section via midi... or better said via a doutmodule > 5V > sound, 0V > no sound. so i need 13 Dout Pins = 2xHC595, done i dont want to use releais to swich all the 13 audio signals... i dont have a problem with distortion... ( i thought of Transistors???) i want that it is quiet when the 595 is LO. the Audio signals are coming from a frequenc devider IC that sends out 6V Sinus, the orginal shematic sends that signal thru a 100K resistor, and it ends with an voltage @ 265mV.... and the worst: the "orginal shematic" i buyd is not identical with the reality i have in front of me... i thought of using a bc547, in a shematic like in the sid module... by feeding the emitter with the 5V from the dout-pin,... when i now switch the DOUT off (lo) or clamp it to ground, i get a Base-Collector voltage by around 20mV, which is enough to be heard.......a resistor @ audio-out from that circuit end up by lowering the loudness in hi-state... a played around with potentiometers to set up the bc547...not worked @all, i think i have problem, which i cant solve alone > thanks
64 clear transparent
