15,248 -
Debugging my core STM32f4 + diomatrix + fatar keybed
TK. replied to aurel33's topic in Testing/Troubleshooting
Fine that the module is working now! :) To align the MIDI notes, please search in the documentation for "note_offset" and "din_key_offset": http://www.ucapps.de/midibox_kb.html Best Regards, Thorsten. -
While reading your posting an idea came into my mind: the PIC device configuration (which comes with the MIOS bootloader) is preconfigured with a brown-out reset detection at 4.5V, which means if the supply voltage falls below this limit, the PIC will be reset, although it also works at lower ranges. I selected this high BORV setting to ensure, that for example an ongoing IIC EEPROM programming operation will be interrupted (by resetting the PIC) before the external device is outside the valid voltage range during power-off - this could lead to data corruption. But the BLM16x16+X doesn't access external EEPROMs, so actually the BORV could be lowered to 2.89V or even 2.14V Unfortunately this can only be done with a PIC programmer. Best Regards, Thorsten.
Notes shouldn't be wiped out as long as no key is played on the external keyboard. See also this video: https://www.youtube.com/watch?v=6gRD_GLHbJM Maybe this happened while you disconnected the keyboard, or changed the MIDI channel, so that MBSEQ didn't receive the Note Off events? Best Regards, Thorsten.
Does it make a difference if you replace the 8 100 ohm resistors by 220 ohm? 100 Ohm has been selected in the original circuit since the LEDs are driven from 3.3V pins - but in your case they are driven from 5V pins which could lead to these ghosting effects. Best Regards, Thorsten.
No, it won't help. The problem is, that the TPD has many DOUT shift registers, but only a single DIN shift register (as far as I remember). This results into an unbalanced serial output which leads to trouble when another module with DIN/DOUT registers (such as the BLM16x4) is connected. So - this kind of module will only work at the end of a serial chain, or with some buffering (and some luck) - it's a complex topic, I can't give you a fool-proven solution without further analysis (and I won't have the time for this anyhow... ;-) Best Regards, Thorsten.
Update: at the bottom of the MBHP_DIO_MATRIX page you will find additional pictures: http://www.ucapps.de/mbhp_dio_matrix.html Best Regards, Thorsten. -
Meanwhile I also think that something is wrong with the cables, resp. the sockets (but this is hard to determine based on the snapshots). The notch of the J8/9 socket on the core module should show to the outer border, the same for the DIO module. Here a picture: @Christian: can you confirm that the socket orientation of your board is the same like for the original MBHP_CORE_STM32F4 module? Best Regards, Thorsten. -
It makes sense to upload the MIDIO128 application to doublecheck, if the inputs are really not working, or if it's related to a configuration problem. By default and without any special configuration, MIDIO128 will send a dedicated note event whenever an input pin is connected to ground. Best Regards, Thorsten. -
No special setup is required on the MIDI router. I'm no keyboard expert and therefore can't give you reliable information how to connect this particular hardware. But from the firmware side I think the most simple tests are the following: - turn off scan optimization (as mentioned above) - input test: connect a short cable from Vs (ground) to I0 -> up to 8 Note On messages should be sent. Note Off messages will be sent when the cable is removed. Repeat this test for the remaining inputs (J3:I0..I7 and J4:I0..I7) With this test, no proper break/make scheme is applied, and in worst case inputs stay at break and won't sent a note anymore - so, reset the core before repeating the next tests. - output test: instead of connecting I0 to ground, just connect it to O7/O6 via diodes (O7=make, O6=break; break has to be activated first; make sends the note). Only a single note on/off message should be sent. This can be repeated for the remaining output pairs. Best Regards, Thorsten. -
Could you please check with the "testaoutpin" command if the control signals also go to the DIN/SCLK/FS pin of the TLV5630? (pin 2/3/4) - if this is the case, the problem must be on the AOUT_NG board. Check all supply pins (GND and VDD pins), something seems to be wrong there. If still no luck, we can't exclude that the chip is defective. Best Regards, Thorsten.
Added to the wish list Best Regards, Thorsten.
Problem happens when the MIDIbox SID firmware hasn't been installed on the slave cores. See also: http://www.ucapps.de/midibox_sid_manual_in.html CAN interface will only work if all connected cores actively listen to the bus. Cloning is only possible on further firmware updates Best Regards, Thorsten.
Separate Random Generator settings for each track
TK. replied to k2z3k0's topic in MIDIbox Tools & MIOS Studio
Hi, welcome on board! :) I added your request to the wish list. It's very unlikely that it will be available for MBHP_CORE_LPC17 because of reduced RAM, but it could be made available for MBHP_CORE_STM32F4 Best Regards, Thorsten. -
Turn off the optimization to ensure that all pins are scanned while connecting Ox to Ix pins: set kb 1 optimized off Best Regards, Thorsten. -
From the notch which is marked with a 1, count the pins counter-clockwise. You will notice that the 7th pin is marked with 7, which gives you the confidence that the 10th pin must be the 4th from the left side of the chip, counted downwards. Best Regards, Thorsten.
I added this to the other requests in the wish list - it will be some effort to integrate such a mode into the existing architecture and GUI, therefore a quick implementation is very unlikely. Best Regards, Thorsten.
At a first glance I don't see a configuration error. However, I think that this combination can lead to unstable SRIO transfers because of the high number of SRIOs and different chain lengths of the DIN/DOUT SRs. This would also explain, why the BLM acts strange. A prober solution to overcome this problem is MBHP_LINE_DRIVER: http://www.ucapps.de/mbhp_line_driver.html I don't know how exactly your hardware looks like, but if the TPD is close to the wilba frontpanel, then it's sufficient to connect the transmitter/receiver between TPD and BLM4x16 Best Regards, Thorsten.
This page describes how to format a SD Card from MBSEQ (sdcard_format command), and how to upload the right MBSEQ_HW.V4 file: -> http://www.ucapps.de/midibox_seq_manual_in.html Best Regards, Thorsten.
Currently there s no auto-save function, but by storing the patch the learnt messages will be persistent. This can be done from the DISK menu page (via SCS) or from MIOS Terminal Best Regards, Thorsten.
looks fine, the leftmost pins (smaller pads) are not used anyhow, therefore it's ok if they are missing. Best Regards, Thorsten.
Similar spacing like on the MBSID panel, this should work Best Regards, Thorsten.
- 40 replies
- MBCV
- illuminated encoders
(and 1 more)
Tagged with:
Does the voltage change at the TLV5630 outputs (pin 12, 13, 14, 15, 6, 7, 8, 9)? See the schematic to find the outputs: http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=seppoman:mbhp_aout_ng_r1_schematic.pdf The REF output might be interesting as well, it should output 2V once the TLB5630 has been correctly configured. You can re-configure the device in the MBSEQ CV Configuration page during runtime (w/o power-cycling the core) by selecting a different interface, and then AOUT_NG again. Last but not least: I just noticed that there is an integrated AOUT troubleshooting app in the MBSEQ firmware, which might help as well! Enter "testaoutpin" in MIOS Terminal to get the appr. help page Best Regards, Thorsten.
Hi Nico, on the SC line you should see a burst of 128 clock cycles each mS The RC line will send a short pulse before and after the SCLK pulse The SO line will output the patterns during the SC burst. The SI line should send a pattern during the SC burst. It's all-1 if no button is pressed. Testing with a scope is rel. simple: just ensure that the SC and RC signal is visible on all 74HC595/165 CLK/LD inputs. And check that the serial inputs and outputs transfer the pattern. If one of the chips doesn't output the pattern, it's either because it doesn't get a pattern at the input, or because a short/power problem at this IC (in worst case the IC is defective, but this would be unusual). Schmitt Trigger: immediately forwards the input data. If you don't see any toggles at the outputs, it's related to a short/power issue. Best Regards, Thorsten.
Ok, this version also supports LPC17: http://www.ucapps.de/mios32/midibox_ng_v1_033_pre20.zip Best Regards, Thorsten.
Alternative solution: http://midibox.org/forums/topic/19761-sd-card-reader-3m-alternative/#comment-172182
