LO
370 -
Everything posted by LO
hasn't he appeared in a few movies as a stunt double for N.C.? ;) A man of many talents
Hi The following is something I have noticed in midiox that only happens when using midibox link, When I plug a single MB in it works fine anyone else experienced this? or know how to stop it? peace LO BTW: im only moving one pot but as you can see several other values keep appearing? ===> MIDI-OX Version: 6.5.1.346 ===> Log Opened: Wed 25-Jun-2003 23:27:01 ===> TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 00022612  1  --   B2   4A   54   3  ---  CC: Brightness     00022616  1  --   B2   4A   55   3  ---  CC: Brightness     00022620  1  --   B2   4A   57   3  ---  CC: Brightness     00022624  1  --   B2   4A   58   3  ---  CC: Brightness     0002262C  1  --   B2   4A   59   3  ---  CC: Brightness     00022630  1  --   B2   4A   5B   3  ---  CC: Brightness     00022636  1  --   B2   4A   5C   3  ---  CC: Brightness     0002263E  1  --   B2   4A   5D   3  ---  CC: Brightness     00022642  1  --   B2   4A   5E   3  ---  CC: Brightness     0002264C  1  --   B2   4A   60   3  ---  CC: Brightness     00022650  1  --   B2   4A   61   3  ---  CC: Brightness     00022658  1  --   B2   4A   62   3  ---  CC: Brightness     0002265A  1  --   B2   4A   63   3  ---  CC: Brightness     00022660  1  --   B2   4A   64   3  ---  CC: Brightness     00022660  1  --   B0   07   3B   1  ---  CC: Volume       00022664  1  --   B2   4A   65   3  ---  CC: Brightness     00022668  1  --   B0   07   3C   1  ---  CC: Volume       0002266C  1  --   B2   4A   66   3  ---  CC: Brightness     00022670  1  --   B2   4A   67   3  ---  CC: Brightness     0002267B  1  --   B2   4A   69   3  ---  CC: Brightness     0002267F  1  --   B2   4A   6A   3  ---  CC: Brightness     00022683  1  --   B2   4A   6B   3  ---  CC: Brightness     00022689  1  --   B2   4A   6C   3  ---  CC: Brightness     0002268F  1  --   B2   4A   6D   3  ---  CC: Brightness     0002268F  1  --   B0   07   3B   1  ---  CC: Volume       00022691  1  --   B2   4A   6E   3  ---  CC: Brightness     00022697  1  --   B0   07   3C   1  ---  CC: Volume       00022697  1  --   B2   4A   6F   3  ---  CC: Brightness     0002269B  1  --   B2   4A   70   3  ---  CC: Brightness     000226A9  1  --   B2   4A   72   3  ---  CC: Brightness     000226AD  1  --   B2   4A   73   3  ---  CC: Brightness     000226AF  1  --   B2   4A   74   3  ---  CC: Brightness     000226B9  1  --   B2   4A   75   3  ---  CC: Brightness     000226B9  1  --   B2   4A   76   3  ---  CC: Brightness     000226BF  1  --   B2   4A   77   3  ---  CC: Brightness     000226C3  1  --   B0   06   50   1  ---  CC: Data Entry MSB   000226C7  1  --   B2   4A   79   3  ---  CC: Brightness     000226D1  1  --   B2   4A   7A   3  ---  CC: Brightness     000226D9  1  --   B2   4A   7B   3  ---  CC: Brightness     000226E3  1  --   B2   4A   7C   3  ---  CC: Brightness     000226E7  1  --   B0   06   51   1  ---  CC: Data Entry MSB   000226EB  1  --   B2   4A   7D   3  ---  CC: Brightness     000226F1  1  --   B2   4A   7E   3  ---  CC: Brightness     00022707  1  --   B2   4A   7F   3  ---  CC: Brightness     00023173  1  --   B2   4A   7E   3  ---  CC: Brightness     00023189  1  --   B2   4A   7D   3  ---  CC: Brightness     0002319D  1  --   B2   4A   7B   3  ---  CC: Brightness  Â
AKL New Zealand ::)
Hey thanks for the reply I'll try and hold out...... at the moment im opening the case up and unpluging/pluging the LCD every time I wish to switch! As far as the MB_link goes Im having some trouble with random data showing up in midi ox i.e when the boxes are connected seperately they are working well but when I connect via MB_link and turn a knob the data looks pretty good in midi-ox except for a random note or two showing up. ill try and do some screen dumps later Also TK did you ever have any luck getting V-midi-box to work with MB_link? TIA LO
'ello Any info on how I might do the following would be appreciated. In one box I have a MB64 & also a MB_SID but only room for one LCD, I would like to be able to switch between the modules (would be nice but does not need to be a "hot" swap) The MB64 is connected to the LCD and the "data" lines from the SID could be connected to the lcd but diconnected by a switch? Which wires going to the LCD from the modules do I need to have it switchable? Does this make sence? ??? LO
DJ Cam does some nice tracks with some French MC's Also DJ Vadim (ninja tunes) has some cool guest MC's who are jammin in French I'll try to check out your recommendation is there any albums I might find at the record shop?
Some of the best hip-hop ive listened to is in french! :)
isnt an "AT" Power Supply a switching p/s?
you dont have to use encoders as traktor supports soft take over (as does MB64) LO
you will be wanting velocity sensitive pads? not so easy i think LO
Cubase SX is a completely new prog unlike any previous ver of cubase dont compare it till you have tried it :D
Rather than using low power LEDs I think you can just use a larger value (or extra)Resistor?
Muska Lipman publishing: Cubase SX Power Book by by robert guerin If your serious about learning Cubase? you should check it out
What's wrong with you clowns? ;) Mine work real nice! PIC16F stays where it is for now I think after reading all the above probs Sorry I know that post didnt help no-one
you crack me up dude ;D
grrrrr.. grumble..... grumble.... shuddup  Ian just cause your a ........wanna-be mios geek 18F and SID workin real nice 18F and motor faders couldnt even get then to move! So ive gone back to the 16F for a while so I can actually use this thing thats taken so long to build! its great I will go back to the 18F just not yet, cheers for the offer tho XP pro, Cubase SX
I like your stuff...... very "live" sounding! good to see some fellow hiphop fans in 'ere I wish I could understand your language :-X
Yeah I have an old(ish) terratec EWS64 and a SB Audigy the terratec has good quality sound and plenty of features + ASIO2 drivers t work nicely with all software although this may have been fixed with their newer cards. Many people complain about the audigy but I find it an excellent all round card it has ASIO drivers with reasonable performance and very compatible!
Good luck... tho i doubt the pots out of an amp will be of a useful ohms range?!
hmmm must be an 18F thang?? my panasonics are sweet (no buzzing) on the 16F Im still too scared to try the 18F again
that all depends on how many parameters you wish to control at once I would recomend a min of 8 channels (faders) with min of 1 pot & 2 buttons per channel You will always want more than you have so.... get as many as you can afford!
mmmmmmmmmmm.........mmm.... oh sorry I think i just ..... :o
Oh yes im very wise when it comes to electronics: :-/ where there is a #1 I colour in red #2 I colour blue I think they call it "paint by colour"
hi You dont need the 16E version for traktor standard pots work just fine as it has a soft takeover function and you dont normally need more than 1 bank. Almost all functions in Traktor are learnable (just check the control menu for details on what can be controlled) be sure to include plenty of push buttons start/stop etc etc might be best to go for a cut down version of MB_64 I use this and it works well. LO
Hi Resistors: probably not worth it as they are very cheap! Caps: your better off with new ones as they can be difficult to test Pots: yeah 2nd hand is good Switches: yip good Leds: no problem there either Sorry I dont have a resistor value chart handy but they should be easy to find? LO
