monokinetic
Programmer-
326 -
5
Everything posted by monokinetic
Quite a while back I worked into the pyBLM code to get it to work with Launchpad Mini mk3s. I must confess it has sat unused for way too long, I mentioned it being ready to Borfo like 3 years ago! But I have revived the computer it was on and done some testing, it seems pretty OK so I have decided to push a fork here: https://bitbucket.org/monokinetic/pyblm Having refreshed my memory of the changes I had to make, I should note that for my fork: this is designed for Launchpad mini mk3 only because the MIDI messages changed. I don't have any mk2 to combine with my mk3s to test this. Use Borfo's original if you're running Launchpad mini mk2s. I've tweaked the code to recognise the latest MBSeqV4+ on STM32F4 core. It might not work if you use a different set up. Major props to Borfo for providing this. Without the original start I would have never been able to wrap my head around it FWIW I use it on macOS Ventura. To get the libraries to work I needed to: Install pipx. Then use it to install the dependencies listed in the README. Get macOS to use the virtual environment with: python3 -m venv ~/.local/pipx/ Activate the pipx env with: source ~/.local/pipx/bin/activate Then run the script with: python3 pyBLM.py A more experienced Pythonista might advise you otherwise, but it worked for me..... Hopefully this will enable others to enjoy the lightshow one day!
Cool, good to know you got it sorted!
That behaviour could be explained by PSU being overloaded (i.e. box runs, functions OK, but then stops as PSU can't handle the overload). How are you powering things? Does the regulator get hot (careful when touching, they can get very hot!)? etc Also, it might be useful to provide info like: - which bootloader you have on the PIC? - which operating system are you using on your computer? - which version of MIOS studio are you running? and so on. Good luck!
MBSeq4 kit sold today!
Darn, I was hoping to do the same. Shame to hear it's not working with the updated firmware. I don't have any Launchpads, yet. But as a matter of interest I had a quick look at the code. At a guess, this line here: seqregex = re.compile("MIDIbox SEQ V4:MIDIbox SEQ V4 MIDI ([1-4]) [0-9]") Needs to be updated for the new v4+ firmware. Have you tried editing it to: seqregex = re.compile("MIDIbox SEQ V4+:MIDIbox SEQ V4+ MIDI ([1-4]) [0-9]") i.e. just add the + symbol two times to match the updated name you posted in the output of mido.get_input_names(). Not sure how you tried to modify the regex, but that would be my first thing to try! Oh and you might find that the + character confuses the regex, so if that doesn't work, try using a \ before each + which you add. So it looks like this: seqregex = re.compile("MIDIbox SEQ V4\+:MIDIbox SEQ V4\+ MIDI ([1-4]) [0-9]") Hope you get it up and running....
Still available, talk to me :)
Do you mean the original STM32F1 based core: http://ucapps.de/mbhp_core_stm32.html or the more recent STM32F4 based core? Compare: http://ucapps.de/mbhp_core_stm32f4.html I maybe have one of the STM32F1 boards, not stuffed, available. I can only confirm on Friday this week as I'm travelling....
Hi there, no sorry, this is the stuff which is specific to building the MBSeq. If you would like to discuss maybe send me a direct message? Cheers, David
@TK. thanks for the tip re: storing the values in the DEFAULT.CV2 file, yes that is much easier. My encoders thank you :) FWIW I tried this calibration stuff a bit more: something really seems weird with the way values are entered. For example, if I set cali to 5V and try to set the offset, I can scroll up to 255 and then it jumps down to -3840. I see the same with changing the value to 0xffff in the defaults file. Is that expected? If it helps, this is what MIOS_Studio shows during those 3 clicks of the encoder to the right: [1164.130] value=f000 (with x0=d800 x1=f000 y0=d800 y1=f000) -> result=ffe0 (offset value shows 254) [1164.690] value=f000 (with x0=d800 x1=f000 y0=d800 y1=f000) -> result=fff0 (offset value shows 255) [1165.852] value=f000 (with x0=d800 x1=f000 y0=d800 y1=f000) -> result=0000 (offset value shows -3840) I have done quite a bit of testing now with Cali out, I can provide more info but I don't want to bombard you all the numbers I measured if this is expected behaviour :) In the meantime, I have now found a way to get the output I expected from MBCV. My steps were: on Default page, channel type must be set to something other than Note, in my case I use CC. Otherwise it impacts on the output, regardless of any MIDI note ever being actually received. This really got me for a while :) on CV out set LFO1 to Sine, reasonably slow rate, with amp 127. Only then can I get reliable level, i.e. 0 to ~10V. I have various other notes from my studies of MBCV recently. I will write them up more once I'm sure of some things.... Cheers, I'm having a blast with this so far. Can't wait to get my scope LCDs hooked up so I can put my multimeter away ;)
Using a fresh compile of master from Github to try out that amazing v4.96 feature set, I tried to set a track to control an AOUT using the LFO as mentioned recently. Indeed assigning the extra out sends the LFO to the AOUT, excellent another source of modulation! But on my set up (unipolar original AOUT) the output seemed weird. For example, when I first turn on the LFO effect, and set the output to sine I get a triangle. Then changing through the waveforms gave me just lower volume versions of the wave, it seems to be a saw. Having seen this on the scope, this made me go back and check the output via MIDI CC and it seems the same. If it helps, I have experimented with amp and offset. I expected that with both set to 64 I should see the full waveform, i.e. triangle going from 0 to 127. But what I see seems weird to me! FWIW both the AOUT and the CC seemed to have same behaviour. Let me know if you need more info or the session sending :)
Follow up having used the same hardware using MBSeq4 app: I'm not totally sure the calibration process will solve this. I tried the MBSeq outputting CC0 to 127 to an AOUT channel. That generates the expected voltage, without me changing the calibration of the AOUT at all. It feels to me more like I need a way to tell MBCV to double the final level of the CV output. In the process I also found something new, which I will post in the MBSeq main thread.
Excellent TK! Many thanks for taking this on :) I have pulled from Gihub, compiled and had a bit of a play with it. So far I see some things which seem weird to me: the "Cali" list of options seems in the wrong order. For me it goes - Off, Min, Middle, Max, Wave, -4V, -3V, -1V, 3V, -5V (at this point offset becomes editable), -4V, -3V, -2V, -1V, 0V, 1V, 2V, 3V, 4V, 5V, Max: (with offset, unlike earlier Max value). Is that expected behaviour? When I select 5V from above list and try to change offset, as I scroll up it seems to jump down to -3840. Which is not within the range you mentioned (between -2048 and 2047 right?) Anyway, seems like it's close. If it helps, my testing process is to set a CV channel to output the triangle from LFO 1, set the rate reasonably slow and then the -CV output of LFO1 to 127. Also, how do you recommend to set the offset values if I want say the triangle wave LFO sent to CV with level 127 to range between 0 and max voltage (i.e. ~10V)? I had planned to set 5V to maximum offset, but wasn't sure how to proceed after that! My guess is that I set -5V with offset to output 0V, 0V to output ~5V and 5V to output 10V. Is that the idea? Oh and final suggestion: would it be possible to support the new caliaout at the Mios terminal i.e. in MIOS Studio? I ask because the way the offset jumped, now to reset I have to scroll a long way. From memory, MBSEQ stores these calibration values on the SD card. Does MBCV do the same i.e. could I just tweak the values on the SD? Thanks muchly in advance :) David
Hi there Thorsten, aha yes I remember the new calibration stuff, it'd would be great to have in MBCV as well..... If you would be able to do it that would be an amazing new year's present, I had a look last year and it seemed a bit complicated for my skills :) But I'd gladly do some testing on both apps! Cheers David
Hi folks, I've been using MBCV2 for a while now and I always felt like it wasn't working quite right with my synth. I went back to it this weekend and think I understand the problem now, indeed MBCV is not outputting full range CVs for me. I'm running an STM34F4 based standard core with an AOUT. I'm not using the "Balanced output extension" as mentioned on ucapps.de because my synth runs unipolar CVs in a range of 0 to 10V. When I use this setup with MBSEQ4 to run CVs I can output CC 0-127 and get 0-10V, so I know my hardware is good. Now, when I run MBCV2 and say for example assign an LFO to CV out 1, what I get is a 0 to approx 5V output. I think the reason is that MBCV2 assumes that the AOUT is set up with the "Balanced output extension". I base this theory on the fact that I can tweak the mod matrix to force the LFO to a full range CV by setting offset high. I realise I could probably set up the opamp output stage of the AOUT to handle this (double gain I guess?), but I'd prefer a s/w solution :) So I was wondering if that is correct, and how I could tweak the software to support unipolar AOUTs such as mine? I think a compile time option would be enough, or maybe the AOUT driver could be extended to have an option to represent unipolar vs bipolar set ups? Thanks for reading! David
New eurorack modules from midiphy - preview
monokinetic commented on Hawkeye's gallery image in Members Gallery
Interesting to read that you have had problems based on the power. FWIW I have been running mine inside of a Buchla clone which is using a pretty nice PSU and I haven't noticed any big problems. But this does make me wonder if the AOUT would benefit from a better output stage, those fancy DACs deserve the best IMO! I would probably use something similar to the ornaments and crime: https://ornament-and-cri.me/schematic/ has anyone tried such a thing? Or any other suggestions? :) -
Still available, almost no effort required to build an MBseq with this stuff :)
FWIW I use Lemur on an old iPad v1 and use it for the BLM of the sequencer, and with the MBSID. That communicates over OSC, is rock solid and make me think that going the SPI i2C route would be unnecessary. Only thing is that requires you using a computer to to go USB MIDI -> OSC -> Lemur. I might go computer free at some point using Midibox + an OSC interface, but so far things work so well and I given that I always end up having a computer on to capture MIDI and audio from my jams that it seemed like if it's working I'll get on with making some music :) Maybe before you complicate things trying to communicate using an internal bus, give that a try? Just a suggestion!
MIOS8/32 repositories now hosted at Github
monokinetic replied to TK.'s topic in MIOS programming (C)
aha excellent, I agree that this should make collaboration easier.... Heheh, define easier ;) I'm no Git expert, but if it helps, here's how I'd imagine doing things: Make a directory for this repo i.e. cd ~ mkdir mios_stuff cd mios_stuff Clone the repo to your local dir: git clone https://github.com/midibox/mios32.git Let's check to see which branches are available in the new repo: cd mios32/ ~/mios_stuff/mios32$ git branch -av * master 79292db corrected comments in source_me_* files remotes/origin/HEAD -> origin/master remotes/origin/feature/juce_5_4_3_migration 5e8148f MIOS Studio: updated release script remotes/origin/feature/mcan b7b78c2 corrected mios32_* namespace remotes/origin/master 79292db corrected comments in source_me_* files I used the -av option to show all of the branches on the remote repo. Note the * by master, that shows which branch you have checked out at the moment. It looks like TK has set you up the feature/mcan branch. Let's assume you want to do some work on that, so switch to the MCAN branch like this: ~/mios_stuff/mios32$ git checkout feature/mcan Branch feature/mcan set up to track remote branch feature/mcan from origin. Switched to a new branch 'feature/mcan' Here is where things are a bit different to SVN. I'd try and explain it but you'd be better reading this: https://git-scm.com/book/en/v2/Git-Branching-Branches-in-a-Nutshell Then basically you can do your work, doing regular commits. Those go in to the branch you have checked out currently. Then when you are ready to share them with others you push to the repo, ensuring that your push goes to the feature/mcan branch. Eventually, once we know that everything you have done in feature/mcan is OK to add to the full mios32 then someone has to merge the changes in feature/mcan branch into the master branch. Then finally everyone can use MCAN and blow their minds with so many MIDI ports to play with ;) I also recommend looking up how Git stash works (I find that invaluable) :) Sorry for the slightly long post, and apologies in advance for things that a Git expert would tell you are wrong. But that's how I plan to use it so far! -
Hi folks, nice to know this info is of use to some! @Rowan I'm afraid both of my attempts at building an AOUT_NG failed so I gave up on that path. But yes to what Zam wrote, basically all I did was recalculate the opamp resistors. Don't know why it didn't occur to me years ago, but that's life :) Good luck with your builds!
As you probably know, the AOUT module is set up to support 1v/octave scaling, and that has been fine for me when I was using it with a Serge modular system. But I have been wondering how I could use my AOUTs with my Buchla-ish modular synth, which uses 1.2v/octave scaling. I contemplated building an opamp based solution, boosting the voltage a bit. But this seemed a bit of a hack to me, so I spent a bit of time understanding the opamp based outputs from the MAX525 DACs. I realised that by tweaking a resistor value I could get the AOUT to put out 1.2v/octave. I've tested this for a bit with two different oscillators (258r and 259r) and it seems fine for my uses. I'm no electrical engineer though, so if this mod blows up your rather expensive equipment I'm afraid you're on your own... That said, for any other Buchla users who want to use an AOUT to output 1.2v/octave, just change RY to 1.8K on any channels you want. That should give you the extra bit of gain required, and then you can trim it to 1.2v/octave. FWIW I usually use the MBSeqV4 app, then use the nice new calibration stuff to get things super accurate. I'm able to get submillivolt accuracy over the whole voltage range. Top voltage is obviously a bit higher in this case, almost 13v from my measurements. That seems to have been fine in my system, but YMMV. Also, I have set my AOUT so that V1-V4 have this tweak (1.8K for RY), and I use them for controlling Buchla oscillators. V5-V8 use the 2.2K resistor for RY still, and I use those channels for modulation CVs and to control the Serge oscillators which run at 1v/octave. All in all I'm most happy with this system and am glad I don't have to mess around with adding more circuitry. Hope that helps someone in the future!
Bump for the price drop to 325 Euros, that's a bargain!
