Twin-X
Administrators
    1,081
Everything posted by Twin-X
  1. My freund i have to dissapoint you. I can play notes without crashing. (i have to admit my sid is not 100% ready and i have mios 1.7) mpc4000 and sid is ok! Try a to do a factory reset (e.g. turn off autoloader if you have that.) set drum pad to keyboard set sid to channel 10 and hit the pads till you get dizzy. Worked for me so i think it works. But the mpc4000 software is totally diffrent from 2000 or 2500 series. So it stilll could be in that. Good luck!
  2. pwx sorry to ask this but you have the mpc2000xl and the mpc2500 and the sid does not work on both? I have a mpc4000 i will try tonight if the sid works yes or no. I have not tried it yet (have not touched my gear for 6 months now ;D). It are not similar machines but it is worth a try.
  3. Wat gaat iedereen maken eigenlijk? Ik weet wel dat ik nog 2 fm synths op de plank heb liggen en mijn quad sid is zo goed als af.
  4. HOUT? wel eiken he ;D laat zien dat ambacht nog leeft in NL :P
  5. Twin-X
    [B] SID 6581
    Hehehe no problem with that. Been the black sheep of the community since it's existance ;)
  6. Twin-X
    [B] SID 6581
    Deal if it has the springback and aluminum button. I will pay for shipping.
  7. Drooling allready ;D ;D ;D
  8. Are u sure you speak english ??? ??? ??? ??? ??? ;D ;D ;D ;D
  9. The tutorials are on wiki. Wiki is available but not filled yet due to a few errors in the past. Maybe someone on the board can help you with your questions. So feel free to ask them.
  10. Well sonic since you helped me on acidcode i gave you an applaud!! ;)
  11. Have you looked at http://ucapps.de ?
  12. Indeed that's a simple solution.I would reccomend links in signatures.
  13. You could always try vmware and make a test install. Try to see if your things work before migrating to x64. Usually when its on a serial port you do not have to worry about things. But i can't tell for sure. regards, Jef
  14. Yes this would be great for my Modular that is in planning stage too. Got a full board set of oakley modular 2 vco etc.
  15. http://www.youtube.com/w/Toshio-Iwai-%28TENORI-ON%29-%40-Artfutura05?v=WQq2aXvIsz4&search=japn http://www.global.yamaha.com/design/tenori-on/ I just watched it it is an amazing instrument controller :o :o :o :o
  16. Hello Carsten, Here is a wide disscussed link http://www.midibox.org/forum/index.php?topic=233.0
  17. You get the best results by doing the following. Create mark point Set drill in HI speed Set drill in reverse Do not be disturbed by plastic melting back on. After drilling you can scrape it off easy
  18. You need a minimum order of 150 Euro to order from them. Doesn't mouser have pots for you? It does not have to be radiohm. Maybe have a look at futurlec.com also cheap pots that are good. Brand is alpha. Edit --- Are you Jeff Farr on the SDIy list?
  19. May i ask what i have done wrong towards you?
  20. That lIve box is SIMPLY WOW!!! Keep it up it looks great! Who did the drilling? Or do you have your own cnc router for that?
  21. Sign up at the SDIY mailing list and ask the same question. I can assure you you will get tons of positive replies on elby designs material.
  22. please show us your dremel cutting tool. And my Italian is worse than your english. So do not worry about your English ;)
  23. misschien moet je eens kijken naar de allen heath xone 3d voor inspiratie.
  24. LOL And a happy B'Day from holland! Don't forget to eat lots of cake!!!! regards, Jeffry
