pay_c
Frequent Writer
    1,468
Everything posted by pay_c
  1. pay_c
    MIDImerger
    You can do whatever you want. You can use the Core (also there´s much more on there than you need for the Merger) - but also can build it up on breadboard. The second optocoupler is not on the core already! You have to put it there by yourself. Best you put it next to the second MIDI Input on some small breadboard piece or so. Greetz!
  2. Little thing: The SID needs 12 Volt @ very low current. So it should be no prob to get the 18 Volt down to 12 or 9 Volt without to much heat (heatsink really not needed!). So, if you can´t find any solution, just forget it right now and go on. And: 10 kOhm @ 18 Volt is not really a "Load": That´s just 1,8 mA... The voltage will go down with some more current (@ about 50 mA) for sure. Greetz! :)
  3. Little thing: The SID needs 12 Volt @ very low current. So it should be no prob to get the 18 Volt down to 12 or 9 Volt without to much heat (heatsink really not needed!). So, if you can´t find any solution, just forget it right now and go on. And: 10 kOhm @ 18 Volt is not really a "Load": That´s just 1,8 mA... The voltage will go down with some more current (@ about 50 mA) for sure. Greetz! :)
  4. Counting the Seq: 2x LCD backlight appr. at 200 mA = 400 mA The whole schematic (including core, DIN´s, DOUT´s): about 50 mA - 100 mA LEDs: from 0 up to more than 300 mA (!!) So with the Seq you´re some good kinda over the 500 mA. Greetz.
  5. Counting the Seq: 2x LCD backlight appr. at 200 mA = 400 mA The whole schematic (including core, DIN´s, DOUT´s): about 50 mA - 100 mA LEDs: from 0 up to more than 300 mA (!!) So with the Seq you´re some good kinda over the 500 mA. Greetz.
  6. OK. That´s good, as you bring in a little more precision by using PCB mounted stuff automatically. So I would try 19x19 mm. That´s 0,3 mm on each side, should be ok. If you´re not sure, just go up to 0,5mm on each side (would be 19,4x19,4 then). Greetz!
  7. OK. That´s good, as you bring in a little more precision by using PCB mounted stuff automatically. So I would try 19x19 mm. That´s 0,3 mm on each side, should be ok. If you´re not sure, just go up to 0,5mm on each side (would be 19,4x19,4 then). Greetz!
  8. That´s more or less a opinion of yourself. I always use something like 0,5 mm up to 1 mm (depends). Roughly you can say something like 5% up to 10%. Are your buttons frontplate mounted or on the PCB? Greetz!
  9. That´s more or less a opinion of yourself. I always use something like 0,5 mm up to 1 mm (depends). Roughly you can say something like 5% up to 10%. Are your buttons frontplate mounted or on the PCB? Greetz!
  10. Wenn der genauere Termin da ist, bin ich wahrscheinlich auf jeden Fall dabei. Bin halt jetz noch bis Mitte September/Oktober voll in meiner Diplomarbeit eingespannt, danach bin ich definitiv dabei und würde mich freuen. "The God" TK in life... ;) *huldig* thnx für die Orga!!
  11. Wenn der genauere Termin da ist, bin ich wahrscheinlich auf jeden Fall dabei. Bin halt jetz noch bis Mitte September/Oktober voll in meiner Diplomarbeit eingespannt, danach bin ich definitiv dabei und würde mich freuen. "The God" TK in life... ;) *huldig* thnx für die Orga!!
  12. I know these will be stupid questions, but I´m expert at questioning stupid questions... ;D - You did do the hardware mod for MIOS, did you? - What current goes in there (measure it), when you have disconnected the DOUTs? That´s important! Should not be above 300 mA without LEDs - Do you have your Backgroundlight Pot to the max or some middle point? Put it to some middle if you don´t have already. - What Cap do you have before the 7805? 2200 uF? 1000 uF? - Is the Optocoupler in there the right way? It´s not the same way as the PIC is! Just still hoping, cause 100 people used this setup and it works without any Caps on the 165s. Greetz!
  13. Ich auch... ;D ;)
  14. Evtl mal ne ganz andere Art an Abhilfe (so funzt des WIRKLICH hundert pro) - abgesehen davon, daß ich mir auch nicht ganz sicher bin, warum das bisher nicht so läuft - tippe mal auf Antenneneffekt oder sowatt. Egal: Nimm einen Taster mit zwei getrennten Kanälen (also einer zu, der andere auf wenn Taster auf und wenn Taster zu der eine auf und der andere zu .. wenn du verstehst, was ich jetzt mein...). So, jetzt packst du den Taster zwischen Faderabnehmer und AIN - den einen Eingang direkt auf den Fader, den anderen auf 5 Volt. Damit hast du dann eine komplette, galvanische Trennung und damit Absicherung. Hier nochmal zur Klarheit: __ | ------------(Faderkanal) / AIN- ------------(+ 5 Volt) Dann muss es klappen. Du klemmst den Fader damit komplett vom AIN ab und gibst Ihm lediglich +5V als Eingang. Einziges Prob: Der Taster prellt natürlich ein wenig zwischendrin (ca. 1-10 ms), aber das sollte bei träger Lichtsteuerung kein Prob darstellen. Viel Glück - hoffe des funzt. /modify: der haut mir mei schöne Zeichnung voll durcheinander... super... Vergiss die Zeichnung, ich glaub, du verstehst, was ich meinte.
  15. Did you check how much current your whole thing needs? It´s quite unnormal that the LEDs start to flicker, also the LCD flickering is normally some less current/power. The 7805 does get hot, but not touching it anymore? That´s heavy... forget the 7809 thing. You go in with 9 Volt, so you don´t have to go down to 9 Volt with the 7809... The maximum (I can imagine): 7805 = (9 Volts - 5 Volts) * 500 mA = 2 Watts heat That is pretty much indeed, but with a heatsink, this shouldn´t be the prob. I guess you still have some short somewhere in there... btw: The prob with the button? ... ... no idea ... :-[
  16. Öhm... ich mein ja nur, aber das ist komplett unabhängig vom Betriebssystem. Du steuerst den SID (so wie (fast) alle Synthies/Controller usw... ) über MIDI an, d.h. dein Comp muss halt nur über MIDI verfügen, das Betriebssystem ist da wurst....
  17. Yeah, should be oki. As long as the LCD comes up, everything should be alright. The enc will change some option (no matter where it is). The button and the LED should be at some good place (so if you push the button the LED comes up e.g.) - check the DIN/DOUT schematic for that. Greetz.
  18. Check your main.asm - there is stated something about configuring the Encs. I think the file you have to modify is the mios_tables.inc or so. Somewhere there are all the Encs stated together with their modes. There are 3 modes, you have to use the Detended2 one. Should work. Greetz
  19. Yupp. Just one thing: I tried the same with my SID setup. The noise (humming 50 Hz) was pretty loud. Consider using TK´s PSU recycle for the "power board". It has much more than enough power to supply more than just a 4x SID. Greetz!
  20. Also mal als grobe Faustregel: Der 7805 hält ohne Wärmeabfuhrfahne etwa 1,5W bis 2 W maximal aus. Mit Fahne dann nochmal etwa 2,5W bis 3W (absolute Obergrenze - eher etwas zum Spiegeleier braten). Wieviel Watt du in Wärme abführst kannst du ungefähr (Daumenregel) so berechnen: (U rein - U raus)*(I raus) = Leistung d.h.: 35 Volt - 8 Volt = 27 Volt (sagen wir mal 30 - besser rechenbar) bei 10 mA Ausgangsstrom musst du also nur 0,3 Watt abführen, bei 100 mA aber schon 3 Watt - glüh. 500 mA: 15 Watt - Glühlampe. Es kommt also auf deinen Ausgangsstrom an. Du kannst z.B. stufenweise runterregeln: 35 Volt auf z.B. 7824 (bei 500 mA aber immer noch 5 Watt!!!) auf 7815 usw... die Elkos dazwischen halt nur einmal einbauen. Ist aber bei deinem Fall ganz schön hart: Was du da an Leistung wegfezt ist bös. Andere Möglichkeit: Schaltregler. Aber: Brummspannungen usw. Echt jetzt: 35 Volt auf 8 Volt runterzuhauen ist hart! Was du da alles wegnimmst! Warum nicht einfach ein kleineres Netzteil kaufen? Die kosten 5.- bis 10.- wenns hoch kommt. Oder von irgend einem alten Gerät das Netzteil klauen! Na? :)
  21. Geh mal zur Sicherheit das Debug von MBHP durch. Ansonsten: Vorher mal den 18F "formatiert", d.h. komplett gelöscht? Verify während *und* nach der Programmierung an? Gruß pay.c
  22. I got it from a company in Berlin. It´s called "Modulor". They got very good prices, although you have a minimum order value . But they got so much stuff, it´s no prob to go beyond (and if you just get some more alu as intended). Cool thing: They got their *WHOLE* catalog in paper form for ordering *AND* as .pdf download! Only the online ordering form is a little wrecked. But not too bad. Here´s the webpage: http://www.modulor.de/ Greetz!
  23. Hi there! The bankstick automatically would get formatted if inserted. That´s implemented within every MIOS application. Ask me why this is like that, but the 24C is NOT compatible to the 24LC! It´s just pin-compatible, which means nearly nothing... Just get your 24LCs as samples directly from Microchip for nothing (up to three are possible). Greetz!
  24. Hey! Really nice! Cool thing! Some nice ideas implemented in there (e.g. the play button! ;D). I also like that all silver design! 8) :o
  25. Cool, new flat. Have fun there, TK! Till September or so then!
