nebula
943 -
4
Everything posted by nebula
From newbie to wizard: Max's PG-300/MB synth programmer project
nebula replied to Max Romantschuk's topic in MIDIbox HUIs
Well it's an issue for me! ;) (just kidding) FWIW I find the hardest part of any DIY electronic project to be enclosures and panels. You are going to need to determine the route you want to go: board-mount or panel-mount pots/encoders/switches. Both techniques have their pros and cons. You're documenting this really well so far. It's looking good! -
Wow, this guy has put a lot of work into this. Looks like it could be a lot of fun when it's done. The web page already is.
For testing and choosing resistors, why bother with the PCB? Just poke them through the panel.
I added 2 more, for 4 (2 MBSID, 1 C64, 1 spare) 35 to go!
In no particular order ... DIY/techy Stuff: Complete all my partly done MIDIbox projects: 2 sequencers, MB-CV, MB-FM, simple stereo 6581 MB-SID. Build a second x0xb0x. Put shorter ribbon flex cables in my MB-6582 so I can put the damn case together! Finish mods to the first Korg DW-6000, and steal the filter board from the second DW-6000 and get it working with MB-SID. Complete repairs to CS40M. Music stuff: Finish my tech-house-ish album that has been several years in the works. Convert my live set to be less laptop-based and more based on standalone, tweakable tone generators and sequencers. Life stuff: Seriously re-evaluate my lame-ass daytime career. Make my wife happier. Really nerdy stuff: Lay foundation to a MIDIbox builders/users convention.
Put it here: http://www.midibox.org/dokuwiki/doku.php?id=dougwellington_mb6582_powersupply_bulk_order
Your panel is just insanely gorgeous. I love it. The Novation knobs in the first pic look really cool ... it would be really tempting to figure out a way to stick some frosted acrylic underneath the panel, peaking out from behind the knobs. You could light it up, creating a little illuminated halo around each knob. (But that would be a lot of very tedious work). I've got the "Waldorf" knobs on my MB-6582, in grey. I find the grey ones a little "tamer" than the white / red ones you see in a lot of pics. The nicest ones IMHO are on Wilba's prototype, and are sadly no longer available.
Also consider participating in this bulk order. The C64 PSU is a very elegant solution. It works very well.
I just etched a couple of OPL3 boards. I was planning on populating at least one next week. I'll let you know how it goes.
FLUX!
I now have a working x0xb0x! Peeeeeeooooooowwwww!!! ISSUES 1. I had 10 mm spacers. I filed them down to 8 mm. They are not perfect, so it my panel is still slightly uneven. It's hardly noticable, but it is there when you look for it. I'll be buying some new spacers. 2. I think my square wave is a bit too sine-y. Back when I built the VCO the square didn't have that nice sharp point at the beginning of the cycle, it was slightly more rounded than the Ladyada oscilloscope screen shots. My square doesn't sound as bright as I think it should, and this is probably why. I'm going to look at Q8, C11, and some stuff around there. I don't remember right now, but I may have subbed a Tantalum in for C11 and some of the 1 uF caps instead of electrolytic. BUILD TIPS: 1. First, let me repeat: MULTI-TURN trim pots. Next time I have my x0xb0x apart I am going to replace the VCO calibration trimmers and the power supply trimmer. 2. Don't spend too much time on VCO calibration when you're still at the VCO building phase. Get it close and move on, you'll need to calibrate it later. Ladyada's build site would have you inject 2V and 3V to get the VCO calibrated. The problem is, your actual CV generated might not be exactly 2V and 3V. My x0xb0x generates 1.98, 2.98, 3.97 and 4.95 on each "C". You'll never know the precise voltage you'll see until you fire it up with the atmega. I suppose you could remedy this somewhat by hand-matching all those 1% 200K resistors, which actually form the DAC in this project, but it's not really necessary unless you also want to interface with other 1V/oct control voltage devices. 3. If you use spacers under 10 mm (3/8") long, you will need to cut or file off the little protrusion on the side of the big encoders, or else they will get in the way of the sub-panel. Similarly, you will need to enlarge the holes where the toggle switch and Panasonic pots poke through. I used a machining bit on a Dremel and it made short work of the job, although it does of course make a mess :) Now, if I may .... HUGE thanks to Sasha and The Prof. You both remained dedicated to this project and made it really easy for a dolt like me to build this thing. Thanks for being there to support us, the builders too. I decided to get in on this project only because I had a few extra bucks to burn. I have a pretty nice little home studio, and usually any time somebody came to visit they'd say something like "oh, wow! do you have a 303?" ... I would usually just sort of mumble some story about how the TB-303 was overrated in the first place, and it's played out ... and then show them something else I have that's more interesting. So the x0xb0x wasn't even really on my radar, until Sasha announced a pretty good price for boards and panels, with Dr. Pepper taking all the headache out of finding the rare parts. I figured "what the hell" and bit the bullet. Am I ever glad I did! I have always thought the TB-303 to be more of a toy than a serious music machine. Now that I have had a x0xb0x for about 13 hours, I can honestly say that it's a surprisingly versatile instrument - not just for cheesy acid sounds! It also does really solid sub-bass parts, screaching leads, and other stuff too. The really cool part the x0xb0x is that it can be sequenced via MIDI, so if you want swing timing, or just tighter DAW integration, it's there. I think I want 2 more. Pics to follow. EDIT: one thing I forgot to add... at first I thought Sasha's layout changes weren't all that important. Now that I'm using it, and I have this gorgeous front panel when compared to the adafruit x0x panels, I can honestly say that Sasha's changes are a significant improvement, and worth the deviation from Limor's design. Great job, Sasha!
I think it's expensive for a defective DX7. You should be able to get the price down. I would: Think of how much it would cost this person to get it fixed. Subtract that from the current market value of a DX7. Then take off about 25% and offer that. The UK market for used keyboards is always a lot more pricey than North America though, so maybe the amount is right on the money.
Hmmm ... Now that I look at it more closely, I guess you're right about the reflection. I'm not proposing enlarging any screw holes. I think I trimmed my pot shafts a little too short. To compensate, I can use shorter spacers, and then just enlarge the holes in the sub-panel around the Panasonic pots. It should make no difference, because those areas are generally covered by knobs anyway! Also, on closer examination I see that the Grayhill encoders have a little "nub" that sticks up, which I can also file off. I'll try that first, but I'm confident now that I can work around this.
I should be clear here: I'm not upset or anything like that, and I'm not pointing fingers ... I'm just trying to find the solution for my problem. I looked at this pic: Maybe it's just me, but it seems to me that the black keys look like they don't stick out as much as the white keys. Am I wrong? I have used shorter spacers than you, maybe because I trimmed the shafts too short. But my black keys stick out less than my white keys, and it's because I can't get the top part of the panel to sit as low as the bottom, due to the height of the Panasonic pots. I am sure I can remedy this by enlarging the holes in the sub-panel. I am only posting to see if anybody else is having the same problem.
Hi Sasha, I enlarged the hole for the toggle switch with a Dremel. Now the sub-panel touches the Panasonic pots before it reaches the spacers. I just looked more closely at your first x0xb0x and I see that the black keys don't stick out from the panel as much as the white keys ... it's because your panel is doing exactly the same thing. It is bending a little. I think the solution would be to either use larger spacers (but then the pot shafts are too short), or else enlarge several holes in the sub-panel to accommodate for the taller housings on the Panasonic pots. I'm going to think about it. Please let me know if I'm missing something. Thanks!
As luck would have it, I had 7x 10mm aluminum hex spacers on hand. After assembling the panel against the board, I decided I needed 8 mm. (I cut my pot shafts fairly short I suppose, but it was suitable for the Sifam knobs). Rather than ordering a set of 8 mm spacers, I filed my existing spacers down to 8 mm (+/- .5 mm). Then I went to attach the panel. Unfortunately, the little square hole in the sub-panel for the toggle switch prevents the sub-panel from going low enough. So I think I'm going to remove a bit of material from the sub-panel. I might just hacksaw off that corner of the subpanel - after all, the corner of the main panel will still be supported by the PT-10.
Do those knobs fit a D-shaft? It's hard to tell in the pic. Soundwell / Voti encoders have a "D" shaped shaft (i.e. one flat edge). Some knobs are meant for a spline shaft (ridged), and others have setscrews.
Well, an LED to show which sample is playing may or may not be doable. If you're talking about using the buttons to start AND stop samples, then yes, you could have an LED show that the sample was started but not stopped. But if you are triggering one-shot samples in your laptop from a MIDIbox, the MIDIbox has no way of knowing how long the samples are, so the LED's on/off status would be meaningless. I don't know how much experience you have with this type of stuff, so I'll add: don't take on a MIDIbox project to save money. You probably can't build something for less than it would cost to buy a cheap commercial controller off-the-shelf, especially if you need to buy basic hardware, tools, supplies and parts. Advantages to building a MIDIbox (and DIY in general) are: - customization (you can make it look and work exactly as you want it to) - community (people in the forum will help you learn, so just by building you are contributing, and then you get bitten by the bug and want to help others, while other people learn from the help that you got), and - pride (the satisfaction of realizing your own design, using it, and showing it off).
Roland PG-300 (Alpha Juno) synth programmer clone?
nebula replied to Max Romantschuk's topic in Design Concepts
http://www.midibox.org/dokuwiki/doku.php?id=eusart_bug -
Thanks :) Troubleshooting was easy. I didn't notice that the level coming from the VCF is much lower, so I needed to adjust my scope. Duh...
Another word to those building: Most projects that use trim pots work best with multi-turn pots, similar to those used on the AOUT board variants. Sometimes, a single-turn pot works best, like for the brightness/contrast on a Core (where you don't really need ultra-fine control). If you're sourcing parts, and you have a choice, use multi-turn pots for your x0xb0x. Having just calibrated my power supply and VCO, I can tell you that plain ol' cermet pots are a bloody nuisance, ESPECIALLY in the x0xb0x. My status: I think I may get all the electronics done tonight, leaving only hardware issues (spacers etc) for tomorrow. My (completed) VCF section is not making a sound when tested according to the instructions on Ladyada's site, but I'm still trying to retrace my steps...
It's pretty, but I'm likely to spend more time with the familiar theme. I agree that it's nicer for reading in the dark. I wouldn't say the actual layout is significantly better or worse, but it's different enough that it takes me longer to navigate.
Maybe it's my inexperience so far with my MB-6582 so far, but I often find myself having to stop and think about which mod source is which when I assign something in the matrix. 1 and 2 are envelopes 1-2, and 3-8 are LFO 1-6. Usually when I create the modulation routing, I immediately want to jump to the modulation source and edit it. Unfortunately from a UI standpoint the matrix "feels" somewhat disconnected from the LFO and envelope controls. At first I was thinking it would be nice for the modulation source to automatically be selected every time you create a modulation point, but that could be annoying if you're trying to tweak one source while toggling another. But... It would be cool if I pressed "3" in the matrix, WITHOUT selecting a modulation target, and then RELEASED the button, the control surface would automatically change the selected LFO to #1. Maybe the newly selected LFO would even blink once or twice to show you that it did it. Or press and release "5" and the selected LFO would jump to 3. Or press and release "2" and the selected envelope would jump to 2. The idea is that it saves the user a step, and some thought. Similarly, when you select an LFO or an envelope using the selection buttons (LFO 1-6, Env 1-2), maybe the entire column in the matrix that corresponds to the source you select could blink, just once very quickly, to show which source you're about to edit. Any opinions?
