v1 and v2 don't differ concerning the CS as much as you seem to think. As for the comparison - they don't compare well. Just look at the feature list of the mbSID v2 and compare it to the sidstation. Start with 8 SID chips vs. 1 ;)
"Do I want one" is a really bad question to ask, since you've got severe GAS. It should be "can I buy one w/o my wife getting mad at me" :flowers:
I think you don't want one, but you wanna make one yourself. So much more fun :)
A 9V wallwart will do just fine. How will you use it? Plug it in the wall? The purpose of a power supply is to, erm, supply power. Try removing the power supply from your PC and see how well it runs ;)
The reason kaleaf thinks it's the wrong core is that there's few/no apps for the mios32 yet. So you'll either have to code your own or wait till it happens ;)
I think the idea was to have an extended "Step B" CS - 40x2 LCD + 10 LCD buttons + menu encoder and menu buttons. The 5 extra encoders (for direct access to the "knobs" values) do not necessarily have to be in any way assigned or connected to the menu buttons.
You might wanna look for "elSID", "mxSID" and seppoman's "der brat" for some inspiration as they include some different concepts.
*While* you push down the multimeter probe on a bad solder joint it may well make a connection, especially SMD pins ;)
Glad you got it to work! :frantics:
That does in fact seem rather odd. Just follow the path of the two MIDI outs from the gm5 to the sockets and check that all the parts in the path are correct and the soldering is good (pay special attention to the gm5 pins, maybe those two aren't soldered rigtht):
MIDI Out 1:
GM5:14 -> R32 (220) -> IC3:13
IC3:12 -> IC3:11
IC3:10 -> MIDIOut1:5
MIDIOut1:4 -> R31 (220) -> +5V
MIDI Out 4:
GM5:17 -> R12 (220) -> IC6:13
IC6:12 -> IC6:11
IC6:10 -> MIDIOut4:5
MIDIOut4:4 -> R11 (220) -> +5V
Check continuity between each connection and make sure the resistors are 220 Ohm.
Yes.
By either using this or if you're on Windows beta testing this: http://midibox.org/forums/index.php?app=core&module=attach§ion=attach&attach_id=6610
//Turn on adc
ADCON0bits.ADON = 1;
//wait for adc to do conversion
while (AD1CON1bits.DONE == 0)
continue;
}[/code]
IIRC it's /DONE, which means that in your source it's the wrong way around and should be
[code]
AD1CON1bits.DONE = 1;
while (AD1CON1bits.DONE)
continue;
Otherwise the app will wait until it's "not done" which will result in an endless loop.
