nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. What you seem to want to do is definitely doable. "Writing an entire app" sounds a lot harder than it is. You don't start out at 0, but with a fully working app, with all hooks that just doesn't do a lot yet. So it's really not that big a deal :-) In most cases you can just mod an existing app but I personally prefer to statr from scratch rather than digging thorugh someone else's code ;)
  2. It absolutely can, and it doesn't even have to be that complex. A single program change message could do if you write the app with full support of all the possible pedalboards you have.
  3. $16 müssten das gewesen sein.
  4. nILS
    # of ADSR's
    Short answer: Lots. Long answer: 90 MIPS -> 90,000,000 instructions per second -> 90,000 instructions @ 1kHz. Semi-random very pessismistic guess per ADSR is 1000 instructions -> 90 ADSRs.
  5. Vermutlich weil Du das 1.5fache vom Neupreis verlangst ;)
  6. Sweet :-) :D
  7. This topic has been moved to Deutsch. [iurl]http://www.midibox.org/forum/index.php?topic=14160.0[/iurl]
  8. It'll get better the more you read ;)
  9. Get yourself a copy of the datasheet and look for info on the TRIS* registers :-)
  10. Wilba is kinda hard to get drunk. I tried it with german beer (obviously not hard enough) .
  11. Any particular reason you sent that as PM as well? Tiny traces, tiny spacing, >400 holes - not very diy friendly, and certainly not worth the effort, when you can buy one for <10eur.
  12. if (PORTCbits.RC5) { // pin is high do something } else { // pin is low do something else } Remember to set the pin directions before using them as in/outputs.
  13. For J10:SO you would do: PORTCbits.RC5 = 0; or PORTCbits.RC5 = 1; J10:RC is PORTCbits.RC4. Simple enough, eh?
  14. Cool! How many newb-points do I get if I start a thread with a hitler reference? edit: It's only fair to give the opposition equal time ;)
  15. Get the new toolchain installed instead ;)
  16. You can just paste the "copy ...." in a command window (start -> run -> cmd)
  17. Yep, that's it.
  18. Yes, that's possible (depending on the app you want to use it might mean some coding [for the mbCV for instance the amount of coding = 0]), the triggers are 5V
  19. Thanks, now I can finally see all the cool stuff you got there ;)
  20. Resizing pics good. Napster bad.
  21. Teehee, nice link :-)
  22. If the few mA that the opamps pull are above the minimum current draw of your atx power supply, then technically yes. Most PC power supplies will introduce a lot of noise audible though.
