nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. In case anyone wonders - the SSM2044 filter will work on +-15V as well ;)
  2. Follow the instructions in the readme.txt (and possibly instrcutions in the main.asm) that came with the app. Pull the SID (always good to be on the safe side), send CC, measure voltage at current pin, repeat.
  3. Nice looking box! Great job ;)
  4. You seem to have a lot of intermittent errors, proto. Earlier in the chat you mentioned that your PSU stopped working, the other core (which now mysteriously works) didn't even send out an upload request, ... Try and focus on one thing at a time.
  5. Well you already found this gem: http://ucapps.de/mbhp/mbhp_8xsid_c64_psu_optimized.pdf It has all the wiring in it ;) Even though the silkscreen on the SID PCBs is a bit different the pinout is the same - wire them as shown in the pdf.
  6. Hehe, no worries, just saying ;)
  7. Um yeah, I am pretty sure d2k solved that problem or quit the project, after all he asked 4 years ago...
  8. Disconnect everything else, work on one problem at a time. With 20 LEDs I assume you have a DINx4 connected. Remove all SRs and see what it's doing now. None of the LEDs should be lit. Measure the voltages on the supply pins of each SR. All good? Stuff the first one, see what happens. If all LEDs are suddenly lit - try another SR in the place. What happens now?
  9. That's a good choice for a beginner's project imo.
  10. Since the button is just a switch and not a knob you won't need an aout for the job. A pic pin will do (possibly needs an opamp/transistor to buffer/adjust the signal).
  11. Hübsch geworden!
  12. SerialDeath
  13. It's not supposed to send anything. Since you uploaded the files with smart mode - you core's midi out is working. You don't have a problem.
  14. How did you upload MIOS and the SID firmware? Using smart mode? What exactly do you expect the mbSID to send out? Besides the upload request on startup the mbSID will not really send out anything ;)
  15. Anyone else wanna chip in? :D
  16. Yay! http://www.midibox.org/forum/index.php/topic,13891.0.html
  17. This topic has been moved to Parts Questions. [iurl]http://www.midibox.org/forum/index.php?topic=13889.0[/iurl]
  18. [me=nILS]checks the queue[/me] Neh, sowwy.
  19. Looking great :-) Well except for the protective sheet ;D
  20. Ja und zwar der Großmeister TK selbst ;) Machbar ist das auf jeden Fall, das "wie" ist eine andere Frage, schlimmstenfalls ein zweiter Core und ein bissel eigener Code.
  21. That's correct, to run v2 you'll need a PIC18F4685. J2 on the core is +5V/Gnd which you don't need to attach to anything. Directly soldering the wires to the headers is in fact usually not a great thing to do, as it makes checking and replacing a lot harder. Pull the SID chip and check the voltages first.
  22. What gave you that idea? v2 supports all SIDs. You don't need an AIN module for the CS. What you need is a DIN module. Not having a CS will not lead to no sound though. Neh. You either fix it yourself or it's gonna be done for free. Charigng money for anything mb-related is bad karma. Which is not a problem at all. The chat is a lovely place for step-by-step trouble shooting. Let's see what you got working so far: * Core is working apparently, as you are able to upload MIOS, the sid app and the presets (are you sure you used the v1.7 presets?) * We don't know if the SID module is working. To find that out, first remove all ICs from the SID module. Then test the voltages as described on ucapps. Post the results here. If all the voltages are okay, you'll need to do the interconnection test (also described on ucapps). If that's okay as well and you still get no sound, your SID is most likely damaged - we'll know more after you post the test results.
