nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. If you're still undecided give the Alpha 16mm pots a shot - I have grown to love em.
  2. Yes. Neither is better. It depends on what you want the feel of the controller to be like. Pots have a fixed movement of 300° thus always giving you visual feedback off the position. Encoders can have a much higher resolution, but don't give you any hint about the position and can be rotated in either direciton endlessly. Either one will work. That's a matter of adjusting the code. But is doable.
  3. In case anyone wonders - the SSM2044 filter will work on +-15V as well ;)
  4. Follow the instructions in the readme.txt (and possibly instrcutions in the main.asm) that came with the app. Pull the SID (always good to be on the safe side), send CC, measure voltage at current pin, repeat.
  5. Nice looking box! Great job ;)
  6. You seem to have a lot of intermittent errors, proto. Earlier in the chat you mentioned that your PSU stopped working, the other core (which now mysteriously works) didn't even send out an upload request, ... Try and focus on one thing at a time.
  7. Well you already found this gem: http://ucapps.de/mbhp/mbhp_8xsid_c64_psu_optimized.pdf It has all the wiring in it ;) Even though the silkscreen on the SID PCBs is a bit different the pinout is the same - wire them as shown in the pdf.
  8. Hehe, no worries, just saying ;)
  9. Um yeah, I am pretty sure d2k solved that problem or quit the project, after all he asked 4 years ago...
  10. Disconnect everything else, work on one problem at a time. With 20 LEDs I assume you have a DINx4 connected. Remove all SRs and see what it's doing now. None of the LEDs should be lit. Measure the voltages on the supply pins of each SR. All good? Stuff the first one, see what happens. If all LEDs are suddenly lit - try another SR in the place. What happens now?
  11. That's a good choice for a beginner's project imo.
  12. Since the button is just a switch and not a knob you won't need an aout for the job. A pic pin will do (possibly needs an opamp/transistor to buffer/adjust the signal).
  13. Hübsch geworden!
  14. SerialDeath
  15. It's not supposed to send anything. Since you uploaded the files with smart mode - you core's midi out is working. You don't have a problem.
  16. How did you upload MIOS and the SID firmware? Using smart mode? What exactly do you expect the mbSID to send out? Besides the upload request on startup the mbSID will not really send out anything ;)
  17. Anyone else wanna chip in? :D
  18. Yay! http://www.midibox.org/forum/index.php/topic,13891.0.html
  19. This topic has been moved to Parts Questions. [iurl]http://www.midibox.org/forum/index.php?topic=13889.0[/iurl]
  20. [me=nILS]checks the queue[/me] Neh, sowwy.
  21. Looking great :-) Well except for the protective sheet ;D
  22. Ja und zwar der Großmeister TK selbst ;) Machbar ist das auf jeden Fall, das "wie" ist eine andere Frage, schlimmstenfalls ein zweiter Core und ein bissel eigener Code.
