4,314 -
4
Everything posted by nILS
Each DOUTx4 module gives you 32 outputs. Using that module is a bit more complicated as the leds are wired in a matrix (for some more info on how this is done check http://ucapps.de/mbhp/button_duoled_matrix.pdf) I'd suggest using 3 indivual displays, which makes life (on the software side as well) a lot easier for a beginner's project.
Well you best do some reading on http://www.ucapps.de then ;) You'll need a CORE8 (the heart of each midibox) module and a DOUT (Digital OUTput, in your case LED) module. Read up on those and come back with more question afterwards :-)
Okay, so you could just split the midi signal (using some inverters for instance) and run it into a core module. Hook up a DOUTx2 to it, wire up the displays - done ;) The software side is a piece of cake as well, I'll gladly help out if you need anything.
is the midi switch a midibox? if so, just hook up another DOUT module to it (you'll need 16 pins if you go without 7-segment display drivers, assuming not displaying the leading "0" is not a problem, otherwise you'll need 20 pins) and change the source code so it changes the status of the 16/20 pins according to the program number.
Yes ;) Either use 7-segment LED drivers or individual DOUT pins for the individual LEDs in the display. What exactly is your question though?
This is not a MIDIbox SID and hence does not belong into the "MIDIbox SID" subforum.
This topic has been moved to Miscellaneous. [iurl]http://www.midibox.org/forum/index.php?topic=13666.0[/iurl]
lol! err I mean: Bad Wilba, bad Wilba! [me=nILS]rolls up a newspaper[/me]
http://www.midibox.org/forum/index.php/topic,9666.msg117512.html#msg117512 http://www.midibox.org/forum/index.php/topic,13083.msg117505.html#msg117505 http://www.midibox.org/forum/index.php/topic,6043.msg117340.html#msg117340 http://www.midibox.org/forum/index.php/topic,9705.msg117298.html#msg117298 http://www.midibox.org/forum/index.php/topic,13645.msg117299.html#msg117299 Stacky, seriously now. No, you don't. What you do need is to stop asking for "circuit diagrams" of random and for the most part not even midibox projects and start reading.
Erm, this is cimo we're talking about ;)
This Works Very Well>>>Game pad / Joy stick for midi controler?
nILS replied to stacky2009's topic in Design Concepts
http://www.ucapps.de -> Menu on the left side -> MB Hardware Platform -> there's all the different modules listed right there. -
You need to do some reading. Go to http://www.ucapps.de and read, read, read. There's a lot of schematics, pcb layouts and most importantly information about what midibox is. Once yout got a rough idea how the whole thing works - feel free to ask more detailed question. Go to http://www.ucapps.de and read now! -
Stacky... Please read replies to your posts. http://www.midibox.org/forum/index.php/topic,6043.msg117343.html#msg117343
Good to hear you're ok! Stop doing all that real life stuff and get back here :-)
Also, check if your MIDI interface is blacklisted and use the search function of the forum to look for "overrun error".
Is so (siehe http://www.mikes-elektronikseite.de/shop_englisch/index.htm). Ohne jetzt was vom Zaun brechen zu wollen - mit den unterschiedlichen Midi-Headern ist bei Weiten noch nicht der Unterschied zwischen Smash's und Mike's Platinen abgedeckt. Es liegen einfach faktisch Welten zwischen zu Hause geätzten Platinen (leider auch des öfteren mit kleinen Fehlern wie Brücken oder weggeätzten Leiterbahnen, wie ich selber des öfteren festgestellt habe) und einer professionell gefertigten Platine mit Bestückungsdruck bei der alles passt und alle Löche tatsächlich gebohrt sind, bei der man keine Brücken von Hand löten muss, bei der die teilweise empfindlichen Komponenten nicht in Styropor gesteckt versendet sondern anständig in antistatischen Tütchen und Antistatikschaumstoff, bei der traumhaft einfach zu verwendende 2x5er Sockel verwendet werden (die 1:1 mit anderen Platinen verbunden werden können), ... Ich könnte noch ne Stunde so weitermachen. Am besten mal den Unterschied am eigenen Leib erfahren - es sind Welten. Selbstredend geht's bei Mike Dank des kurzen Versandwegs schneller und ist bei kleineren Bestellungen auch noch günstiger - sobald's ein bisschen mehr wird, lohnt sich dank des miesen Dollar und Smash's günstigeren Preisen der Versand schon recht früh. So wieder on-Topic: Ich habe seit Jahr und Tag einen kleinen 25W ERSA Lötkolben. Lötzinn ist Geschmackssache, am besten nicht gleich eine riesige, fette Rolle kaufen ;) Ich bin sehr zufrieden mit dem hier (bleifrei ist im Fall von Lötzinn ziemlich bäh). Dazu bietet es sich an eine Entlötpumpe und Entlötlitze zur Hand haben.
Hooray for 16 kB/s uploads :-)
Potentiometers (if that's what you meant with 10k encoders) should be 10k linear as well :-)
Nojo, allegmein wird ja als MIDI interface hier eher das gehandelt, was an den PC/MAC MIDI Sockel ranzaubert ;)
Wo hast Du denn die Info her? Ist auf jeden Fall falsch. Kein core8 hat ein MIDI Interface mit drauf. Da Du die Teile nicht günstiger kriegen wirst als von Mike/Smash lohnt es sich nicht die selber zu kaufen. Smash's PCBs sind qualitativ besser als die von Mike (doppelseitig, professional gefertigt, mit Bestückungsdruck) und somit gerade für Anfänger deutlich einfacher zu verarbeiten - wo Du bestellst ist Deine Sache, funktionieren tut beides. Die 5V vom PC USB Port kannst Du theoretisch nehmen (der core8 hat allerdings keinen USB Anschluß), allerdings musst Du da ein wenig mit den zur Verfügung stehenden mA aufpassen, das wird mit ein paar LEDs und LCD mit Hintergrundbeleuchtung recht schnell sehr eng. Ist also allenfalls besser ein 9V Steckernetzteil zu nehmen - die kosten auch kaum was.
Bis der core32 (nicht "coreV4") rauskommt wird das noch ein bisschen dauern. Die Module werden alle kompatibel sein. Also wie schon gesagt, einfach wie schon hunderte vor Dir mit 'nem core8 loslegen ;)
I've used all sorts of cables for audio - the difference is subtle to say the least if you don't run the audio cables parallel to power or monitor cables ;-)
Using JDM for burning 16F88 PIC used in IIC module?
nILS replied to ilmenator's topic in Testing/Troubleshooting
For anyone who's still in doubt - depending on your burner it might as well work without an adapter (with mine for instance) ;) -
I'd start with one of the 6582As as they are pretty much guaranteed to work, which may be a huge benefit in potential troubleshooting. Also it seems rather likely that you'll build a stereo setup at some point, so that's another reason to start with the 6582A which will go nicely along with it's sibling in a stereo setup :-) You cannot simply replace the 6582A with a 6581. The 6582A is basically an 8580 and needs a) a different voltage to run and b) different filter caps. Obviously it's not a huge problem to replace them though ;)
