SLP
1,149 -
Everything posted by SLP
a) just select all 3 oscillators. the numbers under OSC will go 1-- -2- --3 12- 1-3 -23 123 as you turn the master-encoder
Awesome! :D First step on the long road to the MB-Sampler ;) nice find, Sasha!
nope. here's the beta: http://research.microsoft.com/en-us/um/redmond/projects/songsmith/
It all belongs to MS's plan to kill music. This plan also includes DRM and Vista :rolleyes:
Midi to CV converter with 32 CV Outputs - 4x AOUT_NG´s ?
SLP replied to mangor's topic in MIDIfication
SHX8-Module? -
http://www.delamar.de/free-vst-host/ http://www.delamar.de/free-vst-plugins/
I don't know what wavelength the used laser-light has, but assuming that it is below ~125nm, It is not ionizing and therefore not causing cancer. What he does is simply burning his skin. Remember when you were a child and burnt your hand using a magnifying glass and sunlight? that was more dangerous. Of course, what he does is grossly negligent and I wouldn't mind if there would be an accident and it would burn a bigger hole in his hand. But by paying this idiot so much attention, some poeple could have the desire to become as "famous" as he is now and imitate it. It's the same with clothing. One wants to be a bit individualistic, he gets attention, the other copy it... [rolleyes-smiley!]
I love the labeling of the buttons! It looks a bit like some russian cold-war nuclear bomb firing terminal. The only thing missing is a big red button :) I can't read it anyway ;)
www.Bandprojekt27.de.tt Here are two songs of a little bit chaotic DnB (at least I guess it's DnB) Quartett. The songs are of course a bit imperfect (I couldn't really decide which notes to play ;)) , and in the song "Sylvester Stallone" the singer couldn't really decide in which mic to sing (one was hooked up to our 4-channel-Recorder, and the other one was hooked up to the PA ;D ) so it sounds a bit weird. But it was a really funny session :) enjoy :) edit: my sustain-pedal was also jamming. that little sucker ;) edit2: topic name changed
ewww.... women! *SLP runs...
Tonertransfer-method or Press'n'Peel You have always been able to etch your PCBs at home :) But this one is said to be the fastest and the most precise method
nILS, I've tried to reach you in the chat several times: I've had some troubles with the "submit"-button on that page. I don't know whether the informations have been sent or not. Could you just verify my order, please? regards
Ich tippe grob auf die selbe Elektronik wie in optischen Mäusen, also einen optischen Sensor der die Bewegungen der Kugel erfasst.
MIDI-to-COM interfaces funktionieren nur selten mit Midibox-Hardware. Von den Midibox MIDI-USB interfaces funktioniert eigentlich nur das GM5 fehlerfrei. Allerdings brauchst du dafür einen speziellen SMD-Chip, der regelmäßig in Sammelbestellungen von der Community gekauft wird. Das wäre also die optimale Lösung wenn du noch etwas warten kannst, und SMD-Löten für Dich kein Problem ist. Am geeignetsten wäre sowas: http://www.thomann.de/de/swissonic_midiusb_1x1.htm Wenn Du willst verkauf ich dir meins für 10€. Ich hab ja jetzt mehrere GM5 am Start und brauche mein altes nicht mehr.
exakt. Irgendwas, das nen Ton macht. MIDI-SIgnale sind nur "Steuerdaten". d.h. es wird u.A. übermittelt: - Was für eine Note wird angeschlagen? - Wie fest? (Stichwort: Anschlagdynamik, "Velocity") - Wann wird die Taste wieder losgelassen?
I imagine getting the round edges look exact the same could be a bit difficult by hand..
Awesome Idea. I've just mailed "my" Laserman :P what it would cost to cut such a "case" for the GM5x5x5. I've even found some nice plexiglass. It's black when you look at it, but it lets the light from the LEDs onthe PCB shine through.
äh... mal was Andrers:
Stimmt! An die Software-Lösung habe ich jetzt garnicht gedacht. aber eine Klaviatur sollte schon sein IMHO. Im Grunde reicht ja ein gebrauchtes 2-4 Oktaven Midikeyboard (ca 50€). Dein PC sollte dann auch einen Midi-Eingang haben. Falls er keinen hat, gibt es für 20€ MIDI-USB-Interfaces. Bitte lass die Finger von diversen Gameport-Midi-Kabeln. Damit gibts oft Probleme. Dann benötigst du evtl. noch nen VST-Host: http://www.delamar.de/free-vst-host/ (Ich weiß nicht, wie gut Du dich mit Musik-Software auskennst. Evtl. hast du ja schon eine Sequencersoftware, dann brauchst du natürlich keinen STandalone VST-Host mehr.) Und natürlich noch diverse VST-Synthies: http://www.delamar.de/free-vst-plugins/ viel Spaß :)
Jetz leg erstmal deinen SEQ zur Seite, und besorg dir eine Klaviatur und/oder ein Synthesizer Modul. Gut für Anfänger ist der Roland SH-201. Den kannst du dann direkt mit deinem Sequenzer steuern. Falls du keine Klaviatur brauchst ist der Waldorf Blofeld IMHO auch recht günstig und klanglich in Ordnung. Ansonsten gibts natürlich auch die DIY Variante, sprich: Midibox SID-Synthesizer oder der MB-OPL3-FM-Synth. Jetzt wo Du die Teile schon hast, würd ich auf keinen Fall nen Rückzieher machen :)
Stell Dir einfach ein Klavier oder ein Schlagzeug vor: Du drückst nur die Tasten bzw schlägst auf die Trommeln. Den Klang selbst macht das Klavier bzw das Schlagzeug. lies Dir mal das durch: http://de.wikipedia.org/wiki/Musical_Instrument_Digital_Interface und lass Dich nicht davon abschrecken wenns manchmal etwas kompliziert klingt ;)
see http://www.midibox.org/forum/index.php/topic,11642.0.html especially:
didn't you say that you've programmed your own browser?
http://www.schickt.de/ :)
;) nice new homepage, btw.
