109 -
Everything posted by Digineural
MDF board to mount control suface compontents... bad idea?
Digineural replied to fallenturtle's topic in Design Concepts
Point to point wiring on MDF isn't a bad idea as much as it is heavy and thin MDF tends to be brittle. The SID CS isn't that large so I don't see flex as a huge problem. Hardboard is a decent alternative if you're careful. For either, take measures to avoid tear out. All that said, when I created my first MB some 15 years ago (man it's been a long time) I had all sorts of trouble with getting a clean fabrication that I was proud to show off, so I've been using Lexan or CNC'd aluminum. Moisture isn't never an issue and lexan takes vinyl overlays quite well. I usually paint the back and letter the front for a candy coated look. The rest of the enclosure can be built out of anything. -
MIOS Studio: new version on the way
Digineural replied to TK.'s topic in MIDIbox Tools & MIOS Studio
I while back I started creating a Dockerfile image using gcc to build apps regardless of the host machine, not specifically for juce. One of the reasons I never completely used it was because how all of the source for all samples and such were pulled in. I was getting a bit lost as to how to decouple the framework & OS from the applications is a more module fashion but I couldn't figure out a good way to do it. I also think moving to a lighter OS than ubuntu might be a better move. Anyway, heres the Dockerfile but instead of the SVN step you could checkout from github FROM ubuntu:latest LABEL Description="Image for building and debugging midibox projects" WORKDIR /usr/local # Build time definable environment arguments ARG FAMILY=STM32F10x ARG PROCESSOR=STM32F103RE ARG BOARD=MBHP_CORE_STM32 ARG LCD=universal # Install any needed pacakges RUN apt update && \ apt upgrade -y && \ apt install -y \ # Development files gcc-arm-none-eabi \ build-essential \ subversion \ bzip2 \ wget \ libgmp3-dev && \ apt clean && \ # Grab the official midibox setup wget http://www.midibox.org/mios32_toolchain/gcc-arm-none-eabi-4_7-2013q3-20130916-linux.tar.bz2 -O gcc-arm-none-eabi-linux.tar.bz2 && \ tar -xjf gcc-arm-none-eabi-linux.tar.bz2 && \ rm gcc-arm-none-eabi-linux.tar.bz2 && \ mkdir /home/midibox && \ mkdir /home/midibox/local # Grab the latest source which WORKDIR /home/midibox # Grab the latest source and remove everything not needed to build RUN svn checkout svn://svnmios.midibox.org/mios32/ && \ rm -rf /home/midibox/mios32/playground && \ rm -rf /home/midibox/mios32/trunk/apps && \ rm -rf /home/midibox/mios32/trunk/tools # Internal build environment settings ENV PATH="/usr/local/mios32_toolchain/bin:${PATH}" ENV MIOS32_PATH=/home/midibox/mios32/trunk ENV MIOS32_BIN_PATH=$MIOS32_PATH/bin ENV MIOS32_GCC_PREFIX=arm-none-eabi # Build time definable environment settings ENV MIOS32_FAMILY=${FAMILY} ENV MIOS32_PROCESSOR=${PROCESSOR} ENV MIOS32_BOARD=${BOARD} ENV MIOS32_LCD=${LCD} WORKDIR /home/midibox/local ADD . /home/midibox/local VOLUME [ /home/midibox/local ] -
*bump*
The 6581 will get hot, thats normal. And the opening sound is a good sign that the SID is working. Chances are its just a patch problem. That said, I'm running my 6581s on a PIC18F4685 using the SID V2 firmware. This has a default set of patches. I say all that to say, I would learn towards an issue with the PIC or firmware and less with the rest of the hardware. Before you go out and grab a new PIC however, move a different patch to the default patch and then try playing. Or see if you can send a CC command to change the patch. If you get a new tone then everything is fine and an LCD and a minimal control surface should help you change patches
Yes, I control my SID over USB with the M-Audio UNO (USB to MIDI). That would be the most straight forward approach.
I dont have anymore of the GM5s. Sorry
Yes. The documentation for the Midibox 64E or Midibox NG should explain this pretty well. If if this is all the functionality you'll need, the programming tutorials on ucapps.de should get you most of the way. See Sending relative MIDI events with rotary encoders and then add a button that will increment or decrement the offset for the track.
One of these are for sale. I don't need them. PM me if you are interested. $30 US each pair of PCB and GM5 + shipping. [sOLD]
I cleaned up my workspace this weekend and found that I have 1 more GM5x5x5 PCB and 1 more GM5 ic that I'm willing to part with. $30US + shipping. I actually have 2 sets but I'm keeping the last set for me. :smile:
Some pictures of me playing around 2 days ago. At this point, short of Core2 it's a fully functioning MB6582. The last 2 cores (3 & 4) have the SID caps left out so that you can either socket them for modularity or configure it yourself. There are no sids populated in 3 & 4 per the original pics above.
This particular sale will probably be closed out in the next day or so. I have a solid buyer, i just need to get to the post office. That said, I have 1 more GM5x5x5 and 2 more GM5 ics. I may consider posting them for sale since my audio interfaces do the work of this tool anyway. I'll consider it...
Unfortunately I've come that point in my life where I've realized my desire to build stuff was greater than my desire to use it, so I'm selling some stuff to get other stuff that I can actually use. I'll post some exterior pics soon but here's the list MB6582 - All blue LEDs - White Waldorf knobs - Blue/White LCD screen - LCD window - Stock panels with blue inlayed line dividers / white text - Setup with 4 cores - 2 6581s (working) - CORE 1 - 2 8580s (working - see known issues below) - CORE 2 - US PSU pulled from a C64 - PC Fan Known issues - all 4 cores have been tested to work but the first core can't communicate with core 2. Its likely a simple resistor problem, but I never got around to actually correcting it. So Core 2 wont actually play just yet. Once that issue is worked out, you can slave cores 2-4 Cores 1,3&4 work great. Core 2 appears to have a problem with RX communication. TX works fine, needs a new PIC with ID:1. RX is likely a physical connection issue. $600 US + shipping I'm going to move the 8580s to core 3 and make sure everything is working. I couldn't get core 2 to work with a new PIC but the other cores are communicating well. So with the fix, I'm dropping the price $525 US + shipping. Also I have a GM5x5x5 board with a spare GM5 chip. This is not a kit, just the PCB and GM5 chip unsoldered. $30 + shipping. [Reserved, pending sale]
Want to develop, not sure where to start?
Digineural replied to Reggie's topic in MIDIbox Tools & MIOS Studio
Hi Reggie. You should be able to use the windows xp setup for windows 7. Most of the legwork is already done for you but you may have to upgrade yourSVN client or some small parts here and there. The biggest hurdle that most people run into is not setting up their environment variables correctly. If you're not familiar with C/C++ or gcc, you will have a steep learning curve but definately doable. I develop in the MonoDevelop IDE which is free and fairly painless. You can use notepad++ or any other IDE with custom makefile integration. You don't need a board to start developing but you will once its time to debug. At the very least, order a board and a 2x20 CLCD and expand as your needs change. I've found the Programming Tutorials section to be immensely useful when digesting a concept. In time, you may want to add a Standard Control Surface to your STM32. Depending on you're requirements however, the MB-NG might be enough to get things working the way you intend so consider that route before going into custom application development. Have fun. -
Project: MA4PC a Midibased Lighting Controller
Digineural replied to GMAprogrammer's topic in MIDIbox NG
Wow, thats an amazing setup. Feeling inspired to dig up some old projects again. -
that moment when your machines procreate
Cool! I just finished building mine, its a shapeoko. I'll be connecting the electronics tonight. have you noticed any performance loss with the new spindle. I've heard that the quieter spindles have less cutting power. I'll be fitting mine with dewalt dw600 after I adjust the runout.
Are you talking about the MidiBox Plus of yore? Or the MidiBox 1? I didnt see the schem for MidiBox 1 but theres are bunch for the Plus
My wife got me a desktop CNC. She just showed me the receipt. It comes in tomorrow. :D
- Show previous comments 1 more
That is one heck of a gift. I'll have to show mrs all the good webshops, and instruct her on my needs for a stagepiano :P
I made a chart of things I wanted by cost. I very well could have just got another guitar pedal but she picked well.
Its all here in the wiki. J8 is "Configuration Jumper. Closed (default): midibox.org configuration, open: ploytec.com configuration" No, you do not need the leds and if you dont want to use them you can leave a bunch of other parts out... also in the wiki.
Received mine, very nice indeed!
What Parts will i definately need for a usb midi controller?
Digineural replied to eden's topic in Parts Questions
Its common place to point you to our fearless leaders site and do a lot of reading. We've all been where you are, full of questions and ambition and its truly the best place to start. Read about the hardware platform as that's where all your I/O options are at. If, after all that reading, you have more questions then feel free to ask but consider looking everywhere on the site first lest we make the MIDIBox gods angry (they get a lot of these questions). To make things simple though, you can just start with an LPCXPRESSO and a MBHP_CORE_LPC17. That should get you enough to talk MIDI to your PC. You can follow the tutorials to make a custom controller or wait until the MB_NG code is ready. -
Kirby's Dream Band will hopefully use the MB-6582
Digineural replied to pingosimon's topic in Songs & Sounds
Cool vid. You guys seemed to really enjoy it. I know way too many musicians who take their music so seriously that they keep it from being seriously fun to do. -
That is slick. Good job!
sorry, I got rid of my extras but I'm keeping the last 3 for myself.
