patatruc, i will build one in the next weeks (panel finally drilled, thanks reboot ^^ ) and try to improve the firmware for 4 Matrix1000 as i use an ultracore
so stay tuned
C_DECLARATION void MIOS_SRIO_TS_SensitivitySet(unsigned char sensitivity)
DESCRIPTION sets the touch sensor sensitivity.
sensitivity == 0x00 disables the TS so that Pin RD.4 (J14 of the core module) won't be driven by MIOS anymore and therefore is free for other purposes
have a look in mios8 fonctions webpage
i am really very interested by your design as i discovered Traktor Scratch Pro a few times ago and it is still a revolution in my head :w00t: :w00t:
does it make a tone on boot ?
if yes it is ok
mono/poly is more a software config
1*** : sammich is monotimbral, whereas mb6582 is 4timbral, that is why only channel one is activated
remember : 2SID=stereo, not mono1+mono2
there is a very basic app called ain64din128dout128 for core8
it maps all buttons,pots and leds with a unique midi message (notes or CC)
free to u to translate after with a dedicated program (max msp) or map all traktor controls
the best is to watch the forum (sorry i cqn't find back topics) for getting the right LEDs. Anyway, you can still had the transistors after if they consum too much
i used the previous model (green, no Rohs) to make a BLM 64. it works without transistors with my chinese leds and din/dout
you will have a lot of wires, so stay concentrates while building
check for shortcuts on the Mainboard/CS connectors (the 70 wires)
check shift registers on mainboard + Resistor networks (is the dot where it is supposed to be ?)
Regards
IMHO you have only 40% because it doesn't use the 280° of the rotation. I noticed on my Moog that the modwheel goes from 4 o'clock to 8 o'clock on the pot.
the best is to use 10bits and some algorithmic ( x+ (pot value>> 2 )for example) in order to get a value between 0 and 127.
Did Franklin design the MPC FSR ? Where can i get this stuff for cheaper ? (MPCStuff sells 1€ rotary encoder in local shop at 12USD !!)
What is strange is that all 16 FSR drop down at the same time. If it was an oldness problem, only some would drop down, isn't it ?
i will fix the v6 (i am a x0xb0x expert now :P)
Just one important thing : do you have the file of the firmware for the MCU ?
Yes i want both compressors : stereo !
yes i did
but it is a second hand and warranty is over
they adviced to get in touch with local maintenance (and this should NOT be fair price)
i can buy a replacement part on mpcstuff.com but it costs 75USD (ouch!) so some feedback is very welcome
