59 -
Everything posted by Polykobol
Compatibility Wilba control surface with Core407V
Polykobol replied to Polykobol's topic in MIDIbox SEQ
Well, I work using English since 1995. I don't have any back Panel on this one. On the silver one I have a side Panel, but it is not here right now. I want to get the maximal Midi port amount as possible. I would like to update as well with the the CV/Gate directly but for the beginning, it is not a must. SD port on the back as well. Sync Roland for old drum/Sequencers. Isn't it possible to use the midi8 PCBs from Midiphy? https://www.midiphy.com/en/shop-details/138/7/midi8-pcb- -
By the way, I have the feeling that's exactly the panel that you have according to that link: -
http://wiki.midibox.org/doku.php?id=mididocs:seq:beginners_guide:start http://ucapps.de/midibox_seq_manual_in.html But I don't know if this is compatible with the Midiphy Core. -
Everything is detailed under UCAPPS MIDIbox SEQ V4 -
You can find it under: Trace: • wilba_mb_seq_construction_guide -
Dear all, I first wish you all an happy new year and a lot of creativity for this year. I did a long DIY and music pause due to professional reason. I have few Sequencer V4 and some Core are damaged. I think that the Midiphy solution is amazing but as I already have panels, cases, VFD Displays, and control surface I would prefer to continu to use them. Another reason, I prefer to have a small unit than a monster device. In this way as well, I would re-use theses tools and instruments and it would still be possible in future to upgrade to the Midiphy solution. But to send directly to the trash devices is to my taste not acceptable. If I would buy the following Midify PCBs, would it be possible to run the Sequencer based on Wilba control panel with these boards? 1) PCB Core2) SD PCB3) MIDI 8 PCB4) I2C PCB5) Line TX PCB6) Line RX PCB Thanks, F
Stereo Polivoks VCF (nearly complete :)
Polykobol commented on Hawkeye's gallery image in Members Gallery
Noritake CU 20045-UW VFD for Core8
Hello, I may be interested into. can you let me know please? thanks, best regards, francois
Hello, I am as Well in the same Situation. I am looking for such a PCBs. best regards, PK
Hi, is it still for sale? best regards, pk
Hello, do you sell the core Module?
PCBs for sale (again) incl. LRE8x2 & STM32F4Disco
Polykobol replied to FantomXR's topic in Fleamarket
Hello are they still for sale? -
Hello, I would like to buy the core Module
Hello, I am interested. is it still available?
Hi, give a sign of you have one for sale. Thanks, PK
Hi, the title says enough. Thanks, PK
Hi all, I have finished my control surface for the Seq V4.I uploaded the midibox_seq_v4_086/MBHP_CORE_STM32/project.hexIt seems the mapping of the control surface doesn't fit to the software.When I press BPM, the display shows the step view menu... What's wrong?Any idea?
Thanks to both of you. According the notice from Wilba, I changed R5 R6 R7 R7a R8 R8a R5a R6a to 1Kohm. Now, the little problem I meet is the soldering face of the J1 and J2. I initially set the connector on the Components side. Unfortunately, it is not possible to connect the corresponding connector due to place problem between the PCB and the front panel. I assume the best solution is tho soldered the J1 and J2 connector pins on the opposite face, let's call it the copper face.
Hello everybody!I am finishing a control surface for a Seq V4 right now. I would have some questions concerning the CS. It was impossible today to get 27 Green LEDs. I set so 27 Red Leds. Which resistor should I change to allow them to work fine? In addition, it was difficult for me to notice the polarity of these Leds on the PCB...
I have a cool idea to use this Midibox KB... 8-)
Hello, I just finished an LRE8X1. Someone knows where is the firmware for this? I guess I will use it either on an Core STM 32 or Core based. Thanks, PK
