346 -
3
Everything posted by sineSurfer
Yep, 12mm for the main mount holes + 10mm spacers for extra support, just tested yesterday using only 12m spacers, the pcb bends a little when pressing switches in the middle, like 1 mm so I guess after a while this could be a problem(broken solder joints), better to add extra 10 mm spacers. Beware, get 5mm thick spacers as 5.5mm thick won't fit into the panel mount holes. btw. is it just me or the 3mm leds don't fit into the holes, any tip to make them fit?
From the album: sineSurfer
The mbSEQ panel from Julian is here, whee! -
hi cimo ;) maybe this will work?: http://www.getlofi.com/?p=518 http://ericarcher.ne...-space-rockers/ http://www.beavisaud...inoPunkConsole/ http://nostromo.nois.../arduino-piano/ Laters!
Hi Julian, thanks for the answers. I guess I can move the funds form paypal to my cc, don't feel that happy by sharing my cc # with google though, they have too much info on me already hehee and about the extra spacer holes, will be nice if you can do them ;), btw what's the diameter of this holes?, just checking to be sure I get the proper spacers from Mouser Thanks, Freddy.
yes, the matte black x0x panel, how much $ for that one? and, white infill is fine for me ;) A couple of questions: Will you add the extra milling for pcb support as suggested by Wilba in the construction guide? Is there any chance to have a panel cut at 17" or 18" for desktop case usage?(no rack ears) maybe after doing all the cnc? btw. do you take paypal? Thanks, Freddy
Hi, yesterday I played a little with fresh mandolane install and mios studio just fine, but today I can't make it work again, keep getting this message "Received SysEx message of less than 8 bytes.". Things I tried so far: Different midi interfases: midisport 4x4, tascam US428, GM5x5x5, same results on each one Changed the core I was using to rule out some hardware error Changed midi cables reinstalled mandolane activated 32bit on Java preferences tried mios studio 9_3 and 9_4 all this without any luck the mac is running with: OS 10.5.8 java version "1.5.0_22" Java 2 Runtime Environment, Standard Edition (build 1.5.0_22-b03-333-9M3125) Java HotSpot Client VM (build 1.5.0_22-147, mixed mode, sharing) as a workaround I tried to go with the laptop, but had an old mandolane demo installed now expired, so out of luck there too and don't feel like buying a possibly broken piece of soft so... is there anything else I should look for?(I can't tell what changed since yesterday, other than turning off/on the comp ) Are there any usable alternatives to mandolane? thanks, Freddy.
thanks for the goodie, nice one TK!
Hi Fozzy, not exactly the same but should give you some ideas;) (the synth is a Paia Fatman )
the next "official" thing on my queue, still missing the midibox part though :)© sineSurfer© 2009
mmm, I'll have to try it, thanks for the searching/testing TK! btw. is the Flame Six-in-a-Row using this solution?
Hi there, the link to the pdf is in the Midibox CV page, but file is missing: Interconnections to MBHP_AOUT_NG module It seems that older AOUT file will work though: Interconnections to MBHP_AOUT module
Hi meeshka, you can use Xcode, just install it from the OS X disks and check the link to set up svn access: http://www.midibox.org/dokuwiki/doku.php?id=how_to_setup_xcode3_to_access_the_svn_server&s[]=xcode you can skip to "Setup SVNMIOS Repository", ignore the "key" parts, user and pass info, you should be able to download all the files just fine.
just tried to buy one among other things... surprise, surprise... they don't accept orders from mexico
© sineSurfer © 2009
x1 and x4, one configured for mbSID (ensemble bank)© sineSurfer © 2009
