latigid on
Frequent Writer
    2,516
    147
  1. No extra CV needed :) Okay, but what's the best implementation? Assign all tracks to AOUT port, channels 1-16 with duplication for 8 channels to the respective MIDI ports? In this case there's nothing in the config file to assign the gates to the correct SR (AOUT 1-8 but not 9-16) But isn't AOUT 16 already configured for extra gates with one sent for every MIDI note? Going back the other way, using the respective ports with duplication to AOUT 16. But here wouldn't the gate respond only if it hit the correct MIDI note? Would there be a way to map all notes of a channel to a single note on AOUT 16 and thus the correct SR pin? Many thanks,
  2. Feature request: all 16 tracks can have their gates assigned to DOUT pins. I think at the moment just the AOUT + extras on "AOUT_16" can send them. I'm not sure how that would work with port assignments: can a gate be sent on both a MIDI channel and as a DOUT signal?
  3. Right... you want to use the GPIOs for gates. Did you enable this in your hardware file? # should J5A/B/C outputs be enabled (0: no, 1: yes, 2: yes, but in open drain mode)? # - the 6 first AOUT gates will be forwarded to J5A/B # - the remaining last 2 AOUT gates are available at J5C.A10 and J5C.A11 (LPC17: J28.WS and J28.MCLK) # - DIN sync clock will be forwarded to J5C:A0 (LPC17: J28.SDA) # - DIN sync start/stop will be forwarded to J5C:A1 (LPC17: J28.SC) # - if open drain mode enabled (option 2), external pull-ups have to be connected to J5 pins # (advantage: pin levels can be pulled to 5V) # # NEVER USE THIS TOGETHER WITH ANALOG POTS - IT WILL CAUSE A SHORT CIRCUIT! J5_ENABLED 1 The idea I think is to move towards DOUT gates, I suppose the pin assignments from the Core remain as a legacy function. P.S. Open-drain mode does not work (at least for STM32F1 and I think LPC 17), your gates will be 3-3.3 V and no protection is implemented for the Core. Take care how these are connected!
  4. Hi, you shouldn't need use a CC, just enter some notes into the pattern. Hope that works!
  5. Hello, you should configure your track as AOUT channel 1, this should send the gate. It would be great if TK could tweak the SW to allow all 16 channels to send their gates to the DOUT, I think with the BLM this will be really cool even if the corresponding CV is not sent.
  6. First thoughts: The 1M resistor will create a voltage divider, I guess you chose 1M to minimise the effect of this. Definitely go for Schottky-type diodes for clamping. You're correct in that the reverse voltage will kill your IO otherwise. You might want to check this out: It's designed for an STM Core but could be easily adapted for PICs. The concept is to use a rail-to-rail opamp as a second inverting amp stage instead of diodes. There's no chance that a higher voltage gets through unless it manages to raise/lower the power rails (unlikely in a modular setup). The design has input attenuators and switches/jumpers for selecting the voltage range (unipolar 0-5, 0-10 V or bipolar -5 to +5). I might have some spare boards available, currently I haven't tested them due to other commitments. Let me know if you want some and I'll look into it for you.
  7. Let's keep up the discussion, I have an opinion but it's not meant to trump anyone else's. For me this would look a bit tacky and lose stability. Maybe wooden end cheeks could be added but here I think a sloping sheet music stand would be the best option. I'm trying to picture this, but if I've got it right you suggest standoffs on the rear of the panel. If you read up a few posts my idea is to use long studs (threaded rod) on the rear of the panel, through an acrylic spacer and then through the PCB and tightened on the back. This comprises a lot of material to avoid flexing and the threads are smaller in diameter compared with standoffs. I've kept in the other mounting holes on the PCB (2.8 mm), so if more strength is needed they could act as fixing points on the back. But in this case you couldn't go through the spacer as there's not enough material left for the grid shape after the hole has been cut out. In terms of flat or sloped, we have to consider what else goes inside. Will everyone buy a miniCore board? Or do some prefer to use their old Core8s? What if others would like to develop a BLM-specific instrument e.g. with a Core32 inside? Again, I need to check the full PCB dimensions but a square case will have wasted space at the bottom of the BLM. In this situation what is preferred? A flatter part at the front or a uniformly thicker case? This is my main motivation for a sloping box. You're dead right, U-shaped cases are much cheaper than the "Consolet" style from Protocase. EDIT: but in fact the "sloped top" style is the same price as the U-shape. The "consolet" has an extra flat part on the top and a removable rear panel. So there's already savings available.
  8. Also a possibility. Just a question: is your idea motivated by aesthetics or price? From what I've seen of Monomes and the like, the flat surface is not very ergonomic, hence my idea of a slope. It can possibly be made flatter but I have to check the PCB first. Also remember that we're already talking 30 cm+ for to the back of the case, bigger than say your Novation controllers. Didn't you already put four together? How is that to play?
  9. It looks that way but thankfully the socket doesn't go right to the PCB surface. Check a Core8 or on midibox-shop.com and you'll see.
  10. Heh, nothing too fancy! I'm still learning PCB design, but one rule of thumb is that you shouldn't have breaks in your ground plane where signals run across. If they go over a slot the return current has to take the long way around. Probably complete overkill unless you're getting into the MHz range, but I figure why not if it can be done without too much fuss. The blue is a keepout zone as measured from the Core r4,
  11. © 2015 latigid on
  12. Thanks for having a look, I will move the resistors away from the edge of the DIP40. I always put caps as close as possible to the power pins for the best effectiveness. Some 4-wall sockets are actually mirrored (we're looking at the back of the board). It's always best if you don't have to, but bending components out of the way or putting them on the other side of the board is always possible. OSHpark won't be too expensive so I'll order a couple after a few changes.
  13. and done I think. All 16 mil/single sided, I should check the clearances inside the DIP40 socket. I put in J5B in case anyone wants some extra pot/CV sources.
  14. © 2015 latigid on
  15. I'd like to redesign the Core board to fit with my There are quite a lot of unused connectors and components. I will add a line driver (74HCT125) to buffer the IO. First question: are pull ups on the unused pins still recommended?
  16. I don't have an exploded view yet but perhaps I can explain in words. This assumes an enclosure from Protocase Designer. Front panel is 3.2 mm aluminium (8 gauge in the US). There are 15 mm M3 studs running along the top and bottom edges and an M2 thread in the middle. I haven't yet specified the extra north-south studs as it messes with the symmetry :). Next is a 3 mm acrylic spacer which extends from the left edge to the sliders. It provides a semi-rigid support to keep the buttons in place, especially the extra ones that need to be cut into 1x4 pieces. Then the button pads. They have a 1.75 mm skirt and the buttons themselves are 10mm on top. This gives about 4 mm clearance over the top panel, more or less the same as ADAfruit's UNTZrument. Then the PCB (1.6 mm). Note that the sliders are 7 mm tall from the top face of the PCB. The back of the 3.2 mm panel must be milled out ~2.2 mm leaving 1 mm panel space to fit them under. The studs would pass through the PCB and be fastened with washers/nuts on the other side. The M2 screw right in the middle is important as it provides an opposing anchoring force. If more stability is needed there are four M2.5 (?) holes for each set of 16 pads. I hope the PCB+spacer+panel will keep everything rigid though, especially if it's all flush. (-1 point for JBweld, the glue would get in the way here) Then either a standard Core8 or a mini one as a piggyback module. Wire to the DIN 8 and you're done!
  17. Thanks for all the interest! Boards ordered today, fingers crossed!
  18. latigid on
    Full board
    © 2015 latigid on
  19. I'm not really enjoying the tone here... please have some patience and respect the fact that I've already spent significant time on this. I take all of the risks if there is a flaw with the PCB design. And I've been careful to try to come up with a case solution in parallel in order to avoid a "band aid" approach later on. This is part of the success of the MB-6582 (and Xoxbox). Wilba specifically designed a device around the readily available Pactec enclosure. I bet many people have SEQ V4s which are all but finished apart from the case. I'm curious now: will the other people interested also like a case? After the panel is cut from FPE/Schaeffer or the Beast what is the next step? Will they bend sheet metal too? If somebody can conceptualise a case that is more affordable, more suitable (rack/desktop) and accessible to ALL of the people who will build one, then let's see your design. Don't waste too much time, just consider a PCB of 300x286.5 mm dimensions with approximately 5 mm spacing to the inside surface of a 3.2 mm panel. I have to build one first to get the clearance from the back of the PCB. but I'd say 30 mm would be the minimum depth due to the piggybacked miniCore8. Here's an idea: add holes (M4/M5) to the sides so rack ears can be attached. Or even wooden panels :).
  20. Phatline: you can get model files from ADAfruit if you want to cut your own. I'll post the dimensions later. Fantom: I already plan to use Formulor for an acrylic spacer but not the case as I don't think it's strong enough. Lamouette: cutting the panel is no problem. Because there is no engraving it's a job for a laser cutter or water jet. The issue is getting a case to match which is impossible to find in this size. So my logic is: if you have to pay $200 for the holes, why not get them to make the box at the same time? This way you get exactly what you want.
  21. I'm in Switzerland and I used Protocase Designer for the case. This is a proprietary format so I don't have the CAD file sorry. I did try to look for other cases but there is almost nothing in this size. Some are square but then are quite deep (100 mm). The front dimensions I've used are 330x330 mm, bottom depth 40 mm top depth 70 mm. Altitude had a good idea that the Core8 could be rebuilt on a smaller board and directly connected to the big PCB. I'm working on this at the moment. This could allow for a flatter case, although I still think a gentle slope.is a good idea. I envisage this as a desktop version as it would be awkward to play in a rack (IMO). Plus the height would be 7-8 rack units. I figure it will be expensive, so why not go for something nice. I don't want an UNTZtrument and I don't think the acrylic will be strong enough with a 16x16 sized matrix. Yes, $500+ is a lot but Schaeffer want 150 EUR just to cut the holes in 3 mm alu. The material isn't expensive but the machine time is wherever its done. If 10 people order cases then the cost goes down by almost half, and they will also retroactively discount the first one built. So you can see my motives here :). Remember that they are not just cutting the panel but professionally bending the case and installing blind nuts, studs and standoffs. A JBweld-free MIDIbox. This price also includes a "grained" finish rather than tacky (IMO) powdercoat colours. They could anodise it for extra $$ and time. And to fit the sliders in at the correct height the rear face must be milled out slightly. You're lucky if you have a milling machine and plenty of aluminium to practise with, but I'm guessing most people won't which is why I propose a professionally made case.
  22. The blue+red version will even come out a bit cheaper as the LEDs are less expensive. But I'm with you: green-blue-cyan has the most balanced colour. I really like the red LEDs as they are deep and powerful but the mixing with green just doesn't work properly. Underneath the silicone buttons the light is quite diffused, I didn't notice any pain here. The biggest outlay for me will be the case (>$500) as I will have to order one to check everything works. After that the price will be lower but I hope we can agree on one design/finish and I will preferentially sell PCBs to those who will buy a case too. When you say "contrast case" were you thinking of another case design, or a combined front panel? Anodised perhaps? If so there might be a way to get different finishes (e.g. black) but this would be an add on. I'm happy to discuss other styles, maybe people prefer a flatter box? First of all I will get the PCB working and we can go on from there.
  23. Cool, four-and-a-maybe is a good start! You'll have to check with TK on this one, basically you have some CC control over parameters on the SEQ. I did ask but it will be a development feature once people have the hardware. Joystick feature-creep! There is a bit of space (about 30 mm square) on the bottom right corner of the panel but none on the PCB. The sparkfun/ PS2 thumbstick might fit but I can't find accurate dimensions for it. The panel to PCB spacing is only 5 mm, so I think this is a no-go sorry. Great! C'mon Hawke, Moar ghear right? You could say you picked it up from an ESA flohmarkt? But thanks for the support anyway. Let's get some built and we'll try to tempt you later :). I almost got a good deal on LEDs from Aliexpress but the shipping cost and time doesn't make it worth it. I'm not sure if it's a good idea to order from Mouser at the 1000 piece price break before the concept is proven, otherwise I'd have a lot of spares on my hands... What's the general consensus? Green-blue-cyan for the moment? Or are there some attached to red-blue-pink?
  24. Altitude, Phatline, duly noted and many thanks! Lamouette, merci à toi aussi. The LED brightness is between 100-300 mcd. I was running these at about 8 mA while the peak is 20 mA so there is a little bit of room with current limiting. Maybe the duty cycle could also be altered. At least without the silicone pads they are painful to look at :cool: . I'm not sure about direct sunlight visibility but I can try if it's nice tomorrow :). The brightness is good in a naturally lit room in any case. For data the idea is to use an 8-pin DIN connector. If you have the Quad IIC module installed in your SEQ you connect the BLM for bi-directional MIDI and power (see here). The connector is a nice Amphenol pannel mount but the male plugs are a bit pricey at about $9 each. If anyone knows of a cheap supply of pre-made cables we could drop the cost slightly. I'll aim to get the PCB layout proofed and ordered this weekend.
