Many thanks!
That's a good idea for sure, but for now I prefer to keep it simple. Also attenuation to zero is much easier with a unipolar control. I don't yet know how TK will handle the software side of things and perhaps the levels will be limited in any case.
Here's another installment: a control board to work with the AIN board above.
My idea is to panel mount the AIN board via the pots, and have this at a right angle above. It includes:
4 sockets for AINs, connected via a ribbon to the bottom board
4 switches (ON-OFF-ON) to control the input ranges. I chose 2x 16-way IDCs which will span over two of the jumper spaces below.
4 outputs from a DOUT module. These will be either four CLOCK OUTS, or two CLOCK OUTS, one START signal and one CLOCK IN (see below). These are connected to 3.5 mm sockets but I have also used Schmitt triggers as LED drivers. The 74LVC14A chip (SMD) runs off 3.3 V but has 5V tolerant inputs, so it can be run directly from the DOUT.
1 CLOCK IN routed to two Schmitt triggers in series (logic level preserved) and the same LED as above. This is jumperable so the correct function (CLOCK IN or OUT) can be selected. I think 100k resistors should provide enough current limiting to protect the chip. The 3.3 V signal can then be connected to a DIN module for clock functions.
If I've missed anything, please let me know.
