373 -
16
Everything posted by eptheca
Hi, Does anybody know if it possible to disable the LED matrix? and in case, how? Also, does the sammichSID need any special configuration for 6581 chips in the setup, like the standard SID V2 ;; select default filter calibration value ;; expecting 12bit values (0..4095) ;; will be overwritten by ensemble setting - this is only used as default value for BankStick initialisation! #define DEFAULT_FILTER_CALI_MIN 0 #define DEFAULT_FILTER_CALI_MAX 4095 Cheers, Hal
I have re-cased my SEQ in a Pelican-style plastic case. Added a AOUT_NG with 8 CV and 8 Triggers Connected MIDI OUT 1-8 to a DB9 D-Sub connector for easy connection to the other half of the case which will contain the synths. Made a USB Micro cable with a switch to ground pin 4 for USB Host Support (OTG) as suggested by Yogi Connected the cable to a female USB A socket so I can connect a MIDI keyboard or a GM5 for 4 more MIDI OUT (total of 16 direct outs) With a USB A-A cable I can connect it to my computer for updates etc. The extra USB socket is just 5V for a gooseneck light Thought a case like this deserved a "Nuclear Football" key power switch :)
Midibox SID: Simple Control Surface and LCD wiring questions
eptheca replied to fallenturtle's topic in MIDIbox SID
For the SID with PIC 18F4685 the LCD have to run in 4-bit mode. Use this diagram http://www.ucapps.de/mbhp/mbhp_lcd_4bit_mios8.pdf For the buttons and encoder, use this http://www.ucapps.de/midibox_sid_cs/mbsid_v2_din_default.pdf Ribbon cable is fine for MIDI For Audio, it depends on how far away from the SID module you are stretching the wires, and what other wires or circuits the wire pass on the way. For best results, use a shielded audio wire. Good luck :) I have built 3 MBSID's Pics would be nice- 3 replies
- sid
- control surface
(and 2 more)
Tagged with:
Sounds great. Really liked this one. Is it the Erica Synths Polivoks filter? #dawless
It just says you should double check before you order anything. Some settings in CAD software could change line weights etc. To add your corner screw holes, use the FPD file, add them, and export to DXF.
Yes, It's a vector file, not just a bitmap file. The DXF exporter in FPD is accurate to 0,01 mm or 0,0001 inch. You don't need anything more accurate than that.
SammichSID with MIOS v2.044 - no boot after update
eptheca replied to tassadar's topic in MIDIbox SID
Hi tassadar, According to the Changelog you should have updated MIOS first to V1.9h before installing SID V2.044. This version got an improved rotary encoder handling. Please update to MIOS V1.9h before uploading the application, otherwise the improvements won't be effective. If I were you, I would update to MIOS V1.9h and then install SID V2.044 again. -
Hi folks, I can confirm that the latest FW update from ST, M16 works great for the "new boards" MB997D No need to remove the resistor and bridge from the board to power it from the Micro-USB :) Get the latest Software and Driver as well as the update here: http://www.st.com/en/development-tools/st-link-v2.html Install the Driver first, then the Software, then with the board connected with the MINI-USB / ST- Link, run the ST-LinkUpgrade app. (Through the STM32 ST-LINK Utility it only suggest to update to M15) Merry Christmas :) (other holidays are available) Hal
I am finally building my old sammichFM kit :) The LCD that came with it is an Orient Display FSTN Negative red On the PCB there is an option for "High-power" backlight (250mA) The standard configuration is for "Low-power" (25mA) The paper for the LCD says: Max V= 4,1 and that the forward current for the RED backlight is 210mA Which setting should I use? I think it is a bit dark/dim, or maybe it's the type of LCD. Is it safe for this LCD to use the High-power setting? Cheers, Hal
Thanks :) I am hoping to use my music equipment more with this form factor. It's a pelican- style case that I have mounted rails in. 19" rack rails for the SEQ and Eurorack rails for the synths. They are all MIDI synths, no modular analog synths (yet anyway). 3+3+1U, 93HP Good ideas about the flat cable :) The less I have to do to set it up, the better. Is the Ground from MIDI OUT to the shield of the MIDI cable important? I have to figure out about the powering of the synths, and the audio out. Trying to figure out a power supply with 5V, 9V, 12V and 15V. I guess I have to accept some cables.
Thanks for the tip, and the offer. I think I will still need my Quad IIc for the total of 8 direct MIDI OUT? Or can I get that with the STM32F4-to-BOB adapter board? I don't have much space in this case I am making, so I am trying to do it with as little modules/components as possible (see image) It just felt unnecessary to plug in and out 8 MIDI cables each time. A short serial cable will work great I think, also for when I detach the lid from the SEQ part and have them next to each other.
Hey, that's a cool project. So a 9-pin shielded serial cable, and "BOB's your uncle" ;) Do you have any suggestions where to get one? I was looking for one earlier today, but none of them where 1:1 in pins and had wires on all the pins, that's why I thought of the VGA, I have tons of them. But your right, they are stiff and thick Hal
Thanks for the info. I am also considering another option. Is it possible to use a "multi midi cable"? Does MIDI cables need individual shielding, or could I use a D-Sub connector cable like a VGA cable with a DE-15 connector from the SEQ to the case with the 8 synths. So the 8 M- pins from the 2x MIDI IO modules and 1x Quad IIC module get an individual wire, the Ground goes to the shield of the VGA cable and the 5V gets a wire. On the other side of the cable, in the synth-case I could connect a MIDI wire and a 220 ohm resistor from the 5V to the MIDI IN on each synth. Would this work? Or will it be "cross talk" between the "MIDI wires" inside the cable.?
Yes, that looks very nice. The LEDs are singing "It's hip to be square" ;)
That worked great, thanks :) Used a MC74HC04A Hex-inverter I had. I guess I can use the 3 remaining inverters on this chip for the second port and one more chip for tree and four. What I'm not sure of is the difference in latency in this, compared to the direct MIDI OUT from the UARTs, but I'm pretty sure I can't hear it.
Thanks guys, I have a try with a hex-inverter after the out pin on the GM5 chip, and then a MIDI Out DIN circuit with 220 ohms resistors. Hal
> Maybe the problem can be simplified on the other end: one or two DIN MIDI with a thru box on the other end. That's a possibility. I could test that and see what kind of latency etc I get. Cheers, Hal
Yes the diagram is incomplete, I have 2 x MIDI IO and 2 x Quad IIC connected to the Core already :) But I was thinking for the mobile solution, that I could get away with mounting the GM5 in the case with the synths, and then I only have to connect the SEQ and the synths with one USB cable. Do you know how long the cable can be between the Core and the MIDI IO and Quad IIC modules, or if there is a "Line Driver" solution for long cables for this purpose?
