3,636 -
36
Everything posted by Hawkeye
i am not sure if you can get any slower than when shift is pressed in software - maybe your encoders are just "too quick"... maybe you are also using the wrong "encoder type", which can be changed via a recompile... to do that... well, you need to get the MIOS8 compilation toolchain up and running, but it takes some time and is a bit complicated... start reading here: http://www.midibox.o...n_development[]=toolchain then here: http://www.midibox.o..._toolchain_core then read a bit on encoder types: http://www.midibox.o...p?id=encoders[]=encoder&s[]=types then look in the assembly "config" file for the mb6582, where you can adjust encoder types: http://svnmios.midib...82.asm&peg=1024 If you manage to compile your mb6582.hex file in a "legitimate" timeframe, you can play a bit around with those, maybe choosing another type will improve the situation ... on the other hand, a set of new encoders is less than 30€ on mouser, and it will probably be quicker and more cost-effective, if you consider your time spent...
depends on what you want... you could patch the software to assume constant "slowness" like the shift button is always pressed, but this would require some software assembly work, or exchange the encoders against the recommended encoders: but this would require some hardware assembly work :twitch: Greets, Peter
Are you aware of the input accelleration? If i do a quick half turn of the cutoff encoder, it will approximately change half the cutoff range (eg from 000 to 800), if it is done slowly, single-step increments are possible and i can turn "forever". Also note, that when you press "Shift", while turning the knobs, it will go into constant-slow (unaccellerated) mode. Maybe this helps. Not that i had looked into it, but with a recompile you can surely change the accelleration behaviour of the encoders, if it is too fast...
Hi! * die DOUT LEDs liegen umgekehrt an: (siehe "Note") * die STEP LEDs sind nur gesamt einzelnen Shift Registern zuzuordnen, was ja auch Sinn macht, da Du eh zwei davon brauchst (vier für duo color option) * die Encoder Pins liegen auch immer nebeneinander, was ebenso Sinn macht, um die Kabel bis zu den Shiftregistern parallel führen zu können. Ciao und viele Grüsse! Peter
A commercial SID synth that look damn familiar (seen on MESSE)
Hawkeye replied to stuartm's topic in MIDIbox SID
they also cleverly installed those 5mm hi-power blue led eye burners to make their users go ray charles -
damn, gotta clean my screen zoon, theres some fly spots on it :laugh: edit: to clarify - nILS made Smithys font tiny - which was soonafter undone by Smithy :) -
Nice! Also many thanks for the big "Invoice Enclosed" sticker - not having it on, is the main reason for me to head to the 20km away customz office, when importing cheap china stuff :). Have a great weekend! Peter
After watching 100 hourz of nyan cat and listening to 50 hourz of Klaus Schulze, just before heading to bed, finally had some late-night SID proton blending fun :) Please use headphones for optimum SID induction :) Did I evar say, that the MB-SEQ V4 is unparalleled in thiz world? It is!!! Thanks for listening! Greets, Peter
Well done, my friend - I couldn´t sing like that! Thanks a lot - it also inspired me to do a quick track after work :) Greets and have a great time! Peter
Nice :sorcerer: Have lots of fun with it!
if i had the choice between making music on that thang or my grannys sewing machine, ´t would be a total no-brainer * -
Cit, unfortunately the shipping and handling is added on top by the darn customz... So you might have to pay a few euros (einfuhrumsatzsteuer), but it ´prolly won´t be a big sum! Greets, Peter
:frantics: Thanks for your work, Tim - order placed :) Just as a feedback - for me, there was no address input form in the process - i´ve sent you an email with the shipping address (which is the same as the paypal shipping address). Greets, Peter
If you don´t want to do duplicate work, wait for mbsid v3 - which will be based on the new core... TK. was working on it and it will feature a lot of goodies :) Also, my personal suggestion would be to not add too many things to a single one-core project - the seq or the blm for example can be nicely decoupled into separate projects (in fact there are long-proven midibox projects of them running everywhere around the globe). The fact, that they are separate (by design and pcbs) does not mean, that you need to separate them in your sid-seq-blm-box, which can be one single hardware unit. On the other hand, if you want to do it for the thrillz and have some time on hand, then please don´t let my words discourage you :) Greets, Peter
Don´t low-value orders slip thru customs in finland? In germany, there is a (ca) 21€ border, where tha customz officer getz nuthin´ but a wet handshake :) Unfortunately, i have to always wait for ´bout an hour every time to give that handshake, so local distribution would be very much welcome, from my side. But this won´t be possible so easy, unless Tim opens a "Europe" branch. New York - Berlin - Tokyo :) Greets, Peter
Hi Sparx, can´t help with the 595s, but regarding your question of someone else using the new core for audio output: have a look at Lee´s fine polyphonic sd sample player - which uses a DAC for output: Greets, Peter
That is no error code, it says Ensemble 2, Patch H128, Lead Instrument, Listening on MIDI Channel 16, SID Pair 1 active in user interface (2-4 not active) So, have fun with your new fantastic synth! Greets, Peter
+1 on the poti setting, which is a classic :)
Awesome color! J, please do a purple ´shroom design with some engraved buddhas on it :) a psy-trance seq lite for the masses :) ´ave a nice weekend!
