Ok, just tried it on the little phatty... (which is not an xbase, but i am quite sure that the xbase also sends midi ccs, when you turn a knob)
Set up the track:
Choose the track you want to record MIDI CCs on
Go to MENU->Event
Set Track type to CC (e.g. 128 steps and 8 parameter layers - you can then record up 8 different automations on that track)
Don´t forget to initialize track!
Important! Before initialization, choose the right parameter layers on the right screen.
E.g. parameter layer A is by default "MOD Wheel" - you need to find the right CC type, which you want to control.
The "Controller Number" in your datasheet above corresponds to the CC number.
Record:
Go to record page, Set correct MIDI IN port and MIDI channel
Set Record mode "live", Astart "off" (for me)
Press play and record buttons to arm the bomb :)
Now, when the MIDI device sends any CCs, its values are stored on the currently active parameter layer of the currently recorded step.
Try turning any knob, you should see live values recorded on the track edit screen.
Playback:
You will need another track to actually gate the synthesizer, e.g. play a bassline or trigger your drums.
Or be lazy as me and just hold the "gate" pedal of the synth, which just plays the last keyboard note. Nice automation going :)
By the way, the CC steps need to be lit (gated on the "GATE trigger layer") for CC playback to occur.
Greets,
Peter
Edit: just reached post #1.000 :frantics: which is probably a sign of severe MIDIbox addiction :)
