GM5: Least-cost USB-MIDI Interface Chip for 4.50 EUR
Chips and boards arrived safely today - Man, those are some small pins. Looks like it's time to practice my SMD technique on some old RAM...
  • Replies 732
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I've still 8 GM5 chips in stock from people who haven't paid yet (4 weeks after first notification, 1 week after deadline...)
So - this is your chance to get the remaining ones, the quantity doesn't matter - 1, 2, ... 8.
I've also more than 100 small PCBs in stock - let me know if you are interested as well (the rest will be sold during the next bulk order).
Just PM me the desired quantity - NOW! - first come, first serve!
SOLD OUT!
TK: Many thanks for the GM5 ! I just finished the 2nd Unit (besides small problems initially on the +5v) and all is working now.
Now it's time to look at the port extension (on protoboard).
--jan
  • 3 weeks later...
hi, i paid
Nov. 13, 2008 Payment To Thorsten Klose Completed Details   -€13.65 EUR  €0.00 EUR  -€13.65 EUR
#05362820XB5106219
is it ok the package not showing up yet? I also miss invoice for the 5x5 -.-
According to my records, I sent you the small parcel on 21th november, more than one month ago.
If you don't get it in the next 3 weeks, please write me a PM and we will try to solve this
  • 1 month later...
I'm also on this list. I'm assuming we will be contacted for paypal payment when the minimum is reached and this will communicate the address?
question to all: did anybody already test the part under full load on all MIDI channels at the same time? If yes, did it work properly? I have currently an issue with this GM5 in a customer specific equipment, and under some strange circumstances it hangs up from time to time -- communication on USB and also sometimes on the MIDI ports stops. Only Power-Down/Up solves it.
Cheers,
Skunk
Hi Skunk,
which computer, which operating system, which driver, which HW variant?
I recently had similar issues on my Mac with one of my GM5 modules which is connected to a passive 4x1 USB hub. After some troubleshooting it turned out, that the power consumption on the hub was too high (e.g. a MBHP_CORE_STM32 module + a MBSEQ Frontpanel with backlit LCDs was connected as well).
I solved this by using an active hub with dedicated power supply.
The strange thing was: the MBHP_CORE_STM32 module was still working pretty stable - so it seems, that the Atmel chip is less tolerant against voltage drops, but I haven't checked this further (as I found a stable solution...)
Hi Thorsten,
which computer?            an AMD motherboard with 2.4GHz Athlon (don't know the supplier)
which operating system?  WinXP SP2
which driver?                  Ploytek special, customer specific
which HW variant?          customer specific -- a special board connected via the
                                  GM5 to the motherboard and a second USB-to-Audio
                                  USB I/F with 480Mbit, also connected to the motherboard.
                                  If the 480MBit line fails, the 12MBit USB-to-MIDI line also fails
                                  sometimes
In the meantime we found one possible problem for the failure: groundbouncing. During the initialization of the USB controller on the motherboard, looking for devices, a groundbounce shuts the device recognition down (it looks like that, but this is not yet proven). There seems to be no means in the GM -- only reset.
Cheers,
Andreas
Hi Skunk,
Your manufacturer is probably Dell. I have exactly the same problem. But only with the AMD Athlon board (as well with the 3800+ as the 5400+), not with the Intel (Also Dell).
The USB freezes after intensive use. I think it's a heat problem, but have not looked more into it. Under normal use the USB is fine. Put it under load and it hangs.
If it is still possible to order, I would like 2 Chips with 2 PCB's.
Gioxannes.
This is so weird.
You can get a MIDI-USB-Interface with 5 I/Os for just about 15€!
I mean, search for MIDI-Interfaces at thomann for example and compare the prices.
Can anybody tell me why that is like that?
:P
...and compare it with the Blacklist
Most low-cost interfaces provided by Thomann are working unreliable.
Today you can buy an USB based Multi Purpose card reader for less than 5 EUR, but usable MIDI interfaces are still so expensive like 10 years before. However, seems that this is still a field where you can save money with DIY :)
