Futureman Posted May 25, 2009 Report Posted May 25, 2009 I hope you are not getting annoyed with my questions etc TK.. but I've got another. ;]I use the "All" button quite a bit... (Well, my sequencers are at the hub of my setup)I've found myself, sometimes selecting a track that does not have a step in it while the "All" button is enabled. This currently switches on that step, but switches off all the other active steps.Is it possible that I can deactivate this sort of "inversion" of the steps?I realise I can should just make sure that the "All" button is off before I select a empty step, but it does seem counter intuative that pressing a un-active step would switch off all the active steps when "All" is on.As always, the kindest of regardsMike Quote
TK. Posted May 25, 2009 Author Report Posted May 25, 2009 This feature was a special request by Wilba, I could make it optional if desired.In order to decide about the default behaviour, I would like to know, how many other users like/dislike this function (all triggers inverted when ALL button pressed) - opinions?Best Regards, Thorsten. Quote
Gridracer Posted May 26, 2009 Report Posted May 26, 2009 I like the inversion behaviour of the ALL button very much, as I can quickly set up a new track:1- I start with an empty track2- Push the all button3- push any GP button -> all steps get set4- I use the data wheel to find the right base note, chord, or druminstrument5- I push again any GP button -> all steps get swiched off6- Push the all button again-> Now i built the melodic or rythmic structure by swiching on certain steps and increasing or decreasing values with the encodersBest regards Gridracer Quote
swindus Posted May 27, 2009 Report Posted May 27, 2009 In order to decide about the default behaviour, I would like to know, how many other users like/dislike this function (all triggers inverted when ALL button pressed) - opinions?I don't like this function. I have the same 'problems' like Futureman. Quote
Futureman Posted May 27, 2009 Report Posted May 27, 2009 I spoke to my mate (who I helped make his seq) and he doesn't like the inversion feature either... (Honest.. lol)My main gripe is that it doesn't seem to make sense to switch off all the active steps.. if I have a nicely crafted riff playing, why would I want to turn them all off and fill the blanks with C's ?I can see that there is a potential time for wanting to flood the whole pattern with the same note (as mentioned by Gridracer)Maybe this could be done while holding down "All" and pressing another button such as "Layer A" etc? Not sure.. for me, I just slide my finger along the step buttons.. only takes a second.Kind RegardsMike. Quote
tongenerator Posted May 27, 2009 Report Posted May 27, 2009 hello,i have the same "cursor position" thing on version 3.4 f, also the datawheel is not working anymore.it changes a couple values but not keep them, it looks like it runs through.of course i did not make a backup of the old version, that was on there...can i download the older versions like 3.3 or so somwhere ??? Quote
TK. Posted May 27, 2009 Author Report Posted May 27, 2009 An older version won't helpDoublepost!Discussion continues here:http://www.midibox.org/forum/index.php/topic,13576.msg116764.html#newBest Regards, Thorsten. Quote
kokiPsiho Posted July 23, 2009 Report Posted July 23, 2009 Hi,I've updated to 3.4e from 3.4a and Sync to measure feature still behaves weird like Futureman described in his post. Can anybody check to confirm this?Thanks,koki. Quote
TK. Posted July 23, 2009 Author Report Posted July 23, 2009 Wasn't this issue fixed in v3.4e? I tested it myself, and futureman probably as well?If there is still an issue with this function, I need to know more details how to reproduce it.Best Regards, Thorsten. Quote
kokiPsiho Posted July 23, 2009 Report Posted July 23, 2009 Sorry TK, all is fine. I have mess up my hex files.Thanks,koki. Quote
TK. Posted July 23, 2009 Author Report Posted July 23, 2009 Alright - hope that this doesn't happen again when I release v3.4f this weekend ;)(it will contain the latest improvement requests)Best Regards, Thorsten. Quote
nuke Posted August 7, 2009 Report Posted August 7, 2009 any news on 3.4f ?...are you going to implement the "global shuffle grid" already? :D Quote
TK. Posted October 4, 2009 Author Report Posted October 4, 2009 V3.4f is finally available.From the ChangeLog: o built for MIOS V1.9g (or higher) to support new encoder types. Rotary encoders won't work with older MIOS versions! o Groove function now takes the global step has reference instead of the local step. This results into better results on a non-linear step progression. o Bank of group #1-#4 can now be selected via CC#116..CC#119 o due to various user requests, the previously introduced "set/clear all trigger" function has been disabled by default. It can be enabled again with the DEFAULT_BEH_ALL_WITH_TRIGGERS switch in setup_*.asm 0: only parameter layers are modified by ALL function 1: all trigger and parameter layers are modified by ALL function[/code]Please update your MIOS installation before uploading this new version!Best Regards, Thorsten. Quote
nuke Posted October 6, 2009 Report Posted October 6, 2009 o Groove function now takes the global step has reference instead of the local step. This results into better results on a non-linear step progression.brilliant!!....absolutly....thank you very much....!!! Quote
bassline Posted March 9, 2013 Report Posted March 9, 2013 A little demo with my MIDIbox SEQ V3.4: -TR-808 sounds with reason redrum -Subtractor synth Beste Grüsse :) Quote
TK. Posted March 9, 2013 Author Report Posted March 9, 2013 Nice! :) Btw.: where did you buy the LCDs? I like them! :) Best Regards, Thorsten. Quote
bassline Posted March 9, 2013 Report Posted March 9, 2013 Hallo! http://www.ebay.at/itm/LCD-MODULE-MC4002D-SBL-ALPHANUMERIC-2X40-STN-1-Stuck-/310595276901?pt=Bauteile&hash=item4850ebd065 Grüsse :) Quote
TK. Posted March 9, 2013 Author Report Posted March 9, 2013 Very cool! I ordered 4 pieces :w00t: Best Regards, Thorsten. Quote
bassline Posted March 23, 2013 Report Posted March 23, 2013 A techno song with my mbseq v3.4 ;) Quote
lajos Posted June 29, 2013 Report Posted June 29, 2013 Hello! I'd still like to know whether you can stick on to the bank is ready to copy patterns and how? Thank you, Louis. Where can I download these patterns? Quote
bassline Posted December 7, 2013 Report Posted December 7, 2013 A dubtechno experiment with Santa Klaus ;) :) Quote
TK. Posted December 7, 2013 Author Report Posted December 7, 2013 I like this - the style is somehow like "Kalkbrenner meets Reggae Dub"! :thumbsup: Unfortunately you stopped the video to early! Quote
