MIDIbox NG Release + Feedback
TK.
1 hour ago, TK. said:
Are you using the set_lock command in your .NGR script?
No, I don't use that.
Hm... strange. At least the LED rings do not update. I didn't doublecheck with the controllers itself. I'll investigate ....
Thanks for adding the load command!! ;-)
Edited by FantomXR
Link to comment
Share on other sites
  • Replies 353
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I checked this with LRE2x8 - the LED rings will be updated
Or do you mean LED rings, which are assigned to various banks, but not to the selected bank?
Then I guess that they won't show the updated value until the assigned bank will be selected.
Link to comment
Yes. That's what I meant. Simple example:
LED ring 1 CC1 bank = 1
LED ring 2 CC2 bank = 2
if my software now sends both values for CC1 and CC2 only the selected bank gets updated. The unselected bank doesnt. If I switch to the unselected bank it shows the old value. If I than turn the controller in my software, the LED ring jumps to this value.
Link to comment
Such a configuration doesn't fit to the intended use case.
Actually only a single bank is supported, and it's intended that all display elements have either an assigned EVENT for this bank, or that they are not assigned to any bank.
Link to comment
Hi
Load command work fine :)
I just have a question regarding ^section == 0
When this script is read ? only after startup or reset ? before or after .NGC load ?
I'm able to automaticity load another setup without conditional with load setupA at section 0
if ^section == 0
 load setupA
 exit
endif
But I'm not able to chose a setup (with conditional)
The use case is to have "default" acting like configuration router
setupA (user config) automatically loaded at startup,
but if I press some button at startup it will load other setup, like setupB for dedicated calibration, or setupC etc..
if ^section == 0
 delay_ms 2000
 if button:1 == 127
  load setupB
 else
  load setupA
 endif
 exit
endif
 I have the event_button definition at NGC but if I press it, noting happen, setupA nor setupB are loaded and system is locked at default setup.
Best
Zam
Link to comment
I have another bug report. It's about the NRPNs. As far as I understand a NRPN contains at least three different CCs:
CC#98 = NRPN number
CC#99 = NRPN "bank"
CC#6   = NRPN value
So if I set nrpn=20, it sends CC#98 20, CC#99 0 and CC#6 depending on the value of the controller. If I go over 127, CC#99 changes to 1 and CC#98 counts again from 0. That makes totally sense. But! If I go over 256, CC#99 stays at 1 and doesn't count up to 2.
Or do I overlook something?
Link to comment
  • 7 months later...
if ^section == 0
 delay_ms 2000
 if button:1 == 127
  load setupB
 else
  load setupA
 endif
 exit
endif
The same problem for me. By further investigate NGR script doesn't go beyond the load command. Anything after "load <setup>" command doesn't execute.
BR Norbim
Link to comment
8 hours ago, FantomXR said:
Why don't you call nothing with section == 0 but assign metas to the buttons directly so that they load a NGC file when hitting them?
Hey Fantom
Don't know about Norbim usecase.
In my case it was to select a config at start up, before all buttons get busy for other task.
Your option need a spare/unused button or a conditional flow by hitting two buttons.
Anyway, it's not a critical function for me any more
Best
Zam
Link to comment
The problem is that even the load command is in a conditional branch and the condition doesn't match, the commands after load doesn't execute. In the above example the "load setupA" doesn't execute in the else branch. Also miss the other commands outside the if branch.
Is there a meta op that loads a new NGC config?  I coluldn't find it in the user manual. Am I miss something?
BR Norbim
Link to comment
IIRC it's the same command as NGR:  type=meta  meta=LOAD<setup> ???
also I remember the function was deleted, then implemented again, not sure the downloadable NG1.035 have it,
you may probably build 1.036 from the source.
LOAD will load a "full" config NGC + NGR etc, if you just need to change .NGC you have to duplicate your NGR and just change the name according to both config
Best
Zam
Link to comment
AFAIK the load command works only from NGR. But never mind, I found the cause in "mbng_file_r.c", corrected and built it and now load commands in conditional branches work correctly.
BR Norbim
Edit: Attached the diff
mbng_file_r.c.diff
Edited by norbim1
File attached
Link to comment
  • 2 weeks later...
  • 5 months later...
I noticed that the last release was done 2 years ago, although many preliminary versions have been created meanwhile.
Therefore it's now officially available.
From the ChangeLog:
MIDIbox NG V1.036
   o new .NGR script command: send_seq (see cfg/test/seq* examples)
   o added new MIDI event types: Clock, Start, Stop, Cont
   o added new meta events to control a MIDI clock divider:
     MClkSetDivider, MClkDecDivider, MClkIncDivider
   o added new .NGC file configuration parameters:
     MidiClkOutPorts and MidiClkInPorts
   o new LCD format character '%L' allows to display logic control digits
     (MTC and status digits)
   o added new .NGR commands SET_KB_TRANSPOSE and SET_KB_VELOCITY_MAP.
     The configuration example can be found under cfg/tests/kb_6.ng*
   o encoder absolute mode: negative ranges are now handled correctly
   o .NGR LCD command: %d outputs the ^value
Link to comment
Hello
Now I'm used to build my MB_NG with latest pre release and updated code from SVN
But thanks for the official release !
Since I use this one for months, I don't catch any bug so far.
Best
Zam
Link to comment
  • 2 months later...
What is the correct usage of MidiClkOutPorts and MidiClkInPorts?
Is this all I need? I'm trying to send an incoming clock on Midi 1 to USB 1, I can't make it work so I'm thinking I might have to insert it into a Receiver / Sender event. Real newbie here on MB_NG, but what potential!
#Set Midi clock input port
MidiClkInPorts = 00001000000000000000
#Set Midi clock output port
MidiClkOutPorts = 10000000000000000000
Link to comment
Ok, figured it out. I found an example of  MidiClkInPorts in one of the test examples seq1.ngc. I can see the clock start/stop now in MIOS Studio but no clock data (FE) I'm thinking it's filtered out so as not to mess up the input monitor display.
Link to comment
  • 1 year later...
Hi Thorsten, was there a resolution to this? as I am looking to display the channel/track info on a glcd over each fader. i saw john finsters mackie clone and he was aable to have track info on his displays, I have messaged him hoping he will pop in at some time and i can discuss it with him, but i think he just used the mb_lc setup.
On 16/12/2012 at 9:22 PM, Duggle said:
Some questions:
  • How about LCD display of dynamic text as in patch name(s) contained within a received Sysex message?
I've no solution for this yet, but to ensure that this won't be forgotten I just have added this topic to the MBLC page.
It will probably work in conjunction with a EVENT_RECEIVER which listens to multiple bytes instead only one - but this would blow up the memory storage format, because each EVENT would need to store the byte range.
Once a solution has been found, the label could be inserted into outgoing SysEx, but also displayed on LCD with a special formatting directive (such as %t)
Edited by ssp
Link to comment
  • 3 years later...
It is confirmed the actual NG-Firmware was not tested for a LPC-Core (maybe someone made changes, but tested it only on STM32?
The actual NG Release (1.037) in the github trunk does not work on LPC-Core !
see this thread :
Link to comment
Guest
Reply to this topic...
